[PATCH 1/2] c-user: rtems_scheduler_map_to_posix_priority()
Tue Feb 25 07:05:36 UTC 2020
Update #3881.
 c-user/scheduling_concepts.rst | 40 ++++++++++++++++++++++++++++++++++++++++
 1 file changed, 40 insertions(+)
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index 22d39e1..4106d41 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -37,6 +37,9 @@ The directives provided by the scheduler manager are:
 - rtems_scheduler_get_maximum_priority_ - Get maximum task priority of a scheduler
+- rtems_scheduler_map_to_posix_priority_ - Map task priority to POSIX thread
+  prority
 - rtems_scheduler_get_processor_ - Get current processor index
 - rtems_scheduler_get_processor_maximum_ - Get processor maximum
@@ -701,6 +704,43 @@ NOTES:
    \clearpage
+.. _rtems_scheduler_map_to_posix_priority:
+SCHEDULER_MAP_TO_POSIX_PRIORITY - Map task priority to POSIX thread prority
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_status_code rtems_scheduler_map_to_posix_priority(
+            rtems_id             scheduler_id,
+            rtems_task_priority  priority,
+            int                 *posix_priority
+DIRECTIVE STATUS CODES:
+    .. list-table::
+     :class: rtems-table
+     * - ``RTEMS_SUCCESSFUL``
+       - Successful operation.
+     * - ``RTEMS_INVALID_ADDRESS``
+       - The ``posix_priority`` parameter is ``NULL``.
+     * - ``RTEMS_INVALID_ID``
+       - Invalid scheduler instance identifier.
+     * - ``RTEMS_INVALID_PRIORITY``
+       - Invalid task priority.
+DESCRIPTION:
+    Maps a task priority to the corresponding POSIX thread priority.
+NOTES:
+    None.
+.. raw:: latex
+   \clearpage
 .. _rtems_scheduler_get_processor:
 SCHEDULER_GET_PROCESSOR - Get current processor index
2.16.4
