[PATCH 11/27] libfdt: Ensure fdt_add_property frees allocated name string on failure
Sebastian Huber
Fri Feb 28 06:51:28 UTC 2020
If fdt_add_property or fdt_property_placeholder fail after allocating
a string for the name, they return without freeing that string. This
does not change the structure of the tree, but in very specific cases
it could lead to undesirable space consumption.
Fix this by rolling back the string allocation in this situation.
Signed-off-by: Nicholas Piggin <npiggin at gmail.com>
Message-Id: <20190509094122.834-2-npiggin at gmail.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt_rw.c | 22 +++++++++++++++++++---
cpukit/dtc/libfdt/fdt_sw.c | 23 ++++++++++++++++++++---
2 files changed, 39 insertions(+), 6 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 2e49855d7c..9e7661509e 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -136,6 +136,14 @@ static int fdt_splice_struct_(void *fdt, void *p,
return 0;
+/* Must only be used to roll back in case of error */
+static void fdt_del_last_string_(void *fdt, const char *s)
+ int newlen = strlen(s) + 1;
+ fdt_set_size_dt_strings(fdt, fdt_size_dt_strings(fdt) - newlen);
static int fdt_splice_string_(void *fdt, int newlen)
void *p = (char *)fdt
@@ -149,7 +157,7 @@ static int fdt_splice_string_(void *fdt, int newlen)
return 0;
-static int fdt_find_add_string_(void *fdt, const char *s)
+static int fdt_find_add_string_(void *fdt, const char *s, int *allocated)
char *strtab = (char *)fdt + fdt_off_dt_strings(fdt);
const char *p;
@@ -157,6 +165,8 @@ static int fdt_find_add_string_(void *fdt, const char *s)
int len = strlen(s) + 1;
int err;
+ *allocated = 0;
p = fdt_find_string_(strtab, fdt_size_dt_strings(fdt), s);
if (p)
/* found it */
@@ -167,6 +177,8 @@ static int fdt_find_add_string_(void *fdt, const char *s)
if (err)
return err;
+ *allocated = 1;
memcpy(new, s, len);
return (new - strtab);
@@ -225,11 +237,12 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name,
int nextoffset;
int namestroff;
int err;
+ int allocated;
if ((nextoffset = fdt_check_node_offset_(fdt, nodeoffset)) < 0)
return nextoffset;
- namestroff = fdt_find_add_string_(fdt, name);
+ namestroff = fdt_find_add_string_(fdt, name, &allocated);
if (namestroff < 0)
return namestroff;
@@ -237,8 +250,11 @@ static int fdt_add_property_(void *fdt, int nodeoffset, const char *name,
proplen = sizeof(**prop) + FDT_TAGALIGN(len);
err = fdt_splice_struct_(fdt, *prop, 0, proplen);
- if (err)
+ if (err) {
+ if (allocated)
+ fdt_del_last_string_(fdt, name);
return err;
(*prop)->tag = cpu_to_fdt32(FDT_PROP);
(*prop)->nameoff = cpu_to_fdt32(namestroff);
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 9fa4a94d83..113f28ad3f 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -262,7 +262,16 @@ int fdt_end_node(void *fdt)
return 0;
+ int strtabsize = fdt_size_dt_strings(fdt);
+ int len = strlen(s) + 1;
+ fdt_set_size_dt_strings(fdt, strtabsize - len);
char *strtab = (char *)fdt + fdt_totalsize(fdt);
const char *p;
@@ -270,11 +279,15 @@ static int fdt_find_add_string_(void *fdt, const char *s)
int struct_top, offset;
+ *allocated = 0;
p = fdt_find_string_(strtab - strtabsize, strtabsize, s);
if (p)
return p - strtab;
/* Add it */
+ *allocated = 1;
offset = -strtabsize - len;
struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
if (fdt_totalsize(fdt) + offset < struct_top)
@@ -289,16 +302,20 @@ int fdt_property_placeholder(void *fdt, const char *name, int len, void **valp)
struct fdt_property *prop;
int nameoff;
+ int allocated;
FDT_SW_PROBE_STRUCT(fdt);
- nameoff = fdt_find_add_string_(fdt, name);
+ nameoff = fdt_find_add_string_(fdt, name, &allocated);
if (nameoff == 0)
return -FDT_ERR_NOSPACE;
prop = fdt_grab_space_(fdt, sizeof(*prop) + FDT_TAGALIGN(len));
- if (! prop)
+ if (! prop) {
+ if (allocated)
prop->tag = cpu_to_fdt32(FDT_PROP);
prop->nameoff = cpu_to_fdt32(nameoff);
2.16.4
