Libbsd 5-freebsd-12 does not build for BBB
Chris Johns
chrisj at rtems.org
Fri Feb 28 05:23:41 UTC 2020
Hi,
Please find attached an error log for libbsd for the BBB.
RTEMS Tools Project - Source Builder Error Report
Build: error: building rtems-libbsd-ve562e3bdf33f5de01ede936d5621ab7de88f74d3-x86_64-freebsd11.2-1
Command Line: ../source-builder/sb-set-builder --prefix=/opt/work/rtems/5 --log=xilinx_zynq_zc706.txt --with-rtems-smp 5/bsps/xilinx_zynq_zc706
Python: 2.7.15 (default, Oct 2 2018, 01:21:44) [GCC 4.2.1 Compatible FreeBSD Clang 6.0.0 (tags/RELEASE_600/final 326565)]
git://git.rtems.org/rtems-source-builder.git/origin/25f1d894a30daf669302bbf7a7c26d0127fb4e07
FreeBSD kaka 11.2-RELEASE-p4 FreeBSD 11.2-RELEASE-p4 #0: Thu Sep 27 08:16:24 UTC 2018 root at amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC amd64
Tail of the build log:
[1506/1916] Compiling freebsd/sbin/nvmecontrol/devlist.c
[1507/1916] Compiling freebsd/sys/dev/mii/ukphy.c
[1508/1916] Compiling freebsd/sys/kern/init_main.c
[1509/1916] Compiling freebsd/sys/dev/usb/controller/usb_controller.c
[1510/1916] Compiling freebsd/sys/kern/kern_uuid.c
[1511/1916] Compiling rtemsbsd/sys/dev/atsam/if_atsam.c
[1512/1916] Compiling rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c
[1513/1916] Compiling mDNSResponder/mDNSShared/mDNSDebug.c
[1514/1916] Compiling rtemsbsd/local/usb_if.c
[1515/1916] Compiling freebsd/sys/kern/kern_module.c
[1516/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-stty.c
[1517/1916] Compiling freebsd/sys/dev/usb/usb_msctest.c
[1518/1916] Compiling freebsd/sys/dev/usb/usb_process.c
[1519/1916] Compiling freebsd/sys/dev/usb/usb_busdma.c
[1520/1916] Compiling freebsd/sys/dev/usb/usb_debug.c
[1521/1916] Compiling rtemsbsd/local/gpiobus_if.c
[1522/1916] Compiling rtemsbsd/local/mmcbus_if.c
[1523/1916] Compiling freebsd/sys/dev/usb/usb_dev.c
[1524/1916] Compiling freebsd/sys/dev/bce/if_bce.c
[1525/1916] Compiling freebsd/sbin/nvmecontrol/firmware.c
[1526/1916] Compiling freebsd/sys/kern/subr_sleepqueue.c
[1527/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-nvmecontrol.c
[1528/1916] Compiling freebsd/sys/dev/usb/serial/ubser.c
[1529/1916] Compiling rtemsbsd/local/ifdi_if.c
[1530/1916] Compiling freebsd/sys/dev/usb/quirk/usb_quirk.c
[1531/1916] Compiling freebsd/sys/dev/usb/serial/u3g.c
[1532/1916] Compiling freebsd/sys/dev/e1000/e1000_phy.c
[1533/1916] Compiling freebsd/sys/dev/usb/net/if_kue.c
[1534/1916] Compiling freebsd/sys/netinet/libalias/alias_util.c
[1535/1916] Compiling freebsd/sys/dev/usb/input/uhid.c
[1536/1916] Compiling freebsd/sys/dev/usb/controller/ohci.c
[1537/1916] Compiling freebsd/sys/dev/usb/controller/saf1761_otg.c
[1538/1916] Compiling rtemsbsd/rtems/rtems-kernel-mbuf.c
[1539/1916] Compiling freebsd/sys/netinet/ip_icmp.c
[1540/1916] Compiling freebsd/sys/dev/mii/e1000phy.c
[1541/1916] Compiling freebsd/sbin/nvmecontrol/sanitize.c
[1542/1916] Compiling freebsd/sys/opencrypto/skipjack.c
