error in libtests dl06
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Feb 26 09:06:45 UTC 2020
Hello
I was installing riscv from the latest rtems git
and make install showed error
this error was not before and is probably due to some merged patch
Makefile:8571: recipe for target 'dl06.pre' failed
make[5]: *** [dl06.pre] Error 1
make[5]: Leaving directory
'/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/libtests'
Makefile:663: recipe for target 'libtests' failed
make[4]: *** [libtests] Error 2
make[4]: Leaving directory
'/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites'
Makefile:1222: recipe for target 'testsuites' failed
make[3]: *** [testsuites] Error 2
make[3]: Leaving directory
'/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac'
Makefile:716: recipe for target 'install-recursive' failed
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory
Makefile:289: recipe for target 'install-recursive' failed
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
'/home/eshan/development/rtems/kernel/rv32imac/riscv-rtems5/c'
Makefile:410: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200226/6f0e37c4/attachment.html>
