[PATCH 1/5] c-user: Use four spaces per indent level
Thu Feb 27 12:17:11 UTC 2020
Four spaces per indent level is used in most files.
Update #3853.
 c-user/glossary.rst | 1284 +++++++++++++++++++++++++--------------------------
 1 file changed, 642 insertions(+), 642 deletions(-)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index a230d6c..67dce76 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -4,777 +4,777 @@ Glossary
 .. glossary::
-   :sorted:
+    :sorted:
-   active
-      A term used to describe an object which has been created by an
-      application.
+    active
+        A term used to describe an object which has been created by an
+        application.
-   aperiodic task
-      A task which must execute only at irregular intervals and has only a soft
-      deadline.
+    aperiodic task
+        A task which must execute only at irregular intervals and has only a soft
+        deadline.
-   API
-      An acronym for Application Programming Interface.
+    API
+        An acronym for Application Programming Interface.
-   application
-      In this document, software which makes use of RTEMS.
+    application
+        In this document, software which makes use of RTEMS.
-   ASR
-      An acronym for :term:`Asynchronous Signal Routine`.
+    ASR
+        An acronym for :term:`Asynchronous Signal Routine`.
-   asynchronous
-      Not related in order or timing to other occurrences in the system.
+    asynchronous
+        Not related in order or timing to other occurrences in the system.
-   Asynchronous Signal Routine
-      Similar to a hardware interrupt except that it is associated with a task
-      and is run in the context of a task.  The directives provided by the
-      signal manager are used to service signals.
+    Asynchronous Signal Routine
+        Similar to a hardware interrupt except that it is associated with a task
+        and is run in the context of a task.  The directives provided by the
+        signal manager are used to service signals.
-   atomic operations
-      Atomic operations are defined in terms of :term:`C11`.
+    atomic operations
+        Atomic operations are defined in terms of :term:`C11`.
-   awakened
-      A term used to describe a task that has been unblocked and may be
-      scheduled to the CPU.
+    awakened
+        A term used to describe a task that has been unblocked and may be
+        scheduled to the CPU.
-   big endian
-      A data representation scheme in which the bytes composing a numeric value
-      are arranged such that the most significant byte is at the lowest
-      address.
+    big endian
+        A data representation scheme in which the bytes composing a numeric value
+        are arranged such that the most significant byte is at the lowest
+        address.
-   bit-mapped
-      A data encoding scheme in which each bit in a variable is used to
-      represent something different.  This makes for compact data
-      representation.
+    bit-mapped
+        A data encoding scheme in which each bit in a variable is used to
+        represent something different.  This makes for compact data
+        representation.
-   block
-      A physically contiguous area of memory.
+    block
+        A physically contiguous area of memory.
-   blocked task
-      The task state entered by a task which has been previously started and
-      cannot continue execution until the reason for waiting has been
-      satisfied.  Blocked tasks are not an element of the set of ready tasks of
-      a scheduler instance.
+    blocked task
+        The task state entered by a task which has been previously started and
+        cannot continue execution until the reason for waiting has been
+        satisfied.  Blocked tasks are not an element of the set of ready tasks of
+        a scheduler instance.
-   broadcast
-      To simultaneously send a message to a logical set of destinations.
+    broadcast
+        To simultaneously send a message to a logical set of destinations.
-   Board Support Package
-      A collection of device initialization and control routines specific to a
-      particular type of board or collection of boards.
+    Board Support Package
+        A collection of device initialization and control routines specific to a
+        particular type of board or collection of boards.
-   buffer
-      A fixed length block of memory allocated from a partition.
+    buffer
+        A fixed length block of memory allocated from a partition.
-   BSP
-      An acronym for :term:`Board Support Package`.
+    BSP
+        An acronym for :term:`Board Support Package`.
-   C11
-      The standard ISO/IEC 9899:2011.
+    C11
+        The standard ISO/IEC 9899:2011.
-   C++11
-      The standard ISO/IEC 14882:2011.
+    C++11
+        The standard ISO/IEC 14882:2011.
-   calling convention
-      The processor and compiler dependent rules which define the mechanism
-      used to invoke subroutines in a high-level language.  These rules define
-      the passing of arguments, the call and return mechanism, and the register
-      set which must be preserved.
+    calling convention
+        The processor and compiler dependent rules which define the mechanism
+        used to invoke subroutines in a high-level language.  These rules define
+        the passing of arguments, the call and return mechanism, and the register
+        set which must be preserved.
-   Central Processing Unit
-      This term is equivalent to the terms processor and microprocessor.
+    Central Processing Unit
+        This term is equivalent to the terms processor and microprocessor.
-   chain
-      A data structure which allows for efficient dynamic addition and removal
-      of elements.  It differs from an array in that it is not limited to a
-      predefined size.
+    chain
+        A data structure which allows for efficient dynamic addition and removal
+        of elements.  It differs from an array in that it is not limited to a
+        predefined size.
-   cluster
-      We have clustered scheduling in case the set of processors of a system is
-      partitioned into non-empty pairwise disjoint subsets.  These subsets are
-      called clusters.  Clusters with a cardinality of one are partitions.
-      Each cluster is owned by exactly one scheduler instance.
+    cluster
+        We have clustered scheduling in case the set of processors of a system is
+        partitioned into non-empty pairwise disjoint subsets.  These subsets are
+        called clusters.  Clusters with a cardinality of one are partitions.
+        Each cluster is owned by exactly one scheduler instance.
