RTEMS-BSP testing
Anmol Mishra
anmol.j2020 at gmail.com
Sun Feb 23 16:03:30 UTC 2020
Hey, I also witnessed this, My host was Ubuntu as well, I was trying out
Hello world task using sis. Considering myself naive and new to this, I am
trying to look into this as well.
Thank You
On Sun, Feb 23, 2020 at 9:23 PM John kongtcheu <johnkongtcheu at gmail.com>
wrote:
> Hello again,
> DIfferent problem though it's more minor. I was running the test files and
> at the end of them I always got this message
> *** FATAL ***
> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> RTEMS version: 5.0.0.486829b2766119275f74e7a2a11d7bf3a9561f54
> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (22135c9a7612), Newlib
> d14714c69)
> executing thread ID: 0x08a010001
> executing thread name: UI1
> cpu 0 in error mode (tt = 0x101)
> 113807 0200a080: 91d02000 ta 0x0
> . Is this message normal, because I didn't see it in the other runs of
> this program. I still get the expected output otherwise , just with this
> appended.
> For context the command run was ,
> sparc-rtems5-sis ticker.exe
> run
> Thank you,
> On Sun, Feb 23, 2020 at 4:47 AM John kongtcheu <johnkongtcheu at gmail.com>
> wrote:
>> Hello New Guy Here,
>> I was going through the Gsoc getting started page and I got a bit stuck
>> on the Test a Board Support Package section.I went through the steps
>> provided prior to this. However, when I ran the command
>> cd $HOME/quick-start/build/b-erc32
>> rtems-test --rtems-bsp=erc32-sis --rtems-tools=$HOME/quick-start/rtems/5 .
>> I received the message
>> RTEMS Testing - Tester, 5.0.not_released
>> Command Line: /home/kingkong/Coding-Projects/rtems/5/bin/rtems-test --rtems-bsp=sis-run --rtems-tools=/home/kingkong/Coding-Projects/rtems/5
>> Host: Linux kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic #30~18.04.1-Ubuntu SMP Fri Jan 17 06:14:09 UTC 2020 x86_64
>> Python: 3.6.9 (default, Nov 7 2019, 10:44:02) [GCC 8.3.0]
>> Host: Linux-5.3.0-28-generic-x86_64-with-Ubuntu-18.04-bionic (Linux kingkong-ThinkPad-X390-Yoga 5.3.0-28-generic #30~18.04.1-Ubuntu SMP Fri Jan 17 06:14:09 UTC 2020 x86_64 x86_64)
>> error: no executables supplied
>> I looked online and the only similar error I ran across was someone who didn't run the make correctly , so I double checked running both make && make install and I still received the same error.
>> I'm positive it has something to do with my development setup. If anyone could point me in the right direction regarding this it would be greatly appreciated.
>> Thank you,
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200223/ba6bea9b/attachment.html>
