[PATCH 08/27] libfdt: Add new maximum phandle lookup function
    Sebastian Huber
    Fri Feb 28 06:51:25 UTC 2020
The fdt_get_max_phandle() function has some shortcomings. On one hand
it returns just a uint32_t which means to check for the "negative"
error code a caller has to explicitly check against the error code
(uint32_t)-1. In addition, the -1 is the only error code that can be
returned, so a caller cannot tell the difference between the various
failures.
Fix this by adding a new fdt_find_max_phandle() function that returns an
error code on failure and 0 on success, just like other APIs, and stores
the maximum phandle value in an output argument on success.
This also refactors fdt_get_max_phandle() to use the new function. Add a
note pointing out that the new fdt_find_max_phandle() function should be
preferred over fdt_get_max_phandle().
Signed-off-by: Thierry Reding <treding at nvidia.com>
Message-Id: <20190326153302.17109-1-thierry.reding at gmail.com>
[dwg: Reword for some inaccuracies in the commit message]
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_ro.c  | 44 +++++++++++++++++++++++++++++---------------
 cpukit/include/libfdt.h     | 16 ++++++++++++++++
 cpukit/include/libfdt_env.h |  1 +
 3 files changed, 46 insertions(+), 15 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index eafc142828..1d0335ee71 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -144,32 +144,46 @@ static int fdt_string_eq_(const void *fdt, int stroffset,
 	return p && (slen == len) && (memcmp(p, s, len) == 0);
-uint32_t fdt_get_max_phandle(const void *fdt)
+int fdt_find_max_phandle(const void *fdt, uint32_t *phandle)
-	uint32_t max_phandle = 0;
-	int offset;
+	uint32_t max = 0;
+	int offset = -1;
-	for (offset = fdt_next_node(fdt, -1, NULL);;
-	     offset = fdt_next_node(fdt, offset, NULL)) {
-		uint32_t phandle;
+	while (true) {
+		uint32_t value;
-		if (offset == -FDT_ERR_NOTFOUND)
-			return max_phandle;
+		offset = fdt_next_node(fdt, offset, NULL);
+		if (offset < 0) {
+			if (offset == -FDT_ERR_NOTFOUND)
+				break;
-		if (offset < 0)
-			return (uint32_t)-1;
+			return offset;
-		phandle = fdt_get_phandle(fdt, offset);
-		if (phandle == (uint32_t)-1)
-			continue;
+		value = fdt_get_phandle(fdt, offset);
-		if (phandle > max_phandle)
-			max_phandle = phandle;
+		if (value > max)
+			max = value;
+	if (phandle)
+		*phandle = max;
 	return 0;
+uint32_t fdt_get_max_phandle(const void *fdt)
+	uint32_t phandle;
+	int err;
+	err = fdt_find_max_phandle(fdt, &phandle);
+	if (err < 0)
+		return (uint32_t)-1;
+	return phandle;
 static const struct fdt_reserve_entry *fdt_mem_rsv(const void *fdt, int n)
 	int offset = n * sizeof(struct fdt_reserve_entry);
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index e70f5bf7e8..e1498c3c21 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -385,6 +385,20 @@ const char *fdt_get_string(const void *fdt, int stroffset, int *lenp);
 const char *fdt_string(const void *fdt, int stroffset);
+ * fdt_find_max_phandle - find and return the highest phandle in a tree
+ * @fdt: pointer to the device tree blob
+ * @phandle: return location for the highest phandle value found in the tree
+ * fdt_find_max_phandle() finds the highest phandle value in the given device
+ * tree. The value returned in @phandle is only valid if the function returns
+ * success.
+ * returns:
+ *     0 on success or a negative error code on failure
+int fdt_find_max_phandle(const void *fdt, uint32_t *phandle);
  * fdt_get_max_phandle - retrieves the highest phandle in a tree
@@ -393,6 +407,8 @@ const char *fdt_string(const void *fdt, int stroffset);
  * device tree. This will ignore badly formatted phandles, or phandles
  * with a value of 0 or -1.
+ * This function is deprecated in favour of fdt_find_max_phandle().
  * returns:
  *      the highest phandle on success
  *      0, if no phandle was found in the device tree
diff --git a/cpukit/include/libfdt_env.h b/cpukit/include/libfdt_env.h
index eb2053845c..4d1cdfa585 100644
--- a/cpukit/include/libfdt_env.h
+++ b/cpukit/include/libfdt_env.h
@@ -52,6 +52,7 @@
  *     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <stdbool.h>
 #include <stddef.h>
 #include <stdint.h>
