Error while building the rtems-libbsd
Sebastian Huber
Thu Jan 2 06:14:50 UTC 2020
On 01/01/2020 16:14, Utkarsh Rai wrote:
> I have been successful in building the rtems-libbsd using 'python3
> ./waf'. Although, I had to do some weird changes to some of the files in
> the libbsd package. (These changes were done as there were several build
> errors even after the 'python ./waf' command )
> 1. In the ../freebsd/sys/netinet/in_mcast.c
> and ../../freebsd/sys/netpfil/pf/if_pfsync.c files I had to change
> the IP_MIN_MEMBERSHIPS with IP_MAX_MEMBERSHIPS .
What is your configure command line? Errors like this are unexpected.
Maybe your toolchain (RSB) is out of date.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
