[PATCH] Add CoreMark Benchmark
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Fri Feb 21 17:26:52 UTC 2020
On Fri, 21 Feb 2020 at 17:11, Gedare Bloom <gedare at rtems.org> wrote:
> What is the difference between the CTSRD-CHERI fork and the upstream Coremark?
I submitted a pending PR to CoreMark/upstream to add RTEMS support
[1]. I have more flexbility and control over the CTSRD-CHERI fork to
push/use
fixess/features more quickly. Furthermore, CHERI-related bits and
another pending PR aren't upstream yet [2].
Currently, I have no problem just using the upstream one once my PR is
merged and later if we add CHERI support to RTEMS upstream, change the
fork.
[1] https://github.com/eembc/coremark/pull/21
[2] https://github.com/eembc/coremark/pull/19
> It should be made clear in the repo the license of the Coremark (APL
> 1.0 I believe)
That's included in the coremark repo itself. Do you suggest adding a
note in the commit message about the license?
> On Fri, Feb 21, 2020 at 10:00 AM Hesham Almatary
> <Hesham.Almatary at cl.cam.ac.uk> wrote:
> > CoreMark's primary goals are simplicity and providing a method for testing only a processor's core features.
> > It is used primarily here as a performance benchmark
> > Built and tested for RISC-V rv64imafdc_medany on QEMU and HW
> > .gitmodules | 3 +++
> > benchmarks/coremark/coremark | 1 +
> > benchmarks/coremark/wscript | 48 ++++++++++++++++++++++++++++++++++++
> > benchmarks/wscript | 2 ++
> > 4 files changed, 54 insertions(+)
> > create mode 160000 benchmarks/coremark/coremark
> > create mode 100644 benchmarks/coremark/wscript
> > diff --git a/.gitmodules b/.gitmodules
> > index ae86e49..2bcba90 100644
> > --- a/.gitmodules
> > +++ b/.gitmodules
> > @@ -1,3 +1,6 @@
> > [submodule "rtems_waf"]
> > path = rtems_waf
> > url = git://git.rtems.org/rtems_waf.git
> > +[submodule "benchmarks/coremark/coremark"]
> > + path = benchmarks/coremark/coremark
> > + url = git at github.com:CTSRD-CHERI/coremark.git
> > diff --git a/benchmarks/coremark/coremark b/benchmarks/coremark/coremark
> > new file mode 160000
> > index 0000000..cdafe98
> > --- /dev/null
> > +++ b/benchmarks/coremark/coremark
> > @@ -0,0 +1 @@
> > +Subproject commit cdafe986865cf46a3222f7bf28be82fc8d96fa8f
> > diff --git a/benchmarks/coremark/wscript b/benchmarks/coremark/wscript
> > new file mode 100644
> > index 0000000..c2c225a
> > --- /dev/null
> > +++ b/benchmarks/coremark/wscript
> > @@ -0,0 +1,48 @@
> > +# SPDX-License-Identifier: BSD-2-Clause
> > +# Copyright (c) 2020 Hesham Almatary
> > +# This software was developed by SRI International and the University of
> > +# Cambridge Computer Laboratory (Department of Computer Science and
> > +# Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
> > +# DARPA SSITH research programme.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> > +# are met:
> > +# 1. Redistributions of source code must retain the above copyright
> > +# notice, this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> > +# notice, this list of conditions and the following disclaimer in the
> > +# documentation and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> > +# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> > +# FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> > +# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> > +# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > +# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> > +# LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> > +# OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> > +# SUCH DAMAGE.
> > +import rtems_waf.rtems as rtems
> > +def build(bld):
> > + rtems.build(bld)
> > + bld(features = 'c cprogram',
> > + target = 'coremark.bin',
> > + includes = 'coremark/ coremark/rtems',
> > + source = ['coremark/rtems/core_portme.c',
> > + 'coremark/core_list_join.c', 'coremark/core_main.c', 'coremark/core_matrix.c', 'coremark/core_state.c', 'coremark/core_util.c'],
> > + defines = [
> > + # FLAGS_STR is used within CoreMark to print the compiler flags used
> > + 'FLAGS_STR="'+' '.join([str(flag) for flag in bld.env.CFLAGS])+'"'
> > diff --git a/benchmarks/wscript b/benchmarks/wscript
> > index 12741e7..24db85b 100644
> > --- a/benchmarks/wscript
> > +++ b/benchmarks/wscript
> > @@ -1,3 +1,4 @@
> > +# Copyright 2020 Hesham Almatary (hesham.almatary at cl.cam.ac.uk)
> > # Copyright 2013 Gedare Bloom (gedare at rtems.org)
> > # This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
> > @@ -7,4 +8,5 @@ import rtems_waf.rtems as rtems
> > def build(bld):
> > bld.recurse('nbench')
> > + bld.recurse('coremark')
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