[1543/1916] Compiling mDNSResponder/mDNSCore/DNSDigest.c
[1544/1916] Compiling freebsd/sys/dev/usb/serial/umcs.c
[1545/1916] Compiling freebsd/sys/dev/fdt/fdt_common.c
[1546/1916] Compiling freebsd/sys/dev/mii/mii_fdt.c
[1547/1916] Compiling freebsd/sys/dev/mmc/mmc.c
[1548/1916] Compiling freebsd/sys/dev/e1000/e1000_82541.c
[1549/1916] Compiling freebsd/sys/dev/fxp/if_fxp.c
[1550/1916] Compiling freebsd/sys/dev/evdev/evdev_utils.c
[1551/1916] Compiling freebsd/sys/opencrypto/gmac.c
[1552/1916] Compiling rtemsbsd/pppd/upap.c
[1553/1916] Compiling rtemsbsd/sys/dev/input/touchscreen/tsc_lpc32xx.c
[1554/1916] Compiling freebsd/sys/dev/e1000/e1000_82543.c
[1555/1916] Compiling freebsd/sys/dev/e1000/e1000_82571.c
[1556/1916] Compiling freebsd/sys/dev/mmc/mmcsd.c
[1557/1916] Compiling freebsd/sys/dev/bfe/if_bfe.c
[1558/1916] Compiling rtemsbsd/pppd/chat.c
[1559/1916] Compiling freebsd/sys/crypto/rijndael/rijndael-api-fst.c
[1560/1916] Compiling freebsd/sys/crypto/blowfish/bf_enc.c
[1561/1916] Compiling freebsd/sys/fs/devfs/devfs_vnops.c
[1562/1916] Compiling rtemsbsd/pppd/demand.c
[1563/1916] Compiling freebsd/sys/arm/ti/am335x/am335x_prcm.c
[1564/1916] Compiling freebsd/sys/arm/ti/cpsw/if_cpsw.c
[1565/1916] Compiling rtemsbsd/rtems/rtems-kernel-sysctlbyname.c
[1566/1916] Compiling freebsd/sys/netinet/tcp_sack.c
[1567/1916] Compiling freebsd/sys/opencrypto/cast.c
[1568/1916] Compiling freebsd/sys/arm/ti/ti_hwmods.c
[1569/1916] Compiling freebsd/sys/netinet6/scope6.c
[1570/1916] Compiling freebsd/sys/netinet6/udp6_usrreq.c
[1571/1916] Compiling rtemsbsd/sys/dev/dw_mmc/dw_mmc.c
[1572/1916] Compiling freebsd/sys/kern/subr_firmware.c
[1573/1916] Compiling freebsd/sys/netpfil/pf/in4_cksum.c
[1574/1916] Compiling freebsd/sys/netinet6/nd6_rtr.c
[1575/1916] Compiling freebsd/sys/netinet6/dest6.c
[1576/1916] Compiling freebsd/sbin/nvmecontrol/nvmecontrol.c
[1577/1916] Compiling freebsd/sys/netinet6/ip6_id.c
[1578/1916] Compiling freebsd/sys/kern/subr_prf.c
[1579/1916] Compiling rtemsbsd/rtems/rtems-kernel-thread.c
[1580/1916] Compiling freebsd/sbin/nvmecontrol/format.c
[1581/1916] Compiling freebsd/sys/netinet6/frag6.c
[1582/1916] Compiling freebsd/sys/netinet/tcp_subr.c
[1583/1916] Compiling freebsd/sys/netinet6/in6_mcast.c
[1584/1916] Compiling freebsd/sys/dev/usb/serial/ulpt.c
[1585/1916] Compiling freebsd/sys/netinet6/in6_fib.c
[1586/1916] Compiling freebsd/sys/netinet/tcp_output.c
[1587/1916] Compiling freebsd/sys/netinet/tcp_usrreq.c
[1588/1916] Compiling rtemsbsd/rtems/rtems-kernel-mutex.c
[1589/1916] Compiling rtemsbsd/rtems/rtems-kernel-epoch.c
[1590/1916] Compiling rtemsbsd/rtems/rtems-kernel-delay.c
[1591/1916] Compiling freebsd/sys/net/bpf_buffer.c
[1592/1916] Compiling freebsd/sys/net/altq/altq_hfsc.c
[1593/1916] Compiling rtemsbsd/rtems/rtems-kernel-assert.c
[1594/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-ping.c
