[PATCH v2 33/44] config: Add <rtems/confdefs/newlib.h>
Sebastian Huber
Fri Feb 21 10:52:45 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 24 +-----------
cpukit/include/rtems/confdefs/newlib.h | 72 ++++++++++++++++++++++++++++++++++
3 files changed, 75 insertions(+), 22 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/newlib.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 60a3687db8..1a23ce5608 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -190,6 +190,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/malloc.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/mpci.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/newlib.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index f4cbe43908..0e5038cf92 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -56,15 +56,12 @@
#include <rtems/confdefs/libpci.h>
#include <rtems/confdefs/malloc.h>
#include <rtems/confdefs/mpci.h>
+#include <rtems/confdefs/newlib.h>
#include <rtems/confdefs/percpu.h>
#include <rtems/confdefs/scheduler.h>
#include <limits.h>
-#ifdef RTEMS_NEWLIB
- #include <sys/reent.h>
-#endif
#ifdef __cplusplus
extern "C" {
#endif
@@ -98,14 +95,6 @@ extern "C" {
* used remarkably reliably by most applications.
- * This macro determines whether the RTEMS reentrancy support for
- * the Newlib C Library is enabled.
-#ifdef RTEMS_SCHEDSIM
- #undef RTEMS_NEWLIB
-#endif
* @defgroup ConfigurationHelpers Configuration Helpers
@@ -645,13 +634,6 @@ extern "C" {
#endif
-#if defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
-struct _reent *__getreent(void)
- return _Thread_Get_executing()->libc_reent;
-#endif
#endif
@@ -1005,9 +987,7 @@ struct _reent *__getreent(void)
#if CONFIGURE_MAXIMUM_THREAD_NAME_SIZE > 1
char name[ CONFIGURE_MAXIMUM_THREAD_NAME_SIZE ];
#endif
- #if !defined(RTEMS_SCHEDSIM) \
- && defined(RTEMS_NEWLIB) \
- && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
+ #ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
struct _reent Newlib;
#else
struct { /* Empty */ } Newlib;
diff --git a/cpukit/include/rtems/confdefs/newlib.h b/cpukit/include/rtems/confdefs/newlib.h
new file mode 100644
index 0000000000..5951eb83fb
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/newlib.h
@@ -0,0 +1,72 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Newlib Configuration Options
+ * This header file defines _CONFIGURE_ENABLE_NEWLIB_REENTRANCY for use by other
+ * configuration header files.
+#ifndef _RTEMS_CONFDEFS_NEWLIB_H
+#define _RTEMS_CONFDEFS_NEWLIB_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#if defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
+ #include <rtems/score/percpu.h>
+ #include <rtems/score/thread.h>
+ #include <sys/reent.h>
+ #define _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
+ struct _reent *__getreent( void )
+ return _Thread_Get_executing()->libc_reent;
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_NEWLIB_H */
2.16.4
