Waf Build System Status in RTEMS?
Amar Takhar
amar at rtems.org
Wed Feb 26 03:02:06 UTC 2020
I've been working on setting up hardware testing in my lab at home. The Device
Tree documentation we have currently is horrible:
https://docs.rtems.org/branches/master/user/exe/device-tree.html
It's a list of command and descriptions about what it is but not what they do.
For instance look at section 8.8.1. The 'dtc' command? Where do I get it? I
have one on FreeBSD .. what if I'm running Linux is it the same 'dtc' command?
I have FreeBSD from 6 years ago will that work or what about the CURRENT machine
I have. There is no minimum version.
Also, I'm aware this command exists on Linux. except:
root at beer:~# dtc
bash: dtc: command not found
root at beer:~# apt-get install dtc
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package dtc
This on a Debian 10 machine.
So let me search for it:
root at beer:~# aptitude search dtc
p ddtc - Deal with ddts mails
p dtc-xen - SOAP daemon and scripts to allow contr
p dtc-xen-firewall - small firewall script for your dom0
p python-dtcwt - Dual-Tree Complex Wavelet Transform li
p python-dtcwt-doc - documentation for dtcwt
p python3-dtcwt - Dual-Tree Complex Wavelet Transform li
p sbox-dtc - CGI chroot wrapper script for safer ho
Nope, nothing, but of course *I* know what it is the documentation doesn't tell
me, though:
root at beer:~# aptitude search device|grep -i tree
p device-tree-compiler - Device Tree Compiler for Flat Device Trees
[install]
root at beer:~# dtc -v
Version: DTC 1.5.0
Finally.. but now I'm not so sure I'm there because on FreeBSD:
verm at peach# dtc -v
Version: dtc 0.5.0 compatible with gpl dtc 1.4.7
Are these really the same tool? Which one do I use? What version? How do I
even know that the output is correct do I just run the commands blindly and hope
it works?
FreeBSD is another story. It does have a package called 'dtc' which I had to
install to get 'fdtoverlay'...which is interesting because the 'dtc' command
exists in FreeBSD as part of the base:
root at peach# which dtc
/usr/bin/dtc
Yet there is no 'fdtoverlay'. I had to install the 'dtc' package -- a command I
already have mind you to get 'fdtoverlay'. Again these are things I know how to
find but a new user has no chance.. also:
root at peach# fdtoverlay -V
Version: DTC 1.4.7
It's not even 1.5.. and now I have two 'dtc' commands one in /usr/bin/dtc and
another in /usr/local/bin/dtc. Which one do I use and what version.
Amar.