[1595/1916] Compiling freebsd/sys/net/altq/altq_fairq.c
[1596/1916] Compiling rtemsbsd/rtems/rtems-bsd-set-if-input.c
[1597/1916] Compiling rtemsbsd/rtems/rtems-bsd-get-task-stack-size.c
[1598/1916] Compiling rtemsbsd/rtems/rtems-bsd-get-task-priority.c
[1599/1916] Compiling freebsd/sys/kern/uipc_mbuf.c
[1600/1916] Compiling rtemsbsd/rtems/ofw_machdep.c
[1601/1916] Compiling rtemsbsd/pppd/magic.c
[1602/1916] Compiling freebsd/sys/kern/sys_pipe.c
[1603/1916] Compiling rtemsbsd/local/ofw_if.c
[1604/1916] Compiling rtemsbsd/mdns/mDNSResolveService.c
[1605/1916] Compiling rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver_dump.c
[1606/1916] Compiling rtemsbsd/pppd/ccp.c
[1607/1916] Compiling freebsd/sys/kern/kern_timeout.c
[1608/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-tcpdump.c
[1609/1916] Compiling rtemsbsd/local/mmcbr_if.c
[1610/1916] Compiling rtemsbsd/local/bus_if.c
[1611/1916] Compiling freebsd/sys/kern/kern_time.c
[1612/1916] Compiling mDNSResponder/mDNSCore/uDNS.c
[1613/1916] Compiling freebsd/sys/opencrypto/xform_poly1305.c
[1614/1916] Compiling rtemsbsd/sys/dev/nvd/nvd.c
[1615/1916] Compiling freebsd/sys/opencrypto/xform.c
[1616/1916] Compiling freebsd/sys/opencrypto/cryptodev.c
[1617/1916] Compiling freebsd/sys/netpfil/pf/pf_osfp.c
[1618/1916] Compiling freebsd/sys/dev/usb/usb_lookup.c
[1619/1916] Compiling freebsd/sys/netpfil/pf/if_pflog.c
[1620/1916] Compiling freebsd/sys/netinet6/nd6.c
[1621/1916] Compiling rtemsbsd/sys/arm/lpc/lpc_pwr.c
[1622/1916] Compiling freebsd/sys/dev/usb/serial/usb_serial.c
[1623/1916] Compiling freebsd/sys/dev/usb/serial/uipaq.c
[1624/1916] Compiling freebsd/sys/netinet6/in6_src.c
[1625/1916] Compiling freebsd/sys/netinet6/in6_cksum.c
[1626/1916] Compiling freebsd/sys/dev/usb/serial/ugensa.c
[1627/1916] Compiling freebsd/sys/netinet/tcp_timer.c
[1628/1916] Compiling freebsd/sys/netinet/tcp_input.c
[1629/1916] Compiling rtemsbsd/rtems/rtems-legacy-rtrequest.c
[1630/1916] Compiling freebsd/sys/dev/usb/net/if_mos.c
[1631/1916] Compiling freebsd/sys/netinet/sctp_asconf.c
[1632/1916] Compiling freebsd/sys/netinet/sctp_pcb.c
[1633/1916] Compiling freebsd/sys/dev/usb/input/wsp.c
[1634/1916] Compiling freebsd/sys/netinet/libalias/alias_nbt.c
[1635/1916] Compiling freebsd/sys/netinet/ip_reass.c
[1636/1916] Compiling freebsd/sys/netinet/ip_output.c
[1637/1916] Compiling freebsd/sys/opencrypto/gfmult.c
[1638/1916] Compiling freebsd/sys/dev/pci/pci_pci.c
[1639/1916] Compiling freebsd/sys/netinet/ip_options.c
[1640/1916] Compiling freebsd/sys/crypto/camellia/camellia.c
[1641/1916] Compiling freebsd/sys/dev/evdev/uinput.c
[1642/1916] Compiling freebsd/sys/netinet/ip_fastfwd.c
[1643/1916] Compiling freebsd/sys/netinet/in_mcast.c
[1644/1916] Compiling freebsd/sys/dev/pci/pci.c
[1645/1916] Compiling freebsd/sys/netinet/accf_http.c
[1646/1916] Compiling freebsd/sys/net/radix_mpath.c
[1647/1916] Compiling rtemsbsd/rtems/rtems-kernel-pci_bus.c
