[PATCH] config: Initialize IO drivers on demand
Sebastian Huber
Tue Feb 25 13:19:43 UTC 2020
cpukit/Makefile.am | 1 +
cpukit/include/rtems/confdefs/iodrivers.h | 29 ++++++++++++++++++++
cpukit/sapi/src/exinit.c | 13 ---------
cpukit/sapi/src/iodefault.c | 45 +++++++++++++++++++++++++++++++
4 files changed, 75 insertions(+), 13 deletions(-)
create mode 100644 cpukit/sapi/src/iodefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 9ed260addb..298580e20d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1056,6 +1056,7 @@ librtemscpu_a_SOURCES += sapi/src/getconfigmax.c
librtemscpu_a_SOURCES += sapi/src/getversionstring.c
librtemscpu_a_SOURCES += sapi/src/interrtext.c
librtemscpu_a_SOURCES += sapi/src/io.c
+librtemscpu_a_SOURCES += sapi/src/iodefault.c
librtemscpu_a_SOURCES += sapi/src/ioclose.c
librtemscpu_a_SOURCES += sapi/src/iocontrol.c
librtemscpu_a_SOURCES += sapi/src/ioinitialize.c
diff --git a/cpukit/include/rtems/confdefs/iodrivers.h b/cpukit/include/rtems/confdefs/iodrivers.h
index 1e7b8c4e13..7ebe2ed474 100644
--- a/cpukit/include/rtems/confdefs/iodrivers.h
+++ b/cpukit/include/rtems/confdefs/iodrivers.h
@@ -42,7 +42,19 @@
#ifdef CONFIGURE_INIT
+#if defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) \
+ || defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) \
+ || CONFIGURE_MAXIMUM_DRIVERS > 0
#include <rtems/ioimpl.h>
+#include <rtems/sysinit.h>
#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
@@ -150,6 +162,12 @@ _IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
const size_t _IO_Number_of_drivers =
RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
+RTEMS_SYSINIT_ITEM(
+ _IO_Initialize_all_drivers,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
#ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY
@@ -163,6 +181,17 @@ const size_t _IO_Number_of_drivers =
#endif
+#endif /* CONFIGURE_APPLICATION_EXTRA_DRIVERS
+ || CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+ || CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+ || CONFIGURE_MAXIMUM_DRIVERS */
#endif /* CONFIGURE_INIT */
#endif /* _RTEMS_CONFDEFS_IODRIVERS_H */
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 196c9be576..e29b364806 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -22,7 +22,6 @@
#include <rtems/config.h>
#include <rtems/extensionimpl.h>
#include <rtems/init.h>
-#include <rtems/ioimpl.h>
#include <rtems/score/sysstate.h>
@@ -120,18 +119,6 @@ RTEMS_SYSINIT_ITEM(
-/* Initialize I/O drivers.
- * Driver Manager note:
- * All drivers may not be registered yet. Drivers will dynamically
- * be initialized when registered in level 2,3 and 4.
-RTEMS_SYSINIT_ITEM(
- _IO_Initialize_all_drivers,
- RTEMS_SYSINIT_DEVICE_DRIVERS,
- RTEMS_SYSINIT_ORDER_MIDDLE
void rtems_initialize_executive(void)
const rtems_sysinit_item *item;
diff --git a/cpukit/sapi/src/iodefault.c b/cpukit/sapi/src/iodefault.c
new file mode 100644
index 0000000000..114a419d19
--- /dev/null
+++ b/cpukit/sapi/src/iodefault.c
@@ -0,0 +1,45 @@
+ * @file
+ * @ingroup ClassicIO
+ * @brief This file contains definitions of IO drivers data structures for the
+ * default application configuration.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/ioimpl.h>
+rtems_driver_address_table _IO_Driver_address_table[ 0 ];
+const size_t _IO_Number_of_drivers = 0;
2.16.4
