[PATCH 06/27] Revert "libfdt: Add phandle generation helper"
Fri Feb 28 06:51:23 UTC 2020
From: David Gibson <david at gibson.dropbear.id.au>
This reverts commit 54ea41c22415cb0e283d22faf71202051c89400c.
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_ro.c  | 31 -------------------------------
 cpukit/include/libfdt.h     | 19 -------------------
 cpukit/include/libfdt_env.h |  1 -
 3 files changed, 51 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 97cdcda0db..eafc142828 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -170,37 +170,6 @@ uint32_t fdt_get_max_phandle(const void *fdt)
 	return 0;
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle)
-	uint32_t max = 0;
-	int offset = -1;
-	while (true) {
-		uint32_t value;
-		offset = fdt_next_node(fdt, offset, NULL);
-		if (offset < 0) {
-			if (offset == -FDT_ERR_NOTFOUND)
-				break;
-			return offset;
-		value = fdt_get_phandle(fdt, offset);
-		if (value > max)
-			max = value;
-	if (max == FDT_MAX_PHANDLE)
-		return -FDT_ERR_NOPHANDLES;
-	if (phandle)
-		*phandle = max + 1;
-	return 0;
 static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n)
 	int offset = n * sizeof(struct fdt_reserve_entry);
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 7e102d188e..a470d1df6d 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -140,10 +140,6 @@
 #define FDT_ERR_MAX		17
-/* constants */
-#define FDT_MAX_PHANDLE 0xfffffffe
-	/* Valid values for phandles range from 1 to 2^32-2. */
 /* Low-level functions (you probably don't need these)                */
@@ -380,21 +376,6 @@ const char *fdt_string(const void *fdt, int stroffset);
 uint32_t fdt_get_max_phandle(const void *fdt);
- * fdt_generate_phandle - return a new, unused phandle for a device tree blob
- * @fdt: pointer to the device tree blob
- * @phandle: return location for the new phandle
- * Walks the device tree blob and looks for the highest phandle value. On
- * success, the new, unused phandle value (one higher than the previously
- * highest phandle value in the device tree blob) will be returned in the
- * @phandle parameter.
- * Returns:
- *   0 on success or a negative error-code on failure
-int fdt_generate_phandle(const void *fdt, uint32_t *phandle);
  * fdt_num_mem_rsv - retrieve the number of memory reserve map entries
diff --git a/cpukit/include/libfdt_env.h b/cpukit/include/libfdt_env.h
index 4d1cdfa585..eb2053845c 100644
--- a/cpukit/include/libfdt_env.h
+++ b/cpukit/include/libfdt_env.h
@@ -52,7 +52,6 @@
  *     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-#include <stdbool.h>
 #include <stddef.h>
 #include <stdint.h>