[1648/1916] Compiling freebsd/sys/dev/mmc/mmc_subr.c
[1649/1916] Compiling freebsd/sys/net/if_spppfr.c
[1650/1916] Compiling freebsd/sys/net/if_fwsubr.c
[1651/1916] Compiling freebsd/sys/dev/mii/mii.c
[1652/1916] Compiling freebsd/sys/net/if_bridge.c
[1653/1916] Compiling freebsd/sys/net/altq/altq_subr.c
[1654/1916] Compiling rtemsbsd/rtems/rtems-kernel-malloc.c
[1655/1916] Compiling freebsd/sys/dev/evdev/evdev.c
[1656/1916] Compiling freebsd/sys/dev/e1000/e1000_osdep.c
[1657/1916] Compiling freebsd/sys/net/altq/altq_cdnr.c
[1658/1916] Compiling freebsd/sys/kern/uipc_usrreq.c
[1659/1916] Compiling rtemsbsd/rtems/rtems-kernel-termioskqueuepoll.c
[1660/1916] Compiling freebsd/sys/kern/uipc_accf.c
[1661/1916] Compiling freebsd/sys/kern/subr_unit.c
[1662/1916] Compiling freebsd/sys/kern/subr_eventhandler.c
[1663/1916] Compiling freebsd/sys/kern/subr_lock.c
[1664/1916] Compiling freebsd/sys/dev/dc/if_dc.c
[1665/1916] Compiling freebsd/sys/crypto/siphash/siphash.c
[1666/1916] Compiling freebsd/sys/kern/kern_synch.c
[1667/1916] Compiling rtemsbsd/pppd/auth.c
[1668/1916] Compiling freebsd/sys/dev/usb/usb_transfer.c
[1669/1916] Compiling freebsd/sys/kern/subr_uio.c
[1670/1916] Compiling freebsd/sys/dev/usb/usb_core.c
[1671/1916] Compiling freebsd/sbin/nvmecontrol/reset.c
[1672/1916] Compiling freebsd/sys/dev/usb/serial/ufoma.c
[1673/1916] Compiling freebsd/sbin/nvmecontrol/modules/wdc/wdc.c
[1674/1916] Compiling freebsd/sys/dev/usb/net/if_ipheth.c
[1675/1916] Compiling rtemsbsd/rtems/rtems-kernel-autoconf.c
[1676/1916] Compiling freebsd/sys/dev/usb/controller/musb_otg.c
[1677/1916] Compiling freebsd/sys/dev/re/if_re.c
[1678/1916] Compiling freebsd/sys/dev/ofw/ofwbus.c
[1679/1916] Compiling freebsd/sys/dev/usb/usb_parse.c
[1680/1916] Compiling freebsd/sys/dev/mii/ukphy_subr.c
[1681/1916] Compiling rtemsbsd/sys/dev/usb/controller/usb_otg_transceiver.c
[1682/1916] Compiling freebsd/sys/dev/ffec/if_ffec.c
[1683/1916] Compiling freebsd/sys/netinet/in_fib.c
[1684/1916] Compiling freebsd/sys/dev/e1000/e1000_manage.c
[1685/1916] Compiling mDNSResponder/mDNSShared/dnssd_clientshim.c
[1686/1916] Compiling freebsd/sys/dev/cadence/if_cgem.c
[1687/1916] Compiling freebsd/sys/dev/usb/controller/ehci.c
[1688/1916] Compiling freebsd/sys/crypto/des/des_enc.c
[1689/1916] Compiling freebsd/sys/contrib/libsodium/src/libsodium/crypto_verify/sodium/verify.c
[1690/1916] Compiling freebsd/sys/cam/scsi/scsi_all.c
[1691/1916] Compiling freebsd/sbin/nvmecontrol/perftest.c
[1692/1916] Compiling freebsd/sys/dev/nvme/nvme_pci.c
[1693/1916] Compiling freebsd/sys/dev/nvme/nvme_qpair.c
[1694/1916] Compiling rtemsbsd/sys/dev/usb/controller/ehci_mpc83xx.c
[1695/1916] Compiling freebsd/sys/net/altq/altq_rio.c
[1696/1916] Compiling freebsd/sys/contrib/libb2/blake2b-ref.c
[1697/1916] Compiling freebsd/sys/dev/e1000/e1000_mac.c
[1698/1916] Compiling mDNSResponder/mDNSCore/CryptoAlg.c
[1699/1916] Compiling rtemsbsd/pppd/fsm.c
