[PATCH 2/2] c-user: rtems_scheduler_map_from_posix_priority()
Sebastian Huber
Tue Feb 25 07:05:37 UTC 2020
Close #3881.
c-user/scheduling_concepts.rst | 40 ++++++++++++++++++++++++++++++++++++++++
1 file changed, 40 insertions(+)
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index 4106d41..12316b7 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -40,6 +40,9 @@ The directives provided by the scheduler manager are:
- rtems_scheduler_map_to_posix_priority_ - Map task priority to POSIX thread
prority
+- rtems_scheduler_map_from_posix_priority_ - Map POSIX thread priority to task
+ prority
- rtems_scheduler_get_processor_ - Get current processor index
- rtems_scheduler_get_processor_maximum_ - Get processor maximum
@@ -741,6 +744,43 @@ NOTES:
\clearpage
+.. _rtems_scheduler_map_from_posix_priority:
+SCHEDULER_MAP_TO_POSIX_PRIORITY - Map POSIX thread prority to task priority
+CALLING SEQUENCE:
+ .. code-block:: c
+ rtems_status_code rtems_scheduler_map_from_posix_priority(
+ rtems_id scheduler_id,
+ int posix_priority,
+ rtems_task_priority *priority
+DIRECTIVE STATUS CODES:
+ .. list-table::
+ :class: rtems-table
+ * - ``RTEMS_SUCCESSFUL``
+ - Successful operation.
+ * - ``RTEMS_INVALID_ADDRESS``
+ - The ``priority`` parameter is ``NULL``.
+ * - ``RTEMS_INVALID_ID``
+ - Invalid scheduler instance identifier.
+ * - ``RTEMS_INVALID_PRIORITY``
+ - Invalid POSIX thread priority.
+DESCRIPTION:
+ Maps a POSIX thread priority to the corresponding task priority.
+NOTES:
+ None.
+.. raw:: latex
+ \clearpage
.. _rtems_scheduler_get_processor:
SCHEDULER_GET_PROCESSOR - Get current processor index
2.16.4
