[PATCH] bsp/raspberry: Enabled FDT support for console.
Niteesh gsnb.gn at gmail.com
Fri Jan 3 08:23:40 UTC 2020
On Fri, Jan 3, 2020 at 1:51 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 03/01/2020 04:50, Niteesh wrote:
> > On Fri, Jan 3, 2020 at 2:26 AM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     Sorry, it seems I missed some parts in the last mail. Beneath that I
> >     caused a misunderstanding again.
> >     On 02/01/2020 20:08, G S Niteesh wrote:
> >     > Replaced the older console api with newer FDT based
> >     > console driver.
> >     > Replaces the custom pl011 driver with RTEMS arm-pl011
> >     > driver.
> >     >  bsps/arm/raspberrypi/console/console-config.c | 156
> >     >  bsps/arm/raspberrypi/console/console_select.c | 114 ------------
> >     >  bsps/arm/raspberrypi/console/fbcons.c         |  78 ++++----
> >     >  bsps/arm/raspberrypi/console/usart.c          | 167
> >     >  bsps/arm/raspberrypi/include/bsp.h            |   6 +
> >     >  bsps/arm/raspberrypi/include/bsp/fbcons.h     |  17 +-
> >     >  .../arm/raspberrypi/include/bsp/raspberrypi.h |  53 ++----
> >     >  bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
> >     >  bsps/arm/raspberrypi/start/bspstart.c         |  15 ++
> >     >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   7 +-
> >     >  c/src/lib/libbsp/arm/raspberrypi/configure.ac
> >     <http://configure.ac> |  13 ++
> >     >  11 files changed, 225 insertions(+), 406 deletions(-)
> >     >  delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
> >     >  delete mode 100644 bsps/arm/raspberrypi/console/usart.c
> >     > diff --git a/bsps/arm/raspberrypi/console/console-config.c
> >     b/bsps/arm/raspberrypi/console/console-config.c
> >     > index d2186c918b..c306db439b 100644
> >     > --- a/bsps/arm/raspberrypi/console/console-config.c
> >     > +++ b/bsps/arm/raspberrypi/console/console-config.c
> >     > @@ -19,50 +19,140 @@
> >     >  #include <rtems/bspIo.h>
> >     > -#include <libchip/serial.h>
> >     > +#include <rtems/console.h>
> >     > +#include <rtems/sysinit.h>
> >     >  #include <bspopts.h>
> >     > -#include <bsp/irq.h>
> >     > -#include <bsp/usart.h>
> >     > +#include <bsp.h>
> >     >  #include <bsp/raspberrypi.h>
> >     > +#include <bsp/usart.h>
> >     > +#include <bsp/arm-pl011.h>
> >     >  #include <bsp/fbcons.h>
> >     > +#include <bsp/console-termios.h>
> >     > +#include <bsp/fdt.h>
> >     > +#include <bsp/fatal.h>
> >     > +#include <libfdt.h>
> >     > +#include <libchip/serial.h>
> >     > +arm_pl011_context pl011_context;
> >     > +rpi_fb_context fb_context;
> >     > +static void output_char_serial(char c)
> >     > +  arm_pl011_write_polled(&pl011_context.base, c);
> >     > +void output_char_fb(char c)
> >     > +  fbcons_write_polled(&fb_context.base, c);
> >     > +static void init_ctx_arm_pl011(
> >     > +  const void *fdt,
> >     > +  int node
> >     > +  arm_pl011_context *ctx = &pl011_context;
> >     > +  rtems_termios_device_context_initialize(&ctx->base, "UART");
> >     > +  ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
> >     > +static void register_fb( void )
> >     > +  if (fbcons_probe(&fb_context.base) == true) {
> >     > +    rtems_termios_device_install(
> >     > +      "/dev/fbcons",
> >     > +      &fbcons_fns,
> >     > +      NULL,
> >     > +      &fb_context.base);
> >     > -console_tbl Console_Configuration_Ports [] = {
> >     > -      .sDeviceName = "/dev/ttyS0",
> >     > -      .deviceType = SERIAL_CUSTOM,
> >     > -      .pDeviceFns = &bcm2835_usart_fns,
> >     > -      .deviceProbe = NULL,
> >     > -      .pDeviceFlow = NULL,
> >     > -      .ulCtrlPort1 = BCM2835_UART0_BASE,
> >     > -      .ulCtrlPort2 = 0,
> >     > -      .ulClock = USART0_DEFAULT_BAUD,
> >     > -      .ulIntVector = BCM2835_IRQ_ID_UART