[1700/1916] Compiling freebsd/sys/vm/uma_core.c
[1701/1916] Compiling freebsd/sys/crypto/camellia/camellia-api.c
[1702/1916] Compiling freebsd/sys/contrib/libsodium/src/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c
[1703/1916] Compiling rtemsbsd/nfsclient/mount_prot_xdr.c
[1704/1916] Compiling freebsd/sys/netpfil/pf/pf_table.c
[1705/1916] Compiling freebsd/sys/netpfil/pf/pf_if.c
[1706/1916] Compiling rtemsbsd/sys/dev/ffec/if_ffec_mpc8xx.c
[1707/1916] Compiling freebsd/sbin/nvmecontrol/identify_ext.c
[1708/1916] Compiling freebsd/sys/netinet6/route6.c
[1709/1916] Compiling freebsd/sys/net/altq/altq_cbq.c
[1710/1916] Compiling rtemsbsd/sys/arm/at91/at91_mci.c
[1711/1916] Compiling rtemsbsd/nfsclient/rpcio.c
[1712/1916] Compiling freebsd/sys/netinet6/in6_gif.c
[1713/1916] Compiling rtemsbsd/nfsclient/nfs_prot_xdr.c
[1714/1916] Compiling freebsd/sys/netinet/tcp_offload.c
[1715/1916] Compiling freebsd/sys/kern/subr_bus.c
[1716/1916] Compiling freebsd/sys/kern/kern_intr.c
[1717/1916] Compiling freebsd/sys/kern/kern_hhook.c
[1718/1916] Compiling freebsd/sys/crypto/blowfish/bf_skey.c
[1719/1916] Compiling freebsd/sys/contrib/libb2/blake2s-ref.c
[1720/1916] Compiling freebsd/sys/dev/usb/usb_hid.c
[1721/1916] Compiling freebsd/sys/dev/usb/serial/umoscom.c
[1722/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-pfctl.c
[1723/1916] Compiling freebsd/sys/dev/usb/net/usb_ethernet.c
[1724/1916] Compiling freebsd/sys/dev/usb/input/ukbd.c
[1725/1916] Compiling rtemsbsd/rtems/rtems-bsd-regdomain.c
[1726/1916] Compiling rtemsbsd/local/ofw_bus_if.c
[1727/1916] Compiling freebsd/sys/dev/sdhci/sdhci.c
[1728/1916] Compiling freebsd/sys/dev/nvme/nvme_ns_cmd.c
[1729/1916] Compiling freebsd/sys/dev/nvme/nvme_ns.c
[1730/1916] Compiling freebsd/sys/dev/mii/icsphy.c
[1731/1916] Compiling freebsd/sys/dev/e1000/igb_txrx.c
[1732/1916] Compiling freebsd/sys/dev/e1000/if_em.c
[1733/1916] Compiling rtemsbsd/local/cryptodev_if.c
[1734/1916] Compiling freebsd/sys/dev/usb/serial/ucycom.c
[1735/1916] Compiling freebsd/sys/dev/usb/net/if_axe.c
[1736/1916] Compiling freebsd/sys/dev/e1000/e1000_82542.c
[1737/1916] Compiling freebsd/sys/crypto/sha2/sha256c.c
[1738/1916] Compiling rtemsbsd/pppd/options.c
[1739/1916] Compiling freebsd/sys/crypto/blowfish/bf_ecb.c
[1740/1916] Compiling freebsd/sys/arm/ti/am335x/am335x_usbss.c
[1741/1916] Compiling rtemsbsd/pppd/chap.c
[1742/1916] Compiling rtemsbsd/rtems/rtems-bsd-init-dhcp.c
[1743/1916] Compiling freebsd/sbin/nvmecontrol/logpage.c
[1744/1916] Compiling rtemsbsd/rtems/rtems-bsd-get-ethernet-addr.c
[1745/1916] Compiling freebsd/sys/dev/led/led.c
[1746/1916] Compiling freebsd/sys/vm/uma_dbg.c
[1747/1916] Compiling freebsd/sys/libkern/crc32.c
[1748/1916] Compiling rtemsbsd/rtems/rtems-kernel-cam.c
[1749/1916] Compiling freebsd/sys/crypto/sha1.c
[1750/1916] Compiling freebsd/sys/dev/usb/serial/uplcom.c
[1751/1916] Compiling freebsd/sys/kern/kern_event.c
[1752/1916] Compiling freebsd/sys/opencrypto/cbc_mac.c