-   coalesce
-      The process of merging adjacent holes into a single larger hole.
-      Sometimes this process is referred to as garbage collection.
+    coalesce
+        The process of merging adjacent holes into a single larger hole.
+        Sometimes this process is referred to as garbage collection.
-   Configuration Table
-      A table which contains information used to tailor RTEMS for a particular
-      application.
+    Configuration Table
+        A table which contains information used to tailor RTEMS for a particular
+        application.
-   context
-      All of the processor registers and operating system data structures
-      associated with a task.
+    context
+        All of the processor registers and operating system data structures
+        associated with a task.
-   context switch
-      Alternate term for task switch.  Taking control of the processor from one
-      task and transferring it to another task.
+    context switch
+        Alternate term for task switch.  Taking control of the processor from one
+        task and transferring it to another task.
-   control block
-      A data structure used by the executive to define and control an object.
+    control block
+        A data structure used by the executive to define and control an object.
-   core
-      When used in this manual, this term refers to the internal executive
-      utility functions.  In the interest of application portability, the core
-      of the executive should not be used directly by applications.
+    core
+        When used in this manual, this term refers to the internal executive
+        utility functions.  In the interest of application portability, the core
+        of the executive should not be used directly by applications.
-   CPU
-      An acronym for :term:`Central Processing Unit`.
+    CPU
+        An acronym for :term:`Central Processing Unit`.
-   critical section
-      A section of code which must be executed indivisibly.
+    critical section
+        A section of code which must be executed indivisibly.
-   CRT
-      An acronym for Cathode Ray Tube.  Normally used in reference to the
-      man-machine interface.
-   deadline
-      A fixed time limit by which a task must have completed a set of actions.
-      Beyond this point, the results are of reduced value and may even be
-      considered useless or harmful.
-   device
-      A peripheral used by the application that requires special operation
-      software.  See also device driver.
-   device driver
-      Control software for special peripheral devices used by the application.
-   directives
-      RTEMS' provided routines that provide support mechanisms for real-time
-      applications.
-   dispatch
-      The act of loading a task's context onto the CPU and transferring control
-      of the CPU to that task.
-   dormant
-      The state entered by a task after it is created and before it has been
-      started.
-   Device Driver Table
-      A table which contains the entry points for each of the configured device
-      drivers.
-   dual-ported
-      A term used to describe memory which can be accessed at two different
-      addresses.
-   embedded
-      An application that is delivered as a hidden part of a larger system.
-      For example, the software in a fuel-injection control system is an
-      embedded application found in many late-model automobiles.
+    CRT
+        An acronym for Cathode Ray Tube.  Normally used in reference to the
+        man-machine interface.
+    deadline
+        A fixed time limit by which a task must have completed a set of actions.
+        Beyond this point, the results are of reduced value and may even be
+        considered useless or harmful.
+    device
+        A peripheral used by the application that requires special operation
+        software.  See also device driver.
+    device driver
+        Control software for special peripheral devices used by the application.
+    directives
+        RTEMS' provided routines that provide support mechanisms for real-time
+        applications.
+    dispatch
+        The act of loading a task's context onto the CPU and transferring control
+        of the CPU to that task.
+    dormant
+        The state entered by a task after it is created and before it has been
+        started.
+    Device Driver Table
+        A table which contains the entry points for each of the configured device
+        drivers.
+    dual-ported
+        A term used to describe memory which can be accessed at two different
+        addresses.
+    embedded
+        An application that is delivered as a hidden part of a larger system.
+        For example, the software in a fuel-injection control system is an
+        embedded application found in many late-model automobiles.
-   envelope
-      A buffer provided by the MPCI layer to RTEMS which is used to pass
-      messages between nodes in a multiprocessor system.  It typically contains
-      routing information needed by the MPCI.  The contents of an envelope are
-      referred to as a packet.
-   entry point
-      The address at which a function or task begins to execute.  In C, the
-      entry point of a function is the function's name.
-   events
-      A method for task communication and synchronization. The directives
-      provided by the event manager are used to service events.
+    envelope
+        A buffer provided by the MPCI layer to RTEMS which is used to pass
+        messages between nodes in a multiprocessor system.  It typically contains
+        routing information needed by the MPCI.  The contents of an envelope are
+        referred to as a packet.
+    entry point
+        The address at which a function or task begins to execute.  In C, the
+        entry point of a function is the function's name.
+    events
+        A method for task communication and synchronization. The directives
+        provided by the event manager are used to service events.
-   exception
-      A synonym for interrupt.
+    exception
+        A synonym for interrupt.
-   executing task
-      The task state entered by a task after it has been given control of the
-      processor.  In SMP configurations, a task may be registered as executing
-      on more than one processor for short time frames during task migration.
-      Blocked tasks can be executing until they issue a thread dispatch.
+    executing task
+        The task state entered by a task after it has been given control of the
+        processor.  In SMP configurations, a task may be registered as executing
+        on more than one processor for short time frames during task migration.
+        Blocked tasks can be executing until they issue a thread dispatch.
-   executive
-      In this document, this term is used to referred to RTEMS.  Commonly, an
-      executive is a small real-time operating system used in embedded systems.
+    executive
+        In this document, this term is used to referred to RTEMS.  Commonly, an
+        executive is a small real-time operating system used in embedded systems.
-   exported
-      An object known by all nodes in a multiprocessor system.  An object
-      created with the GLOBAL attribute will be exported.
