[PATCH 21/27] libfdt: Add support for disabling dtb checks
Sebastian Huber
Fri Feb 28 06:51:38 UTC 2020
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Signed-off-by: Simon Glass <sjg at chromium.org>
Message-Id: <20200220214557.176528-4-sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt.c | 53 +++++++++++++++++++++++++++-------------------
cpukit/dtc/libfdt/fdt_ro.c | 3 ++-
cpukit/dtc/libfdt/fdt_rw.c | 2 ++
cpukit/dtc/libfdt/fdt_sw.c | 16 ++++++++------
4 files changed, 45 insertions(+), 29 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 3e37a4b8b6..d4daf6096c 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -19,6 +19,9 @@ int32_t fdt_ro_probe_(const void *fdt)
uint32_t totalsize = fdt_totalsize(fdt);
+ if (can_assume(VALID_DTB))
+ return totalsize;
if (fdt_magic(fdt) == FDT_MAGIC) {
/* Complete tree */
if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
@@ -81,38 +84,44 @@ int fdt_check_header(const void *fdt)
if (fdt_magic(fdt) != FDT_MAGIC)
return -FDT_ERR_BADMAGIC;
- hdrsize = fdt_header_size(fdt);
if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
|| (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION))
return -FDT_ERR_BADVERSION;
if (fdt_version(fdt) < fdt_last_comp_version(fdt))
+ hdrsize = fdt_header_size(fdt);
+ if (!can_assume(VALID_DTB)) {
- if ((fdt_totalsize(fdt) < hdrsize)
- || (fdt_totalsize(fdt) > INT_MAX))
- return -FDT_ERR_TRUNCATED;
- /* Bounds check memrsv block */
- if (!check_off_(hdrsize, fdt_totalsize(fdt), fdt_off_mem_rsvmap(fdt)))
+ if ((fdt_totalsize(fdt) < hdrsize)
+ || (fdt_totalsize(fdt) > INT_MAX))
+ return -FDT_ERR_TRUNCATED;
- /* Bounds check structure block */
- if (fdt_version(fdt) < 17) {
+ /* Bounds check memrsv block */
- fdt_off_dt_struct(fdt)))
+ fdt_off_mem_rsvmap(fdt)))
- } else {
+ /* Bounds check structure block */
+ if (fdt_version(fdt) < 17) {
+ if (!check_off_(hdrsize, fdt_totalsize(fdt),
+ fdt_off_dt_struct(fdt)))
+ } else {
+ if (!check_block_(hdrsize, fdt_totalsize(fdt),
+ fdt_off_dt_struct(fdt),
+ fdt_size_dt_struct(fdt)))
+ /* Bounds check strings block */
- fdt_off_dt_struct(fdt),
- fdt_size_dt_struct(fdt)))
+ fdt_off_dt_strings(fdt),
+ fdt_size_dt_strings(fdt)))
- /* Bounds check strings block */
- if (!check_block_(hdrsize, fdt_totalsize(fdt),
- fdt_off_dt_strings(fdt), fdt_size_dt_strings(fdt)))
return 0;
@@ -142,7 +151,7 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
*nextoffset = -FDT_ERR_TRUNCATED;
tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE);
- if (!tagp)
+ if (!can_assume(VALID_DTB) && !tagp)
return FDT_END; /* premature end */
tag = fdt32_to_cpu(*tagp);
offset += FDT_TAGSIZE;
@@ -154,13 +163,13 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
do {
p = fdt_offset_ptr(fdt, offset++, 1);
} while (p && (*p != '\0'));
- if (!p)
+ if (!can_assume(VALID_DTB) && !p)
break;
case FDT_PROP:
lenp = fdt_offset_ptr(fdt, offset, sizeof(*lenp));
- if (!lenp)
+ if (!can_assume(VALID_DTB) && !lenp)
/* skip-name offset, length and value */
offset += sizeof(struct fdt_property) - FDT_TAGSIZE
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index a5c2797cde..4c26fbeb8d 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -388,7 +388,8 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
(offset = fdt_next_property_offset(fdt, offset))) {
const struct fdt_property *prop;
- if (!(prop = fdt_get_property_by_offset_(fdt, offset, lenp))) {
+ prop = fdt_get_property_by_offset_(fdt, offset, lenp);
+ if (!can_assume(VALID_DTB) && !prop) {
offset = -FDT_ERR_INTERNAL;
break;
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 8795947c00..707c00aabd 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -24,6 +24,8 @@ static int fdt_blocks_misordered_(const void *fdt,
static int fdt_rw_probe_(void *fdt)
+ return 0;
FDT_RO_PROBE(fdt);
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 76bea22f73..352193c0a7 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -12,10 +12,13 @@
static int fdt_sw_probe_(void *fdt)
- if (fdt_magic(fdt) == FDT_MAGIC)
- return -FDT_ERR_BADSTATE;
- else if (fdt_magic(fdt) != FDT_SW_MAGIC)
- return -FDT_ERR_BADMAGIC;
+ if (fdt_magic(fdt) == FDT_MAGIC)
+ return -FDT_ERR_BADSTATE;
+ else if (fdt_magic(fdt) != FDT_SW_MAGIC)
+ return -FDT_ERR_BADMAGIC;
return 0;
@@ -38,7 +41,7 @@ static int fdt_sw_probe_memrsv_(void *fdt)
if (err)
return err;
- if (fdt_off_dt_strings(fdt) != 0)
+ if (!can_assume(VALID_DTB) && fdt_off_dt_strings(fdt) != 0)
return 0;
@@ -151,7 +154,8 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
tailsize = fdt_size_dt_strings(fdt);
- if ((headsize + tailsize) > fdt_totalsize(fdt))
+ headsize + tailsize > fdt_totalsize(fdt))
return -FDT_ERR_INTERNAL;
if ((headsize + tailsize) > bufsize)
2.16.4