[1753/1916] Compiling rtemsbsd/rtems/rtems-bsd-get-mac-address.c
[1754/1916] Compiling freebsd/sys/opencrypto/criov.c
[1755/1916] Compiling freebsd/sys/netpfil/pf/if_pfsync.c
[1756/1916] Compiling rtemsbsd/rtems/rtems-kernel-jail.c
[1757/1916] Compiling freebsd/sbin/nvmecontrol/nsid.c
[1758/1916] Compiling mDNSResponder/mDNSCore/mDNS.c
[1759/1916] Compiling freebsd/sys/netinet6/raw_ip6.c
[1760/1916] Compiling freebsd/sys/libkern/murmur3_32.c
[1761/1916] Compiling rtemsbsd/rtems/syslog.c
[1762/1916] Compiling freebsd/sys/netinet6/in6_rmx.c
[1763/1916] Compiling freebsd/sys/kern/tty_inq.c
[1764/1916] Compiling freebsd/sys/kern/subr_kobj.c
[1765/1916] Compiling freebsd/sys/kern/tty_outq.c
[1766/1916] Compiling rtemsbsd/pppd/ipcp.c
[1767/1916] Compiling rtemsbsd/sys/dev/smc/if_smc_nexus.c
[1768/1916] Compiling rtemsbsd/rtems/rtems-kernel-irqs.c
[1769/1916] Compiling freebsd/sys/netinet/ip_gre.c
[1770/1916] Compiling freebsd/sys/dev/usb/storage/umass.c
[1771/1916] Compiling rtemsbsd/mdns/mdns-hostname-default.c
[1772/1916] Compiling freebsd/sys/kern/kern_osd.c
[1773/1916] Compiling freebsd/sys/kern/uipc_syscalls.c
[1774/1916] Compiling freebsd/sys/kern/kern_khelp.c
[1775/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-sysctl.c
[1776/1916] Compiling rtemsbsd/rtems/rtems-bsd-shell-openssl.c
[1777/1916] Compiling freebsd/sys/kern/kern_linker.c
[1778/1916] Compiling freebsd/sys/dev/usb/serial/uvisor.c
[1779/1916] Compiling freebsd/sys/dev/usb/usb_util.c
[1780/1916] Compiling freebsd/sys/dev/nvme/nvme_ctrlr_cmd.c
[1781/1916] Compiling rtemsbsd/sys/dev/usb/controller/ohci_lpc32xx.c
[1782/1916] Compiling freebsd/sys/netpfil/pf/pf_lb.c
[1783/1916] Compiling freebsd/sys/netinet6/ip6_output.c
[1784/1916] Compiling freebsd/sys/dev/usb/usb_handle_request.c
[1785/1916] Compiling freebsd/sys/dev/usb/serial/uslcom.c
[1786/1916] Compiling freebsd/sys/dev/usb/usb_error.c
[1787/1916] Compiling freebsd/sys/dev/mii/brgphy.c
[1788/1916] Compiling testsuite/arphole/test_main.c
[1789/1916] Compiling testsuite/cdev01/test_cdev.c
[1790/1916] Compiling testsuite/cdev01/test_main.c
[1791/1916] Compiling testsuite/commands01/test_main.c
[1792/1916] Compiling testsuite/condvar01/test_main.c
[1793/1916] Compiling testsuite/crypto01/test_main.c
[1794/1916] Compiling testsuite/debugger01/test_main.c
[1795/1916] Compiling testsuite/dhcpcd01/test_main.c
[1796/1916] Compiling testsuite/dhcpcd02/test_main.c
[1797/1916] Compiling testsuite/epoch01/test_main.c
[1798/1916] Compiling testsuite/evdev01/init.c
[1799/1916] Compiling testsuite/foobarclient/test_main.c
[1800/1916] Compiling testsuite/foobarserver/test_main.c
[1801/1916] Compiling testsuite/ftpd01/test_main.c
[1802/1916] Compiling testsuite/ftpd02/test_main.c
../../testsuite/epoch01/test_main.c:568:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(a);
../../testsuite/epoch01/test_main.c:569:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(b);