+    exported
+        An object known by all nodes in a multiprocessor system.  An object
+        created with the GLOBAL attribute will be exported.
-   external address
-      The address used to access dual-ported memory by all the nodes in a
-      system which do not own the memory.
+    external address
+        The address used to access dual-ported memory by all the nodes in a
+        system which do not own the memory.
-   FIFO
-      An acronym for :term:`First In First Out`.
-   First In First Out
-      A discipline for manipulating entries in a data structure.
+    FIFO
+        An acronym for :term:`First In First Out`.
+    First In First Out
+        A discipline for manipulating entries in a data structure.
-   floating point coprocessor
-      A component used in computer systems to enhance performance in
-      mathematically intensive situations.  It is typically viewed as a logical
-      extension of the primary processor.
+    floating point coprocessor
+        A component used in computer systems to enhance performance in
+        mathematically intensive situations.  It is typically viewed as a logical
+        extension of the primary processor.
-   freed
-      A resource that has been released by the application to RTEMS.
-   global
-      An object that has been created with the GLOBAL attribute and exported to
-      all nodes in a multiprocessor system.
+    freed
+        A resource that has been released by the application to RTEMS.
+    global
+        An object that has been created with the GLOBAL attribute and exported to
+        all nodes in a multiprocessor system.
-   handler
-      The equivalent of a manager, except that it is internal to RTEMS and
-      forms part of the core.  A handler is a collection of routines which
-      provide a related set of functions.  For example, there is a handler used
-      by RTEMS to manage all objects.
+    handler
+        The equivalent of a manager, except that it is internal to RTEMS and
+        forms part of the core.  A handler is a collection of routines which
+        provide a related set of functions.  For example, there is a handler used
+        by RTEMS to manage all objects.
-   hard real-time system
-      A real-time system in which a missed deadline causes the worked performed
-      to have no value or to result in a catastrophic effect on the integrity
-      of the system.
+    hard real-time system
+        A real-time system in which a missed deadline causes the worked performed
+        to have no value or to result in a catastrophic effect on the integrity
+        of the system.
-   heap
-      A data structure used to dynamically allocate and deallocate variable
-      sized blocks of memory.
+    heap
+        A data structure used to dynamically allocate and deallocate variable
+        sized blocks of memory.
-   heir task
-      A task is an heir if it is registered as an heir in a processor of the
-      system.  A task can be the heir on at most one processor in the system.
-      In case the executing and heir tasks differ on a processor and a thread
-      dispatch is marked as necessary, then the next thread dispatch will make
-      the heir task the executing task.
+    heir task
+        A task is an heir if it is registered as an heir in a processor of the
+        system.  A task can be the heir on at most one processor in the system.
+        In case the executing and heir tasks differ on a processor and a thread
+        dispatch is marked as necessary, then the next thread dispatch will make
+        the heir task the executing task.
-   heterogeneous
-      A multiprocessor computer system composed of dissimilar processors.
+    heterogeneous
+        A multiprocessor computer system composed of dissimilar processors.
-   homogeneous
-      A multiprocessor computer system composed of a single type of processor.
+    homogeneous
+        A multiprocessor computer system composed of a single type of processor.
-   ID
-      An RTEMS assigned identification tag used to access an active object.
+    ID
+        An RTEMS assigned identification tag used to access an active object.
-   IDLE task
-      A special low priority task which assumes control of the CPU when no
-      other task is able to execute.
+    IDLE task
+        A special low priority task which assumes control of the CPU when no
+        other task is able to execute.
-   interface
-      A specification of the methodology used to connect multiple independent
-      subsystems.
+    interface
+        A specification of the methodology used to connect multiple independent
+        subsystems.
-   internal address
-      The address used to access dual-ported memory by the node which owns the
-      memory.
+    internal address
+        The address used to access dual-ported memory by the node which owns the
+        memory.
-   interrupt
-      A hardware facility that causes the CPU to suspend execution, save its
-      status, and transfer control to a specific location.
+    interrupt
+        A hardware facility that causes the CPU to suspend execution, save its
+        status, and transfer control to a specific location.
-   interrupt level
-      A mask used to by the CPU to determine which pending interrupts should be
-      serviced.  If a pending interrupt is below the current interrupt level,
-      then the CPU does not recognize that interrupt.
+    interrupt level
+        A mask used to by the CPU to determine which pending interrupts should be
+        serviced.  If a pending interrupt is below the current interrupt level,
+        then the CPU does not recognize that interrupt.
-   Interrupt Service Routine
-      An ISR is invoked by the CPU to process a pending interrupt.
+    Interrupt Service Routine
+        An ISR is invoked by the CPU to process a pending interrupt.
-   I/O
-      An acronym for Input/Output.
+    I/O
+        An acronym for Input/Output.
-   ISR
-      An acronym for :term:`Interrupt Service Routine`.
+    ISR
+        An acronym for :term:`Interrupt Service Routine`.
-   kernel
-      In this document, this term is used as a synonym for executive.
+    kernel
+        In this document, this term is used as a synonym for executive.
-   list
-      A data structure which allows for dynamic addition and removal of
-      entries.  It is not statically limited to a particular size.
+    list
+        A data structure which allows for dynamic addition and removal of
+        entries.  It is not statically limited to a particular size.
-   little endian
-      are arranged such that the least significant byte is at the lowest
-      address.
+    little endian
+        are arranged such that the least significant byte is at the lowest
+        address.