> >     > -      .sDeviceName ="/dev/fbcons",
> >     > -      .pDeviceFns = &fbcons_fns,
> >     > -      .deviceProbe = fbcons_probe,
> >     > -#define PORT_COUNT \
> >     > -  (sizeof(Console_Configuration_Ports) \
> >     > -    / sizeof(Console_Configuration_Ports [0]))
> >     > -unsigned long Console_Configuration_Count = PORT_COUNT;
> >     > +static void console_select( void )
> >     > +  const char *opt;
> >     > +  const void *fdt;
> >     > +  const char *console;
> >     > +  int node;
> >     > +  fdt = bsp_fdt_get();
> >     > +  node = fdt_path_offset(fdt, "/chosen");
> >     > +  console = fdt_getprop(fdt, node, "stdout-path", NULL);
> >     Sorry that I missed that on your earlier patch:
> >     I had a look at all the "chosen" nodes in the dtb files here:
> https://github.com/raspberrypi/firmware/tree/0c01dbefba45a08c47f8538d5a071a0fba6b7e83/boot
> > I was using the dtb file from freeBSD, that one had the chosen node.
> https://github.com/freebsd/freebsd/blob/41655e1cf1451b788f6437c91ec74bcecd2192b7/sys/gnu/dts/arm/bcm283x.dtsi#L31
> > But there is no standalone DTB file from freeBSD, we have to build it so
> > I'll move to the DTB
> > that you mentioned, since it's more commonly used.
> OK. How did you change that? Did you remove it (like suggested) or do
> you search for some other node?
I removed it. We no more search for console in stdout-path.
> >     None of these had a property called stdout-path. Where did you find
> it?
> >     Beneath that: It seems that you just check whether the property is
> there
> >     without checking the value a few lines further down. Why?
> >     If there is no special reason, I would suggest to just completely
> remove
> >     the fdt from here and only parse the cmdline. If it is not "fbcons"
> just
> >     default to the /dev/ttyS0.
> >     > +  opt = rpi_cmdline_get_arg("--console=");
> >     > +  if ( opt ) {
> >     > +    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
> >     > +      if ( rpi_video_is_initialized() > 0 ) {
> >     > +        BSP_output_char = output_char_fb;
> >     > +        link("/dev/fbcons", CONSOLE_DEVICE_NAME);
> >     > +        return ;
> >     > +    }else{
> >     > +      if ( console == NULL ){
> >     > +        bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >     > +      link("/dev/S0", CONSOLE_DEVICE_NAME);
> >     Typo: That should be "/dev/ttyS0". Maybe use a #define for that. You
> are
> >     using the same string twice. Same could be true for "/dev/fbcons".
> > #define UART0    "/dev/ttyS0"
> > #define FBCONS "/dev/fbcons"
> > replace the strings.
> If the defines are in this C file, that is OK. If you put them into some
> header please prefix them with RASPBERRYPI_.
> >     > +  BSP_output_char = output_char_serial;
> >     > +static void uart_probe(void)
> >     > +  static bool initialized = false;
> >     > +  const void *fdt;
> >     > +  int node;
> >     > +  if ( initialized ) {
> >     > +    return ;
> >     > +  node = fdt_node_offset_by_compatible(fdt, -1,
> >     "brcm,bcm2835-pl011");
> >     > +  init_ctx_arm_pl011(fdt, node);
> >     > +  initialized = true;
> >     >  static void output_char(char c)
> >     > -  const console_fns *con =
> >     > -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
> >     > +  uart_probe();
> >     > +  output_char_serial(c);
> >     > +rtems_status_code console_initialize(
> >     > +  rtems_device_major_number major,
> >     > +  rtems_device_minor_number minor,
> >     > +  void *arg
> >     > +  rtems_termios_initialize();
> >     > +  uart_probe();
> >     > +  rtems_termios_device_install( "/dev/ttyS0",
> >     > +    &arm_pl011_fns,
> >     > +    NULL,
> >     > +    &pl011_context.base
> >     If you are touching the patch again (due to the ones further up):
> Please
> >     move the rtems_termios_device_install line to uart_probe().