../../testsuite/epoch01/test_main.c:570:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(c);
../../testsuite/epoch01/test_main.c:571:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(d);
../../testsuite/epoch01/test_main.c:572:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(e);
../../testsuite/epoch01/test_main.c:573:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(g);
../../testsuite/epoch01/test_main.c:574:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(h);
../../testsuite/epoch01/test_main.c:575:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(i);
../../testsuite/epoch01/test_main.c:576:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(j);
../../testsuite/epoch01/test_main.c:577:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(k);
../../testsuite/epoch01/test_main.c:578:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(l);
../../testsuite/epoch01/test_main.c:579:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(m);
../../testsuite/epoch01/test_main.c:580:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(n);
../../testsuite/epoch01/test_main.c:581:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(o);
../../testsuite/epoch01/test_main.c:582:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(p);
../../testsuite/epoch01/test_main.c:583:26: error: macro "RTEMS_SCHEDULER_EDF_SMP" requires 2 arguments, but only 1 given
RTEMS_SCHEDULER_EDF_SMP(q);
In file included from ../../testsuite/epoch01/test_main.c:566:0:
../../testsuite/epoch01/test_main.c:586:3: error: '_Configuration_Scheduler_EDF_SMP_a' undeclared here (not in a function); did you mean '_Scheduler_EDF_SMP_Pin'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name(' ', ' ', ' ', 'a')), \
../../testsuite/epoch01/test_main.c:587:3: error: '_Configuration_Scheduler_EDF_SMP_b' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_a'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name(' ', ' ', ' ', 'b')), \
../../testsuite/epoch01/test_main.c:588:3: error: '_Configuration_Scheduler_EDF_SMP_c' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_b'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name(' ', ' ', ' ', 'c')), \
../../testsuite/epoch01/test_main.c:589:3: error: '_Configuration_Scheduler_EDF_SMP_d' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_c'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(d, rtems_build_name(' ', ' ', ' ', 'd')), \
../../testsuite/epoch01/test_main.c:590:3: error: '_Configuration_Scheduler_EDF_SMP_e' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_d'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(e, rtems_build_name(' ', ' ', ' ', 'e')), \
../../testsuite/epoch01/test_main.c:591:3: error: '_Configuration_Scheduler_EDF_SMP_g' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_e'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(g, rtems_build_name(' ', ' ', ' ', 'g')), \