-   local
-      An object which was created with the LOCAL attribute and is accessible
-      only on the node it was created and resides upon.  In a single processor
-      configuration, all objects are local.
+    local
+        An object which was created with the LOCAL attribute and is accessible
+        only on the node it was created and resides upon.  In a single processor
+        configuration, all objects are local.
-   local operation
-      The manipulation of an object which resides on the same node as the
-      calling task.
+    local operation
+        The manipulation of an object which resides on the same node as the
+        calling task.
-   logical address
-      An address used by an application.  In a system without memory
-      management, logical addresses will equal physical addresses.
+    logical address
+        An address used by an application.  In a system without memory
+        management, logical addresses will equal physical addresses.
-   loosely-coupled
-      A multiprocessor configuration where shared memory is not used for
-      communication.
+    loosely-coupled
+        A multiprocessor configuration where shared memory is not used for
+        communication.
-   major number
-      The index of a device driver in the Device Driver Table.
+    major number
+        The index of a device driver in the Device Driver Table.
-   manager
-      A group of related RTEMS' directives which provide access and control
-      over resources.
+    manager
+        A group of related RTEMS' directives which provide access and control
+        over resources.
-   MCS
-      An acronym for Mellor-Crummey Scott.
+    MCS
+        An acronym for Mellor-Crummey Scott.
-   memory pool
-      Used interchangeably with heap.
+    memory pool
+        Used interchangeably with heap.
-   message
-      A sixteen byte entity used to communicate between tasks.  Messages are
-      sent to message queues and stored in message buffers.
+    message
+        A sixteen byte entity used to communicate between tasks.  Messages are
+        sent to message queues and stored in message buffers.
-   message buffer
-      A block of memory used to store messages.
+    message buffer
+        A block of memory used to store messages.
-   message queue
-      An RTEMS object used to synchronize and communicate between tasks by
-      transporting messages between sending and receiving tasks.
+    message queue
+        An RTEMS object used to synchronize and communicate between tasks by
+        transporting messages between sending and receiving tasks.
-   Message Queue Control Block
-      A data structure associated with each message queue used by RTEMS to
-      manage that message queue.
+    Message Queue Control Block
+        A data structure associated with each message queue used by RTEMS to
+        manage that message queue.
-   minor number
-      A numeric value passed to a device driver, the exact usage of which is
-      driver dependent.
+    minor number
+        A numeric value passed to a device driver, the exact usage of which is
+        driver dependent.
-   mode
-      An entry in a task's control block that is used to determine if the task
-      allows preemption, timeslicing, processing of signals, and the interrupt
-      disable level used by the task.
+    mode
+        An entry in a task's control block that is used to determine if the task
+        allows preemption, timeslicing, processing of signals, and the interrupt
+        disable level used by the task.
-   MPCI
-      An acronym for :term:`Multiprocessor Communications Interface Layer`.
+    MPCI
+        An acronym for :term:`Multiprocessor Communications Interface Layer`.
-   multiprocessing
-      The simultaneous execution of two or more processes by a multiple
-      processor computer system.
+    multiprocessing
+        The simultaneous execution of two or more processes by a multiple
+        processor computer system.
-   multiprocessor
-      A computer with multiple CPUs available for executing applications.
+    multiprocessor
+        A computer with multiple CPUs available for executing applications.
-   Multiprocessor Communications Interface Layer
-      A set of user-provided routines which enable the nodes in a
-      multiprocessor system to communicate with one another.
+    Multiprocessor Communications Interface Layer
+        A set of user-provided routines which enable the nodes in a
+        multiprocessor system to communicate with one another.
-   Multiprocessor Configuration Table
-      The data structure defining the characteristics of the multiprocessor
-      target system with which RTEMS will communicate.
+    Multiprocessor Configuration Table
+        The data structure defining the characteristics of the multiprocessor
+        target system with which RTEMS will communicate.
-   multitasking
-      The alternation of execution amongst a group of processes on a single
-      CPU.  A scheduling algorithm is used to determine which process executes
-      at which time.
+    multitasking
+        The alternation of execution amongst a group of processes on a single
+        CPU.  A scheduling algorithm is used to determine which process executes
+        at which time.
-   mutual exclusion
-      A term used to describe the act of preventing other tasks from accessing
-      a resource simultaneously.
+    mutual exclusion
+        A term used to describe the act of preventing other tasks from accessing
+        a resource simultaneously.
-   nested
-      A term used to describe an ASR that occurs during another ASR or an ISR
-      that occurs during another ISR.
+    nested
+        A term used to describe an ASR that occurs during another ASR or an ISR
+        that occurs during another ISR.
-   node
-      A term used to reference a processor running RTEMS in a multiprocessor
-      system.
+    node
+        A term used to reference a processor running RTEMS in a multiprocessor
+        system.
-   non-existent
-      The state occupied by an uncreated or deleted task.
-   NUMA
-      An acronym for Non-Uniform Memory Access.
+    non-existent
+        The state occupied by an uncreated or deleted task.
+    NUMA
+        An acronym for Non-Uniform Memory Access.
-   numeric coprocessor
+    numeric coprocessor
-   object
-      In this document, this term is used to refer collectively to tasks,
-      timers, message queues, partitions, regions, semaphores, ports, and rate
-      monotonic periods.  All RTEMS objects have IDs and user-assigned names.
+    object
+        In this document, this term is used to refer collectively to tasks,
+        timers, message queues, partitions, regions, semaphores, ports, and rate
+        monotonic periods.  All RTEMS objects have IDs and user-assigned names.
