[PATCH 24/27] libfdt: Add support for disabling version checks
Fri Feb 28 06:51:41 UTC 2020
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Signed-off-by: Simon Glass <sjg at chromium.org>
Reviewed-by: David Gibson <david at gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-7-sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt.c    | 34 +++++++++++++++++++++-------------
 cpukit/dtc/libfdt/fdt_ro.c | 16 ++++++++--------
 cpukit/dtc/libfdt/fdt_rw.c |  6 +++---
 3 files changed, 32 insertions(+), 24 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 0dabb920ad..4419204a86 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -24,10 +24,13 @@ int32_t fdt_ro_probe_(const void *fdt)
 	if (fdt_magic(fdt) == FDT_MAGIC) {
 		/* Complete tree */
-		if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
-			return -FDT_ERR_BADVERSION;
-		if (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION)
+		if (!can_assume(LATEST)) {
+			if (fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
+				return -FDT_ERR_BADVERSION;
+			if (fdt_last_comp_version(fdt) >
+					FDT_LAST_SUPPORTED_VERSION)
 	} else if (fdt_magic(fdt) == FDT_SW_MAGIC) {
 		/* Unfinished sequential-write blob */
 		if (fdt_size_dt_struct(fdt) == 0)
@@ -75,7 +78,8 @@ size_t fdt_header_size_(uint32_t version)
 size_t fdt_header_size(const void *fdt)
-	return fdt_header_size_(fdt_version(fdt));
+	return can_assume(LATEST) ? FDT_V17_SIZE :
+		fdt_header_size_(fdt_version(fdt));
 int fdt_check_header(const void *fdt)
@@ -84,11 +88,14 @@ int fdt_check_header(const void *fdt)
 	if (fdt_magic(fdt) != FDT_MAGIC)
 		return -FDT_ERR_BADMAGIC;
-	if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
-	    || (fdt_last_comp_version(fdt) > FDT_LAST_SUPPORTED_VERSION))
-	if (fdt_version(fdt) < fdt_last_comp_version(fdt))
+		if ((fdt_version(fdt) < FDT_FIRST_SUPPORTED_VERSION)
+		    || (fdt_last_comp_version(fdt) >
+			FDT_LAST_SUPPORTED_VERSION))
+		if (fdt_version(fdt) < fdt_last_comp_version(fdt))
 	hdrsize = fdt_header_size(fdt);
 	if (!can_assume(VALID_DTB)) {
@@ -104,7 +111,7 @@ int fdt_check_header(const void *fdt)
 		/* Bounds check structure block */
-		if (fdt_version(fdt) < 17) {
+		if (!can_assume(LATEST) && fdt_version(fdt) < 17) {
 			if (!check_off_(hdrsize, fdt_totalsize(fdt),
 					fdt_off_dt_struct(fdt)))
 				return -FDT_ERR_TRUNCATED;
@@ -135,7 +142,7 @@ const void *fdt_offset_ptr(const void *fdt, int offset, unsigned int len)
 		    || (absoffset + len) > fdt_totalsize(fdt))
 			return NULL;
-	if (fdt_version(fdt) >= 0x11)
+	if (can_assume(LATEST) || fdt_version(fdt) >= 0x11)
 		if (((offset + len) < offset)
 		    || ((offset + len) > fdt_size_dt_struct(fdt)))
 			return NULL;
@@ -175,7 +182,8 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
 		/* skip-name offset, length and value */
 		offset += sizeof(struct fdt_property) - FDT_TAGSIZE
 			+ fdt32_to_cpu(*lenp);
-		if (fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 &&
+		    fdt_version(fdt) < 0x10 && fdt32_to_cpu(*lenp) >= 8 &&
 		    ((offset - fdt32_to_cpu(*lenp)) % 8) != 0)
 			offset += 4;
 		break;
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 9c325591ae..2fa768e56c 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -60,7 +60,7 @@ const char *fdt_get_string(const void *fdt, int stroffset, int *lenp)
 		if (stroffset < 0)
 			goto fail;
-		if (fdt_version(fdt) >= 17) {
+		if (can_assume(LATEST) || fdt_version(fdt) >= 17) {
 			if (stroffset >= fdt_size_dt_strings(fdt))
 				goto fail;
 			if ((fdt_size_dt_strings(fdt) - stroffset) < len)
@@ -307,7 +307,7 @@ const char *fdt_get_name(const void *fdt, int nodeoffset, int *len)
 	nameptr = nh->name;
-	if (fdt_version(fdt) < 0x10) {
+	if (!can_assume(LATEST) && fdt_version(fdt) < 0x10) {
 		 * For old FDT versions, match the naming conventions of V16:
 		 * give only the leaf name (after all /). The actual tree
@@ -380,7 +380,7 @@ const struct fdt_property *fdt_get_property_by_offset(const void *fdt,
 	/* Prior to version 16, properties may need realignment
 	 * and this API does not work. fdt_getprop_*() will, however. */
 		if (lenp)
 			*lenp = -FDT_ERR_BADVERSION;
 		return NULL;
@@ -427,7 +427,7 @@ const struct fdt_property *fdt_get_property_namelen(const void *fdt,
 		if (lenp)
 		return NULL;
@@ -458,8 +458,8 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset,
 		return NULL;
 	/* Handle realignment */
-	if (fdt_version(fdt) < 0x10 && (poffset + sizeof(*prop)) % 8 &&
-	    fdt32_ld(&prop->len) >= 8)
+	if (!can_assume(LATEST) && fdt_version(fdt) < 0x10 &&
+	    (poffset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8)
 		return prop->data + 4;
 	return prop->data;
@@ -491,8 +491,8 @@ const void *fdt_getprop_by_offset(const void *fdt, int offset,
-	if (fdt_version(fdt) < 0x10 && (offset + sizeof(*prop)) % 8 &&
+	    (offset + sizeof(*prop)) % 8 && fdt32_ld(&prop->len) >= 8)
 	return prop->data;
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 4a95ce2dea..fe13671eb6 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -28,12 +28,12 @@ static int fdt_rw_probe_(void *fdt)
 		return 0;
 	FDT_RO_PROBE(fdt);
 	if (fdt_blocks_misordered_(fdt, sizeof(struct fdt_reserve_entry),
 		return -FDT_ERR_BADLAYOUT;
-	if (fdt_version(fdt) > 17)
+	if (!can_assume(LATEST) && fdt_version(fdt) > 17)
 		fdt_set_version(fdt, 17);
 	return 0;
@@ -425,7 +425,7 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize)
 	mem_rsv_size = (fdt_num_mem_rsv(fdt)+1)
 		* sizeof(struct fdt_reserve_entry);
 		struct_size = fdt_size_dt_struct(fdt);
 	} else {
 		struct_size = 0;
2.16.4