../../testsuite/epoch01/test_main.c:592:3: error: '_Configuration_Scheduler_EDF_SMP_h' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_g'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(h, rtems_build_name(' ', ' ', ' ', 'h')), \
../../testsuite/epoch01/test_main.c:593:3: error: '_Configuration_Scheduler_EDF_SMP_i' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_h'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(i, rtems_build_name(' ', ' ', ' ', 'i')), \
../../testsuite/epoch01/test_main.c:594:3: error: '_Configuration_Scheduler_EDF_SMP_j' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_i'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(j, rtems_build_name(' ', ' ', ' ', 'j')), \
../../testsuite/epoch01/test_main.c:595:3: error: '_Configuration_Scheduler_EDF_SMP_k' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_j'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(k, rtems_build_name(' ', ' ', ' ', 'k')), \
../../testsuite/epoch01/test_main.c:596:3: error: '_Configuration_Scheduler_EDF_SMP_l' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_k'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(l, rtems_build_name(' ', ' ', ' ', 'l')), \
../../testsuite/epoch01/test_main.c:597:3: error: '_Configuration_Scheduler_EDF_SMP_m' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_l'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(m, rtems_build_name(' ', ' ', ' ', 'm')), \
../../testsuite/epoch01/test_main.c:598:3: error: '_Configuration_Scheduler_EDF_SMP_n' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_m'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(n, rtems_build_name(' ', ' ', ' ', 'n')), \
../../testsuite/epoch01/test_main.c:599:3: error: '_Configuration_Scheduler_EDF_SMP_o' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_n'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(o, rtems_build_name(' ', ' ', ' ', 'o')), \
../../testsuite/epoch01/test_main.c:600:3: error: '_Configuration_Scheduler_EDF_SMP_p' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_o'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(p, rtems_build_name(' ', ' ', ' ', 'p')), \
../../testsuite/epoch01/test_main.c:601:3: error: '_Configuration_Scheduler_EDF_SMP_q' undeclared here (not in a function); did you mean '_Configuration_Scheduler_EDF_SMP_p'?
RTEMS_SCHEDULER_TABLE_EDF_SMP(q, rtems_build_name(' ', ' ', ' ', 'q')) \
Waf: Leaving directory `/opt/work/rtems/rtems-source-builder.git/rtems/build/rtems-libbsd-ve562e3bdf33f5de01ede936d5621ab7de88f74d3-x86_64-freebsd11.2-1/rtems-libbsd-e562e3bdf33f5de01ede936d5621ab7de88f74d3/build/arm-rtems5-xilinx_zynq_zc706-default'
Build failed
-> task in 'epoch01.exe' failed with exit status 1 (run with -v to display more information)
shell cmd failed: /bin/sh -ex /opt/work/rtems/rtems-source-builder.git/rtems/build/rtems-libbsd-ve562e3bdf33f5de01ede936d5621ab7de88f74d3-x86_64-freebsd11.2-1/do-build
