[PATCH v2 12/44] config: Add _SMP_Processor_configure_maximum
Sebastian Huber
Fri Feb 21 10:52:24 UTC 2020
Move the processor maximum configuration constant out of the
configuration table.
Update #3875.
cpukit/include/rtems/confdefs.h | 12 +++++++-----
cpukit/include/rtems/config.h | 14 +++-----------
cpukit/include/rtems/score/smp.h | 13 +++++++++++++
3 files changed, 23 insertions(+), 16 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 33b1aa67d4..f8a4eb23cf 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2639,16 +2639,18 @@ struct _reent *__getreent(void)
const rtems_configuration_table Configuration = {
#ifdef RTEMS_SMP
#ifdef _CONFIGURE_SMP_APPLICATION
- true,
+ true
#else
- false,
+ false
#endif
#endif
- #ifdef RTEMS_SMP
- _CONFIGURE_MAXIMUM_PROCESSORS,
- #endif
+ #ifdef RTEMS_SMP
+ const uint32_t _SMP_Processor_configured_maximum =
+ _CONFIGURE_MAXIMUM_PROCESSORS;
+ #endif
const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
#ifdef CONFIGURE_UNIFIED_WORK_AREAS
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 6489e4e4e8..5550397623 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -30,6 +30,7 @@
#include <rtems/score/isr.h>
#include <rtems/score/memory.h>
+#include <rtems/score/smp.h>
#include <rtems/score/stack.h>
#include <rtems/score/userextdata.h>
#include <rtems/score/threadidledata.h>
@@ -86,10 +87,6 @@ typedef struct {
#ifdef RTEMS_SMP
bool smp_enabled;
#endif
- #ifdef RTEMS_SMP
- uint32_t maximum_processors;
- #endif
} rtems_configuration_table;
@@ -204,13 +201,8 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
* @return The configured maximum count of processors.
-#ifdef RTEMS_SMP
- #define rtems_configuration_get_maximum_processors() \
- (Configuration.maximum_processors)
-#else
- 1
-#endif
+#define rtems_configuration_get_maximum_processors() \
+ (_SMP_Processor_configured_maximum)
#ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/smp.h b/cpukit/include/rtems/score/smp.h
index 4d6b24ae48..2722fbdcee 100644
--- a/cpukit/include/rtems/score/smp.h
+++ b/cpukit/include/rtems/score/smp.h
@@ -36,6 +36,19 @@ extern "C" {
+ * @brief The configured processor maximum.
+ * In SMP configurations, this constant is defined by the application
+ * configuration via <rtems/confdefs.h>, otherwise it is a compile-time
+ * constant with the value one.
+#if defined(RTEMS_SMP)
+ extern const uint32_t _SMP_Processor_configured_maximum;
+#else
+ #define _SMP_Processor_configured_maximum 1
+#endif
#if defined( RTEMS_SMP )
extern uint32_t _SMP_Processor_maximum;
2.16.4