-   object-oriented
-      A term used to describe systems with common mechanisms for utilizing a
-      variety of entities.  Object-oriented systems shield the application from
-      implementation details.
+    object-oriented
+        A term used to describe systems with common mechanisms for utilizing a
+        variety of entities.  Object-oriented systems shield the application from
+        implementation details.
-   operating system
-      The software which controls all the computer's resources and provides the
-      base upon which application programs can be written.
+    operating system
+        The software which controls all the computer's resources and provides the
+        base upon which application programs can be written.
-   overhead
-      The portion of the CPUs processing power consumed by the operating
-      system.
+    overhead
+        The portion of the CPUs processing power consumed by the operating
+        system.
-   packet
-      A buffer which contains the messages passed between nodes in a
-      multiprocessor system.  A packet is the contents of an envelope.
+    packet
+        A buffer which contains the messages passed between nodes in a
+        multiprocessor system.  A packet is the contents of an envelope.
-   partition
-      An RTEMS object which is used to allocate and deallocate fixed size
-      blocks of memory from an dynamically specified area of memory.
+    partition
+        An RTEMS object which is used to allocate and deallocate fixed size
+        blocks of memory from an dynamically specified area of memory.
-   partition
-      Clusters with a cardinality of one are partitions.
+    partition
+        Clusters with a cardinality of one are partitions.
-   Partition Control Block
-      A data structure associated with each partition used by RTEMS to manage
-      that partition.
+    Partition Control Block
+        A data structure associated with each partition used by RTEMS to manage
+        that partition.
-   pending
-      A term used to describe a task blocked waiting for an event, message,
-      semaphore, or signal.
+    pending
+        A term used to describe a task blocked waiting for an event, message,
+        semaphore, or signal.
-   periodic task
-      A task which must execute at regular intervals and comply with a hard
-      deadline.
+    periodic task
+        A task which must execute at regular intervals and comply with a hard
+        deadline.
-   physical address
-      The actual hardware address of a resource.
+    physical address
+        The actual hardware address of a resource.
-   poll
-      A mechanism used to determine if an event has occurred by periodically
-      checking for a particular status.  Typical events include arrival of
-      data, completion of an action, and errors.
+    poll
+        A mechanism used to determine if an event has occurred by periodically
+        checking for a particular status.  Typical events include arrival of
+        data, completion of an action, and errors.
-   pool
-      A collection from which resources are allocated.
+    pool
+        A collection from which resources are allocated.
-   portability
-      A term used to describe the ease with which software can be rehosted on
-      another computer.
+    portability
+        A term used to describe the ease with which software can be rehosted on
+        another computer.
-   posting
-      The act of sending an event, message, semaphore, or signal to a task.
+    posting
+        The act of sending an event, message, semaphore, or signal to a task.
-   preempt
-      The act of forcing a task to relinquish the processor and dispatching to
-      another task.
+    preempt
+        The act of forcing a task to relinquish the processor and dispatching to
+        another task.
-   priority
-      A mechanism used to represent the relative importance of an element in a
-      set of items.  RTEMS uses priority to determine which task should
-      execute.
+    priority
+        A mechanism used to represent the relative importance of an element in a
+        set of items.  RTEMS uses priority to determine which task should
+        execute.
-   priority boosting
-      A simple approach to extend the priority inheritance protocol for
-      clustered scheduling is priority boosting.  In case a mutex is owned by a
-      task of another cluster, then the priority of the owner task is raised to
-      an artificially high priority, the pseudo-interrupt priority.
+    priority boosting
+        A simple approach to extend the priority inheritance protocol for
+        clustered scheduling is priority boosting.  In case a mutex is owned by a
+        task of another cluster, then the priority of the owner task is raised to
+        an artificially high priority, the pseudo-interrupt priority.
-   priority inheritance
-      An algorithm that calls for the lower priority task holding a resource to
-      have its priority increased to that of the highest priority task blocked
-      waiting for that resource.  This avoids the problem of priority
-      inversion.
+    priority inheritance
+        An algorithm that calls for the lower priority task holding a resource to
+        have its priority increased to that of the highest priority task blocked
+        waiting for that resource.  This avoids the problem of priority
+        inversion.
-   priority inversion
-      A form of indefinite postponement which occurs when a high priority tasks
-      requests access to shared resource currently allocated to low priority
-      task.  The high priority task must block until the low priority task
-      releases the resource.
+    priority inversion
+        A form of indefinite postponement which occurs when a high priority tasks
+        requests access to shared resource currently allocated to low priority
+        task.  The high priority task must block until the low priority task
+        releases the resource.
-   processor utilization
-      The percentage of processor time used by a task or a set of tasks.
+    processor utilization
+        The percentage of processor time used by a task or a set of tasks.
-   proxy
-      An RTEMS control structure used to represent, on a remote node, a task
-      which must block as part of a remote operation.
-   Proxy Control Block
-      A data structure associated with each proxy used by RTEMS to manage that
-      proxy.
-   PTCB
-      An acronym for :term:`Partition Control Block`.
-   PXCB
-      An acronym for :term:`Proxy Control Block`.
-   quantum
-      The application defined unit of time in which the processor is allocated.
-   queue
-      Alternate term for message queue.
-   QCB
-      An acronym for :term:`Message Queue Control Block`.
