[PATCH] tester: Use prefix for rtems_tools by default
Wed Feb 26 06:25:58 UTC 2020
On 26/02/2020 04:58, Chris Johns wrote:
> On 25/2/20 7:33 pm, Sebastian Huber wrote:
>> Hello Chris,
>> On 14/02/2020 07:14, Sebastian Huber wrote:
>>> On 14/02/2020 03:54, Chris Johns wrote:
>>>> On 2020-02-12 17:27, Sebastian Huber wrote:
>>>>> Commit 72c684eff2cd932b4948e21902680a93473340c3 removed the default
>>>>> value of rtems_tools.  If the --rtems--tools option was omitted the
>>>>> rtems-test command printed lots of
>>>>>      error: run.cfg:61: macro '%{rtems_tools}' not found
>>>>> error messages.
>>>> I will need to think about this. I am wondering id removing the prefix code
>>>> allowed the PATH to be used.
>>> I have rtems-test in the $PATH and calling it without --rtems-tools doesn't
>>> work without this patch.
>> could you please have a look at this. Since the %{rtems_tools} macros needed it
>> should be defined:
>> grep -r rtems_tools --include '*.cfg'
>> tester/rtems/testing/gdb.cfg:%define gdb_cmd
>> %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-gdb
> Please push this change. I thought I had responded but something must have gone
> wrong. I am sorry about that.
No problem, my last statement from you was "I will need to think about
this.".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
