[PATCH 14/27] libfdt: Replace GPL/BSD boilerplate/reference with SPDX tags
Sebastian Huber
Fri Feb 28 06:51:31 UTC 2020
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh at kernel.org>
Message-Id: <20190620211944.9378-3-robh at kernel.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_addresses.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_empty_tree.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_ro.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_rw.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_strerror.c | 46 +-----------------------------------
cpukit/dtc/libfdt/fdt_sw.c | 47 +------------------------------------
cpukit/dtc/libfdt/fdt_wip.c | 47 +------------------------------------
cpukit/dtc/libfdt/libfdt_internal.h | 47 +------------------------------------
cpukit/include/fdt.h | 47 +------------------------------------
cpukit/include/libfdt.h | 47 +------------------------------------
cpukit/include/libfdt_env.h | 47 +------------------------------------
12 files changed, 12 insertions(+), 551 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index ae03b11129..179168ec63 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -1,52 +1,7 @@
+// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause)
* libfdt - Flat Device Tree manipulation
* Copyright (C) 2006 David Gibson, IBM Corporation.
- * libfdt is dual licensed: you can use it either under the terms of
- * the GPL, or the BSD license, at your option.
- * a) This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU General Public License as
- * published by the Free Software Foundation; either version 2 of the
- * License, or (at your option) any later version.
- * This library is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public
- * License along with this library; if not, write to the Free
- * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston,
- * MA 02110-1301 USA
- * Alternatively,
- * b) Redistribution and use in source and binary forms, with or
- * without modification, are permitted provided that the following
- * conditions are met:
- * 1. Redistributions of source code must retain the above
- * copyright notice, this list of conditions and the following
- * disclaimer.
- * 2. Redistributions in binary form must reproduce the above
- * disclaimer in the documentation and/or other materials
- * provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
- * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
- * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
- * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
- * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
- * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "libfdt_env.h"
diff --git a/cpukit/dtc/libfdt/fdt_addresses.c b/cpukit/dtc/libfdt/fdt_addresses.c
index 2cc997ea50..d8ba8ec60c 100644
--- a/cpukit/dtc/libfdt/fdt_addresses.c
+++ b/cpukit/dtc/libfdt/fdt_addresses.c
@@ -1,53 +1,8 @@
* Copyright (C) 2014 David Gibson <david at gibson.dropbear.id.au>
* Copyright (C) 2018 embedded brains GmbH
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_empty_tree.c b/cpukit/dtc/libfdt/fdt_empty_tree.c
index f2ae9b77c2..49d54d44b8 100644
--- a/cpukit/dtc/libfdt/fdt_empty_tree.c
+++ b/cpukit/dtc/libfdt/fdt_empty_tree.c
@@ -1,52 +1,7 @@
* Copyright (C) 2012 David Gibson, IBM Corporation.
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 2c393a100b..6fd9ec170d 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -1,52 +1,7 @@
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 9e7661509e..8795947c00 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -1,52 +1,7 @@
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_strerror.c b/cpukit/dtc/libfdt/fdt_strerror.c
index 0e6b4fd5e7..768db66ead 100644
--- a/cpukit/dtc/libfdt/fdt_strerror.c
+++ b/cpukit/dtc/libfdt/fdt_strerror.c
@@ -1,51 +1,7 @@
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index e773157d0f..76bea22f73 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -1,52 +1,7 @@
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/fdt_wip.c b/cpukit/dtc/libfdt/fdt_wip.c
index 534c1cbbb2..f64139e0b3 100644
--- a/cpukit/dtc/libfdt/fdt_wip.c
+++ b/cpukit/dtc/libfdt/fdt_wip.c
@@ -1,52 +1,7 @@
- * Alternatively,
- * disclaimer.
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 4109f890ae..7830e550c3 100644
--- a/cpukit/dtc/libfdt/libfdt_internal.h
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -1,54 +1,9 @@
+/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */
#ifndef LIBFDT_INTERNAL_H
#define LIBFDT_INTERNAL_H
- * Alternatively,
- * disclaimer.
#include <fdt.h>
diff --git a/cpukit/include/fdt.h b/cpukit/include/fdt.h
index 74961f9026..f2e68807f2 100644
--- a/cpukit/include/fdt.h
+++ b/cpukit/include/fdt.h
@@ -1,55 +1,10 @@
#ifndef FDT_H
#define FDT_H
* Copyright 2012 Kim Phillips, Freescale Semiconductor.
- * Alternatively,
- * disclaimer.
#ifndef __ASSEMBLY__
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 0684ec22ed..8037f391a5 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -1,54 +1,9 @@
#ifndef LIBFDT_H
#define LIBFDT_H
- * Alternatively,
- * disclaimer.
#include <libfdt_env.h>
diff --git a/cpukit/include/libfdt_env.h b/cpukit/include/libfdt_env.h
index 4d1cdfa585..73b6d40450 100644
--- a/cpukit/include/libfdt_env.h
+++ b/cpukit/include/libfdt_env.h
@@ -1,55 +1,10 @@
#ifndef LIBFDT_ENV_H
#define LIBFDT_ENV_H
- * Alternatively,
- * disclaimer.
#include <stdbool.h>
2.16.4