-   ready task
-      A task occupies this state when it is available to be given control of a
-      processor.  A ready task has no processor assigned.  The scheduler
-      decided that other tasks are currently more important.  A task that is
-      ready to execute and has a processor assigned is called scheduled.
+    proxy
+        An RTEMS control structure used to represent, on a remote node, a task
+        which must block as part of a remote operation.
+    Proxy Control Block
+        A data structure associated with each proxy used by RTEMS to manage that
+        proxy.
+    PTCB
+        An acronym for :term:`Partition Control Block`.
+    PXCB
+        An acronym for :term:`Proxy Control Block`.
+    quantum
+        The application defined unit of time in which the processor is allocated.
+    queue
+        Alternate term for message queue.
+    QCB
+        An acronym for :term:`Message Queue Control Block`.
+    ready task
+        A task occupies this state when it is available to be given control of a
+        processor.  A ready task has no processor assigned.  The scheduler
+        decided that other tasks are currently more important.  A task that is
+        ready to execute and has a processor assigned is called scheduled.
-   real-time
-      A term used to describe systems which are characterized by requiring
-      deterministic response times to external stimuli.  The external stimuli
-      require that the response occur at a precise time or the response is
-      incorrect.
-   reentrant
-      A term used to describe routines which do not modify themselves or global
-      variables.
-   region
-      An RTEMS object which is used to allocate and deallocate variable size
-      blocks of memory from a dynamically specified area of memory.
-   Region Control Block
-      A data structure associated with each region used by RTEMS to manage that
-      region.
-   registers
-      Registers are locations physically located within a component, typically
-      used for device control or general purpose storage.
-   remote
-      Any object that does not reside on the local node.
-   remote operation
-      The manipulation of an object which does not reside on the same node as
-      the calling task.
-   return code
-      Also known as error code or return value.
-   resource
-      A hardware or software entity to which access must be controlled.
-   resume
-      Removing a task from the suspend state.  If the task's state is ready
-      following a call to the ``rtems_task_resume`` directive, then the task is
-      available for scheduling.
-   return code
-      A value returned by RTEMS directives to indicate the completion status of
-      the directive.
-   RNCB
-      An acronym for :term:`Region Control Block`.
-   round-robin
-      A task scheduling discipline in which tasks of equal priority are
-      executed in the order in which they are made ready.
-   RS-232
-      A standard for serial communications.
-   running
-      The state of a rate monotonic timer while it is being used to delineate a
-      period.  The timer exits this state by either expiring or being canceled.
-   schedulable
-      A set of tasks which can be guaranteed to meet their deadlines based upon
-      a specific scheduling algorithm.
+    real-time
+        A term used to describe systems which are characterized by requiring
+        deterministic response times to external stimuli.  The external stimuli
+        require that the response occur at a precise time or the response is
+        incorrect.
+    reentrant
+        A term used to describe routines which do not modify themselves or global
+        variables.
+    region
+        An RTEMS object which is used to allocate and deallocate variable size
+        blocks of memory from a dynamically specified area of memory.
+    Region Control Block
+        A data structure associated with each region used by RTEMS to manage that
+        region.
+    registers
+        Registers are locations physically located within a component, typically
+        used for device control or general purpose storage.
+    remote
+        Any object that does not reside on the local node.
+    remote operation
+        The manipulation of an object which does not reside on the same node as
+        the calling task.
+    return code
+        Also known as error code or return value.
+    resource
+        A hardware or software entity to which access must be controlled.
+    resume
+        Removing a task from the suspend state.  If the task's state is ready
+        following a call to the ``rtems_task_resume`` directive, then the task is
+        available for scheduling.
+    return code
+        A value returned by RTEMS directives to indicate the completion status of
+        the directive.
+    RNCB
+        An acronym for :term:`Region Control Block`.
+    round-robin
+        A task scheduling discipline in which tasks of equal priority are
+        executed in the order in which they are made ready.
+    RS-232
+        A standard for serial communications.
+    running
+        The state of a rate monotonic timer while it is being used to delineate a
+        period.  The timer exits this state by either expiring or being canceled.
+    schedulable
+        A set of tasks which can be guaranteed to meet their deadlines based upon
+        a specific scheduling algorithm.
-   schedule
-      The process of choosing which task should next enter the executing state.
-   scheduled task
-      A task is scheduled if it is allowed to execute and has a processor
-      assigned.  Such a task executes currently on a processor or is about to
-      start execution.  A task about to start execution it is an heir task on
-      exactly one processor in the system.
-   scheduler
-      A scheduler or scheduling algorithm allocates processors to a subset of
-      its set of ready tasks.  So it manages access to the processor resource.
-      Various algorithms exist to choose the tasks allowed to use a processor
-      out of the set of ready tasks.  One method is to assign each task a
-      priority number and assign the tasks with the lowest priority number to
-      one processor of the set of processors owned by a scheduler instance.
+    schedule
+        The process of choosing which task should next enter the executing state.
+    scheduled task
+        A task is scheduled if it is allowed to execute and has a processor
+        assigned.  Such a task executes currently on a processor or is about to
+        start execution.  A task about to start execution it is an heir task on
+        exactly one processor in the system.
+    scheduler
+        A scheduler or scheduling algorithm allocates processors to a subset of
+        its set of ready tasks.  So it manages access to the processor resource.
+        Various algorithms exist to choose the tasks allowed to use a processor
+        out of the set of ready tasks.  One method is to assign each task a
+        priority number and assign the tasks with the lowest priority number to
+        one processor of the set of processors owned by a scheduler instance.
