[PATCH v4] Raspberrypi: updated the console interface.
Niteesh gsnb.gn at gmail.com
Wed Jan 1 06:38:48 UTC 2020
How to turn off optimizations, while debugging some of the variables get
optimized out.
On Wed, Jan 1, 2020 at 12:02 PM Niteesh <gsnb.gn at gmail.com> wrote:
> Good news, The FDT works. For testing purposes, I used a different DTB
> file provided by
> raspberrpi foundation. It has a different structure than the DTB from
> FreeBSD, so I modified the
> initialization code a little bit, but anyhow it works, the registers are
> initialized from the DTB file. But they are
> virtual addresses we need to offset them before initializing the registers.
> (gdb) p pl011_context
> $23 = {base = {lock = {interrupt = {<No data fields>}, mutex = {_Queue =
> {_Lock = {_next_ticket = 0,
>             _now_serving = 0}, _heads = 0x0, _owner = 0x0, _name = 0x0}}},
>     lock_acquire = 0x2095d1 <rtems_termios_device_lock_acquire_default>,
>     lock_release = 0x2095e1 <rtems_termios_device_lock_release_default>},*
> regs = 0x7e201000*, irq = 0,
>   initial_baud = 0}
> (gdb)
> I will add the offset function, and send in the patch. I am also planning
> to replace a manual search with
> fdt_node_offset_by_compatible.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200101/1df38c1f/attachment.html>
