[PATCH] bsps/shared/grlib/1553/b1553brm.c : addressed logic issue and unsigned_compare
Peter Dufault dufault at hda.com
Fri Feb 28 21:22:56 UTC 2020
And regardless of the value of count it is successful?
> On Feb 28, 2020, at 12:17 , suyash singh <suyashsingh234 at gmail.com> wrote:
> count is unsigned int and will always be >=0.
> On Fri, Feb 28, 2020 at 10:42 PM suyash singh <suyashsingh234 at gmail.com> wrote:
>  bsps/shared/grlib/1553/b1553brm.c | 6 ++----
>  1 file changed, 2 insertions(+), 4 deletions(-)
> diff --git a/bsps/shared/grlib/1553/b1553brm.c b/bsps/shared/grlib/1553/b1553brm.c
> index 57ef70126b..4041423541 100644
> --- a/bsps/shared/grlib/1553/b1553brm.c
> +++ b/bsps/shared/grlib/1553/b1553brm.c
> @@ -982,10 +982,8 @@ static rtems_device_driver brm_write(rtems_device_major_number major, rtems_devi
>         rw_args->bytes_moved = count;
> -       if (count >= 0) {
> -               return RTEMS_SUCCESSFUL;
> -       return RTEMS_UNSATISFIED;
> +       return RTEMS_SUCCESSFUL;
>  static rtems_device_driver brm_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
> 2.17.1
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
