[PATCH 16/27] libfdt: Allow #size-cells of 0
Fri Feb 28 06:51:33 UTC 2020
From: David Gibson <david at gibson.dropbear.id.au>
c12b2b0c20eb "libfdt: fdt_address_cells() and fdt_size_cells()" introduced
a bug as it consolidated code between the helpers for getting
#address-cells and #size-cells.  Specifically #size-cells is allowed to
be 0, and is frequently found so in practice for /cpus.  IEEE1275 only
requires implementations to handle 1..4 for #address-cells, although one
could make a case for #address-cells == #size-cells == 0 being used to
represent a bridge with a single port.
While we're there, it's not totally obvious that the existing implicit
cast of a u32 to int will give the correct results according to strict C,
although it does work in practice.  Straighten that up to cast only after
we've made our range checks.
Reported-by: yonghuhaige via https://github.com/dgibson/dtc/issues/28
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_addresses.c | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_addresses.c b/cpukit/dtc/libfdt/fdt_addresses.c
index d8ba8ec60c..9a82cd0ba2 100644
--- a/cpukit/dtc/libfdt/fdt_addresses.c
+++ b/cpukit/dtc/libfdt/fdt_addresses.c
@@ -14,7 +14,7 @@
 static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
 	const fdt32_t *c;
-	int val;
+	uint32_t val;
 	int len;
 	c = fdt_getprop(fdt, nodeoffset, name, &len);
@@ -25,10 +25,10 @@ static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
 		return -FDT_ERR_BADNCELLS;
 	val = fdt32_to_cpu(*c);
-	if ((val <= 0) || (val > FDT_MAX_NCELLS))
+	if (val > FDT_MAX_NCELLS)
-	return val;
+	return (int)val;
 int fdt_address_cells(const void *fdt, int nodeoffset)
@@ -36,6 +36,8 @@ int fdt_address_cells(const void *fdt, int nodeoffset)
 	int val;
 	val = fdt_cells(fdt, nodeoffset, "#address-cells");
+	if (val == 0)
+		return -FDT_ERR_BADNCELLS;
 	if (val == -FDT_ERR_NOTFOUND)
 		return 2;
 	return val;
2.16.4