> >     register_fb() registers it's own serial device so uart_probe should
> too.
> > I tried that before, it doesn't work. Maybe the system is not
> > initialized enough to
> > register a device. The first call to uart_probe is from bspstart.c to
> > print board information
> > that causes these issues.
> OK. Missed that call. In that case it's OK like it is.
> >     > +  register_fb();
> >     > -  con->deviceWritePolled((int) Console_Port_Minor, c);
> >     > +  console_select();
> >     > +  return RTEMS_SUCCESSFUL;
> >     >  BSP_output_char_function_type BSP_output_char = output_char;
> >     >  BSP_polling_getchar_function_type BSP_poll_char = NULL;
> >     > +RTEMS_SYSINIT_ITEM(
> >     > +  uart_probe,
> >     > +  RTEMS_SYSINIT_BSP_START,
> >     > +  RTEMS_SYSINIT_ORDER_LAST
> >     > \ No newline at end of file
> >     > diff --git a/bsps/arm/raspberrypi/console/console_select.c
> >     b/bsps/arm/raspberrypi/console/console_select.c
> >     > deleted file mode 100644
> >     > index bd246ca868..0000000000
> >     > --- a/bsps/arm/raspberrypi/console/console_select.c
> >     > +++ /dev/null
> >     > @@ -1,114 +0,0 @@
> >     > - * @file
> >     > - * @ingroup raspberrypi_console
> >     > - * @brief console select
> >     > - * Copyright (c) 2015 Yang Qiao
> >     > - *  The license and distribution terms for this file may be
> >     > - *  found in the file LICENSE in this distribution or at
> >     > - *  http://www.rtems.org/license/LICENSE
> >     > -#include <bsp.h>
> >     > -#include <bsp/fatal.h>
> >     > -#include <rtems/libio.h>
> >     > -#include <stdlib.h>
> >     > -#include <string.h>
> >     > -#include <assert.h>
> >     > -#include <termios.h>
> >     > -#include <rtems/termiostypes.h>
> >     > -#include "../../shared/dev/serial/legacy-console.h"
> >     > -#include <bsp/rpi-fb.h>
> >     > -rtems_device_minor_number BSPPrintkPort = 0;
> >     > - * Method to return true if the device associated with the
> >     > - * minor number probs available.
> >     > -static bool bsp_Is_Available( rtems_device_minor_number minor )
> >     > -  console_tbl *cptr = Console_Port_Tbl[ minor ];
> >     > -   * First perform the configuration dependent probe, then the
> >     > -   * device dependent probe
> >     > -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
> >     > -       cptr->pDeviceFns->deviceProbe( minor ) ) {
> >     > -    return true;
> >     > -  return false;
> >     > - * Method to return the first available device.
> >     > -static rtems_device_minor_number bsp_First_Available_Device( void
> >     > -  rtems_device_minor_number minor;
> >     > -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
> >     > -      return minor;
> >     > -   *  Error No devices were found.  We will want to bail here.
> >     > -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >     > -void bsp_console_select( void )
> >     > -   *  Reset Console_Port_Minor and
> >     > -   *  BSPPrintkPort here if desired.
> >     > -   *  This default version allows the bsp to set these
> >     > -   *  values at creation and will not touch them again
> >     > -   *  unless the selected port number is not available.
> >     > -  const char *opt;
> >     > -  Console_Port_Minor = BSP_CONSOLE_UART0;
> >     > -  BSPPrintkPort = BSP_CONSOLE_UART0;
> >     > -  opt = rpi_cmdline_get_arg( "--console=" );
> >     > -  if ( opt ) {
> >     > -    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
> >     > -      if ( rpi_video_is_initialized() > 0 ) {
> >     > -        Console_Port_Minor = BSP_CONSOLE_FB;
> >     > -        BSPPrintkPort = BSP_CONSOLE_FB;
> >     > -   * If the device that was selected isn't available then
> >     > -   * let the user know and select the first available device.