-   scheduler instance
-      A scheduler instance is a scheduling algorithm with a corresponding
-      context to store its internal state.  Each processor in the system is
-      owned by at most one scheduler instance.  The processor to scheduler
-      instance assignment is determined at application configuration time.  See
-      :ref:`Configuring a System`.
-   segments
-      Variable sized memory blocks allocated from a region.
-   semaphore
-      An RTEMS object which is used to synchronize tasks and provide mutually
-      exclusive access to resources.
-   Semaphore Control Block
-      A data structure associated with each semaphore used by RTEMS to manage
-      that semaphore.
-   shared memory
-      Memory which is accessible by multiple nodes in a multiprocessor system.
-   signal
-      An RTEMS provided mechanism to communicate asynchronously with a task.
-      Upon reception of a signal, the ASR of the receiving task will be
-      invoked.
-   signal set
-      A thirty-two bit entity which is used to represent a task's collection of
-      pending signals and the signals sent to a task.
-   SMCB
-      An acronym for :term:`Semaphore Control Block`.
-   SMP
-      An acronym for Symmetric Multiprocessing.
-   SMP locks
-      The SMP locks ensure mutual exclusion on the lowest level and are a
-      replacement for the sections of disabled interrupts.  Interrupts are
-      usually disabled while holding an SMP lock.  They are implemented using
-      atomic operations.  Currently a ticket lock is used in RTEMS.
-   SMP barriers
-      The SMP barriers ensure that a defined set of independent threads of
-      execution on a set of processors reaches a common synchronization point
-      in time.  They are implemented using atomic operations.  Currently a
-      sense barrier is used in RTEMS.
-   soft real-time system
-      A real-time system in which a missed deadline does not compromise the
-      integrity of the system.
-   sporadic task
-      A task which executes at irregular intervals and must comply with a hard
-      deadline.  A minimum period of time between successive iterations of the
-      task can be guaranteed.
-   stack
-      A data structure that is managed using a Last In First Out (LIFO)
-      discipline.  Each task has a stack associated with it which is used to
-      store return information and local variables.
-   status code
-   suspend
-      A term used to describe a task that is not competing for the CPU because it
-      has had a ``rtems_task_suspend`` directive.
-   synchronous
-      Related in order or timing to other occurrences in the system.
-   system call
-      In this document, this is used as an alternate term for directive.
-   target
-      The system on which the application will ultimately execute.
-   TAS
-      An acronym for Test-And-Set.
-   task
-      A logically complete thread of execution.  It consists normally of a set
-      of registers and a stack.  The scheduler assigns processors to a subset
-      of the ready tasks.  The terms task and thread are synonym in RTEMS.  The
-      term task is used throughout the Classic API, however, internally in the
-      operating system implementation and the POSIX API the term thread is
-      used.
-   Task Control Block
-      A data structure associated with each task used by RTEMS to manage that
-      task.
-   task migration
-      Task migration happens in case a task stops execution on one processor
-      and resumes execution on another processor.
-   task processor affinity
-      The set of processors on which a task is allowed to execute.
+    scheduler instance
+        A scheduler instance is a scheduling algorithm with a corresponding
+        context to store its internal state.  Each processor in the system is
+        owned by at most one scheduler instance.  The processor to scheduler
+        instance assignment is determined at application configuration time.  See
+        :ref:`Configuring a System`.
+    segments
+        Variable sized memory blocks allocated from a region.
+    semaphore
+        An RTEMS object which is used to synchronize tasks and provide mutually
+        exclusive access to resources.
+    Semaphore Control Block
+        A data structure associated with each semaphore used by RTEMS to manage
+        that semaphore.
+    shared memory
+        Memory which is accessible by multiple nodes in a multiprocessor system.
+    signal
+        An RTEMS provided mechanism to communicate asynchronously with a task.
+        Upon reception of a signal, the ASR of the receiving task will be
+        invoked.
+    signal set
+        A thirty-two bit entity which is used to represent a task's collection of
+        pending signals and the signals sent to a task.
+    SMCB
+        An acronym for :term:`Semaphore Control Block`.
+    SMP
+        An acronym for Symmetric Multiprocessing.
+    SMP locks
+        The SMP locks ensure mutual exclusion on the lowest level and are a
+        replacement for the sections of disabled interrupts.  Interrupts are
+        usually disabled while holding an SMP lock.  They are implemented using
+        atomic operations.  Currently a ticket lock is used in RTEMS.
+    SMP barriers
+        The SMP barriers ensure that a defined set of independent threads of
+        execution on a set of processors reaches a common synchronization point
+        in time.  They are implemented using atomic operations.  Currently a
+        sense barrier is used in RTEMS.
+    soft real-time system
+        A real-time system in which a missed deadline does not compromise the
+        integrity of the system.
+    sporadic task
+        A task which executes at irregular intervals and must comply with a hard
+        deadline.  A minimum period of time between successive iterations of the
+        task can be guaranteed.
+    stack
+        A data structure that is managed using a Last In First Out (LIFO)
+        discipline.  Each task has a stack associated with it which is used to
+        store return information and local variables.
+    status code
+    suspend
+        A term used to describe a task that is not competing for the CPU because it
+        has had a ``rtems_task_suspend`` directive.
+    synchronous
+        Related in order or timing to other occurrences in the system.
+    system call
+        In this document, this is used as an alternate term for directive.
+    target
+        The system on which the application will ultimately execute.
