[PATCH 4/5] c-user: Merge parition term definitions
Sebastian Huber
Thu Feb 27 12:17:14 UTC 2020
Update #3853.
c-user/glossary.rst | 10 ++++++----
1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 3f53634..9b9c3c0 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -419,11 +419,13 @@ Glossary
multiprocessor system. A packet is the contents of an envelope.
partition
- An RTEMS object which is used to allocate and deallocate fixed size
- blocks of memory from an dynamically specified area of memory.
+ This term has two definitions:
- partition
- Clusters with a cardinality of one are partitions.
+ 1. A partition is an RTEMS object which is used to allocate and
+ deallocate fixed size blocks of memory from an dynamically specified
+ area of memory.
+ 2. A :term:`cluster` with a cardinality of one is a partition.
Partition Control Block
A data structure associated with each partition used by RTEMS to manage
2.16.4