> >     > -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> >     > -    Console_Port_Minor = bsp_First_Available_Device();
> >     > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
> >     b/bsps/arm/raspberrypi/console/fbcons.c
> >     > index 3669ba458d..0c0a5087ce 100644
> >     > --- a/bsps/arm/raspberrypi/console/fbcons.c
> >     > +++ b/bsps/arm/raspberrypi/console/fbcons.c
> >     > @@ -18,6 +18,7 @@
> >     >  #include <rtems.h>
> >     > +#include <rtems/termiostypes.h>
> >     >  #include <stdlib.h>
> >     > @@ -29,15 +30,6 @@
> >     >  #include <bsp/vc.h>
> >     > - *  fbcons_init
> >     > - *  This function initializes the fb console to a quiecsent state.
> >     > -static void fbcons_init( int minor )
> >     >   *  fbcons_open
> >     > @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
> >     >   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
> >     > -static int fbcons_open(
> >     > -  int   major,
> >     > -  int   minor,
> >     > -  void *arg
> >     > +static bool fbcons_open(
> >     > +  struct rtems_termios_tty *tty,
> >     > +  rtems_termios_device_context *base,
> >     > +  struct termios *term,
> >     > +  rtems_libio_open_close_args_t *args
> >     > -  return RTEMS_SUCCESSFUL;
> >     > +  return true;
> >     > @@ -59,13 +52,12 @@ static int fbcons_open(
> >     >   *  This function shuts down the requested port.
> >     > -static int fbcons_close(
> >     > -  int   major,
> >     > -  int   minor,
> >     > -  void *arg
> >     > +static void fbcons_close(
> >     > -  return ( RTEMS_SUCCESSFUL );
> >     > @@ -73,8 +65,8 @@ static int fbcons_close(
> >     >   *  This routine polls out the requested character.
> >     > -static void fbcons_write_polled(
> >     > -  int  minor,
> >     > +void fbcons_write_polled(
> >     >    char c
> >     > @@ -90,8 +82,8 @@ static void fbcons_write_polled(
> >     >   *  Console Termios output entry point when using polled output.
> >     > -static ssize_t fbcons_write_support_polled(
> >     > -  int         minor,
> >     > +static void fbcons_write_support_polled(
> >     >    const char *buf,
> >     >    size_t      len
> >     > @@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
> >     >     * poll each byte in the string out of the port.
> >     >    while ( nwrite < len ) {
> >     > -    fbcons_write_polled( minor, *buf++ );
> >     > +    fbcons_write_polled( base, *buf++ );
> >     >      nwrite++;
> >     > -   * return the number of bytes written.
> >     > -  return nwrite;
> >     > @@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
> >     >   *  Console Termios polling input entry point.
> >     > -static int fbcons_inbyte_nonblocking_polled( int minor )
> >     > +static int fbcons_inbyte_nonblocking_polled(
> >     >    // if( rtems_kbpoll() ) {
> >     >    //   int c = getch();
> >     > @@ -133,15 +122,17 @@ static int fbcons_inbyte_nonblocking_polled(
> >     int minor )
> >     >   *  This function sets the UART channel to reflect the requested
> >     termios
> >     >   *  port settings.
> >     > -static int fbcons_set_attributes(
> >     > -  int                   minor,
> >     > +static bool fbcons_set_attributes(
> >     >    const struct termios *t
> >     > -  return 0;
> >     > +  return true;
> >     > -bool fbcons_probe( int minor )
> >     > +bool fbcons_probe(
> >     > +  rtems_termios_device_context *context
> >     >    // rtems_status_code status;
> >     >    static bool firstTime = true;
> >     > @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
> >     >    return ret;
> >     > -const console_fns fbcons_fns =
> >     > +const rtems_termios_device_handler fbcons_fns =
> >     > -  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe
> >     > -  .deviceFirstOpen = fbcons_open,                 /*
> >     deviceFirstOpen */
> >     > -  .deviceLastClose = fbcons_close,                /*
> >     deviceLastClose */
> >     > -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
> >     > -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite
> >     > -  .deviceInitialize = fbcons_init,                /*
> >     deviceInitialize */
> >     > -  .deviceWritePolled = fbcons_write_polled,       /*
> >     deviceWritePolled */
> >     > -  .deviceSetAttributes = fbcons_set_attributes,   /*
> >     deviceSetAttributes */
> >     > -  .deviceOutputUsesInterrupts = FALSE,           /*
> >     deviceOutputUsesInterrupts*/
> >     > +  .first_open = fbcons_open,
> >     > +  .last_close = fbcons_close,
> >     > +  .poll_read = fbcons_inbyte_nonblocking_polled,
> >     > +  .write = fbcons_write_support_polled,
> >     > +  .set_attributes = fbcons_set_attributes,
> >     > +  .mode = TERMIOS_POLLED
> >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
> >     b/bsps/arm/raspberrypi/console/usart.c
> >     > index 25fb523621..0000000000
> >     > --- a/bsps/arm/raspberrypi/console/usart.c
> >     > +++ /dev/null
> >     > @@ -1,167 +0,0 @@
> >     > - * @file
> >     > - * @ingroup raspberrypi_usart
> >     > - * @brief USART support.