+    TAS
+        An acronym for Test-And-Set.
+    task
+        A logically complete thread of execution.  It consists normally of a set
+        of registers and a stack.  The scheduler assigns processors to a subset
+        of the ready tasks.  The terms task and thread are synonym in RTEMS.  The
+        term task is used throughout the Classic API, however, internally in the
+        operating system implementation and the POSIX API the term thread is
+        used.
+    Task Control Block
+        A data structure associated with each task used by RTEMS to manage that
+        task.
+    task migration
+        Task migration happens in case a task stops execution on one processor
+        and resumes execution on another processor.
+    task processor affinity
+        The set of processors on which a task is allowed to execute.
-   task switch
-      Alternate terminology for context switch.  Taking control of the
-      processor from one task and given to another.
+    task switch
+        Alternate terminology for context switch.  Taking control of the
+        processor from one task and given to another.
-   TCB
-      An acronym for :term:`Task Control Block`.
+    TCB
+        An acronym for :term:`Task Control Block`.
-   thread
-      This term has the same meaning as :term:`task`.
+    thread
+        This term has the same meaning as :term:`task`.
-   thread dispatch
-      The thread dispatch transfers control of the processor from the currently
-      executing thread to the heir thread of the processor.
+    thread dispatch
+        The thread dispatch transfers control of the processor from the currently
+        executing thread to the heir thread of the processor.
-   tick
-      The basic unit of time used by RTEMS.  It is a user-configurable number
-      of microseconds.  The current tick expires when a clock tick directive is
-      invoked.
+    tick
+        The basic unit of time used by RTEMS.  It is a user-configurable number
+        of microseconds.  The current tick expires when a clock tick directive is
+        invoked.
-   tightly-coupled
-      A multiprocessor configuration system which communicates via shared
-      memory.
+    tightly-coupled
+        A multiprocessor configuration system which communicates via shared
+        memory.
-   timeout
-      An argument provided to a number of directives which determines the
-      maximum length of time an application task is willing to wait to acquire
-      the resource if it is not immediately available.
+    timeout
+        An argument provided to a number of directives which determines the
+        maximum length of time an application task is willing to wait to acquire
+        the resource if it is not immediately available.
-   timer
-      An RTEMS object used to invoke subprograms at a later time.
+    timer
+        An RTEMS object used to invoke subprograms at a later time.
-   Timer Control Block
-      A data structure associated with each timer used by RTEMS to manage that
-      timer.
+    Timer Control Block
+        A data structure associated with each timer used by RTEMS to manage that
+        timer.
-   timeslicing
-      executed for a specific period of time before being preempted by another
-      task.
+    timeslicing
+        executed for a specific period of time before being preempted by another
+        task.
-   timeslice
+    timeslice
-   TLS
-      An acronym for Thread-Local Storage :cite:`Drepper:2013:TLS`.  TLS is
-      available in :term:`C11` and :term:`C++11`.  The support for TLS depends
-      on the CPU port :cite:`RTEMS:CPU`.
+    TLS
+        An acronym for Thread-Local Storage :cite:`Drepper:2013:TLS`.  TLS is
+        available in :term:`C11` and :term:`C++11`.  The support for TLS depends
+        on the CPU port :cite:`RTEMS:CPU`.
-   TMCB
-      An acronym for :term:`Timer Control Block`.
+    TMCB
+        An acronym for :term:`Timer Control Block`.
-   transient overload
-      A temporary rise in system activity which may cause deadlines to be
-      missed.  Rate Monotonic Scheduling can be used to determine if all
-      deadlines will be met under transient overload.
+    transient overload
+        A temporary rise in system activity which may cause deadlines to be
+        missed.  Rate Monotonic Scheduling can be used to determine if all
+        deadlines will be met under transient overload.
-   TTAS
-      An acronym for Test and Test-And-Set.
+    TTAS
+        An acronym for Test and Test-And-Set.
-   user extensions
-      Software routines provided by the application to enhance the
-      functionality of RTEMS.
+    user extensions
+        Software routines provided by the application to enhance the
+        functionality of RTEMS.
-   User Extension Table
-      A table which contains the entry points for each user extensions.
+    User Extension Table
+        A table which contains the entry points for each user extensions.
-   User Initialization Tasks Table
-      A table which contains the information needed to create and start each of
-      the user initialization tasks.
+    User Initialization Tasks Table
+        A table which contains the information needed to create and start each of
+        the user initialization tasks.
-   user-provided
-      These terms are used to designate any software routines which must be
-      written by the application designer.
+    user-provided
+        These terms are used to designate any software routines which must be
+        written by the application designer.
-   user-supplied
-      This term has the same meaning as :term:`user-provided`.
+    user-supplied
+        This term has the same meaning as :term:`user-provided`.
-   vector
-      Memory pointers used by the processor to fetch the address of routines
-      which will handle various exceptions and interrupts.
+    vector
+        Memory pointers used by the processor to fetch the address of routines
+        which will handle various exceptions and interrupts.
-   wait queue
-      The list of tasks blocked pending the release of a particular resource.
-      Message queues, regions, and semaphores have a wait queue associated with
-      them.
+    wait queue
+        The list of tasks blocked pending the release of a particular resource.
+        Message queues, regions, and semaphores have a wait queue associated with
+        them.
-   yield
-      When a task voluntarily releases control of the processor.
+    yield
+        When a task voluntarily releases control of the processor.
2.16.4
