[PATCH] c-user: Add & update ratemon get return values
Martin Erik Werner
martinerikwerner at gmail.com
Fri Feb 28 23:52:43 UTC 2020
Add a description of the previously missing RTEMS_NOT_DEFINED return
value for rtems_rate_monotonic_get_status().
Update the RTEMS_SUCCESSFUL return value descriptions for
rtems_rate_monotonic_get_status() and
rtems_rate_monotonic_get_statistics() which incorrectly used the same
description as rtems_rate_monotonic_period().
c-user/rate_monotonic_manager.rst | 7 +++++--
1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/c-user/rate_monotonic_manager.rst b/c-user/rate_monotonic_manager.rst
index 1cc55fe..6152005 100644
--- a/c-user/rate_monotonic_manager.rst
+++ b/c-user/rate_monotonic_manager.rst
@@ -871,11 +871,14 @@ DIRECTIVE STATUS CODES:
:class: rtems-table
* - ``RTEMS_SUCCESSFUL``
- - period initiated successfully
+ - period status retrieved successfully
* - ``RTEMS_INVALID_ID``
- invalid rate monotonic period id
* - ``RTEMS_INVALID_ADDRESS``
- invalid address of status
+ * - ``RTEMS_NOT_DEFINED``
+ - no status is available due to the cpu usage of the task having been
+ reset since the period initiated
*DESCRIPTION:
This directive returns status information associated with the rate
@@ -938,7 +941,7 @@ DIRECTIVE STATUS CODES:
:class: rtems-table
+ - period statistics retrieved successfully
2.20.1
