RTEMS-BSP testing
John kongtcheu
johnkongtcheu at gmail.com
Sun Feb 23 09:47:59 UTC 2020
Hello New Guy Here,
I was going through the Gsoc getting started page and I got a bit stuck on
the Test a Board Support Package section.I went through the steps provided
prior to this. However, when I ran the command
cd $HOME/quick-start/build/b-erc32
rtems-test --rtems-bsp=erc32-sis --rtems-tools=$HOME/quick-start/rtems/5 .
I received the message
RTEMS Testing - Tester, 5.0.not_released
Command Line: /home/kingkong/Coding-Projects/rtems/5/bin/rtems-test
--rtems-bsp=sis-run
--rtems-tools=/home/kingkong/Coding-Projects/rtems/5
Host: Linux kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic
#30~18.04.1-Ubuntu SMP Fri Jan 17 06:14:09 UTC 2020 x86_64
Python: 3.6.9 (default, Nov 7 2019, 10:44:02) [GCC 8.3.0]
Host: Linux-5.3.0-28-generic-x86_64-with-Ubuntu-18.04-bionic (Linux
kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic #30~18.04.1-Ubuntu SMP
Fri Jan 17 06:14:09 UTC 2020 x86_64 x86_64)
error: no executables supplied
I looked online and the only similar error I ran across was someone
who didn't run the make correctly , so I double checked running both
make && make install and I still received the same error.
I'm positive it has something to do with my development setup. If
anyone could point me in the right direction regarding this it would
be greatly appreciated.
Thank you,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200223/8e6e052c/attachment.html>