> >     > - * Copyright (c) 2013 Alan Cudmore
> >     > -#include <libchip/sersupp.h>
> >     > -#include <bsp.h>
> >     > -#include <bsp/raspberrypi.h>
> >     > -#include <rtems/bspIo.h>
> >     > -static void usart_delay(uint32_t n)
> >     > - volatile uint32_t i = 0;
> >     > - for(i = 0; i < n; i++)
> >     > -#if 0
> >     > - *  These will be useful when the driver supports interrupt
> >     driven IO.
> >     > -static rtems_vector_number usart_get_irq_number(const console_tbl
> >     *ct)
> >     > -  return ct->ulIntVector;
> >     > -static uint32_t usart_get_baud(const console_tbl *ct)
> >     > -  return ct->ulClock;
> >     > -#endif
> >     > -static void usart_set_baud(int minor, int baud)
> >     > -  * Nothing for now
> >     > - return;
> >     > -static void usart_initialize(int minor)
> >     > -  unsigned int gpio_reg;
> >     > -  ** Program GPIO pins for UART 0
> >     > -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> >     > -  gpio_reg &= ~(7<<12);    /* gpio14 */
> >     > -  gpio_reg |=  (4<<12);    /* alt0   */
> >     > -  gpio_reg &= ~(7<<15);    /* gpio15 */
> >     > -  gpio_reg |=  (4<<15);    /* alt0   */
> >     > -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> >     > -  usart_delay(150);
> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
> >     > -  usart_delay(150);
> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> >     > -  ** Init the PL011 UART
> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> >     > -  usart_set_baud(minor, 115000);
> >     > -static int usart_first_open(int major, int minor, void *arg)
> >     > -  rtems_libio_open_close_args_t *oc =
> >     (rtems_libio_open_close_args_t *) arg;
> >     > -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> >     oc->iop->data1;
> >     > -  const console_tbl *ct = Console_Port_Tbl [minor];
> >     > -  console_data *cd = &Console_Port_Data [minor];
> >     > -  cd->termios_data = tty;
> >     > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
> >     > -  return 0;
> >     > -static int usart_last_close(int major, int minor, void *arg)
> >     > -  return 0;
> >     > -static int usart_read_polled(int minor)
> >     > -  if (minor == 0) {
> >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
> >     == 0) {
> >     > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> >     > -    } else {
> >     > -      return -1;
> >     > -  } else {
> >     > -    printk("Unknown console minor number: %d\n", minor);
> >     > -    return -1;
> >     > -static void usart_write_polled(int minor, char c)
> >     > -   while (1) {
> >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
> >     == 0)
> >     > -       break;
> >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
> >     > -static ssize_t usart_write_support_polled(
> >     > -  int minor,
> >     > -  const char *s,
> >     > -  size_t n
> >     > -  ssize_t i = 0;
> >     > -  for (i = 0; i < n; ++i) {
> >     > -    usart_write_polled(minor, s [i]);
> >     > -  return n;
> >     > -static int usart_set_attributes(int minor, const struct termios
> >     *term)
> >     > -  return -1;
> >     > -const console_fns bcm2835_usart_fns = {
> >     > -  .deviceFirstOpen = usart_first_open,
> >     > -  .deviceLastClose = usart_last_close,
> >     > -  .deviceRead = usart_read_polled,
> >     > -  .deviceWrite = usart_write_support_polled,
> >     > -  .deviceInitialize = usart_initialize,
> >     > -  .deviceWritePolled = usart_write_polled,
> >     > -  .deviceSetAttributes = usart_set_attributes,
> >     > -  .deviceOutputUsesInterrupts = false
> >     > diff --git a/bsps/arm/raspberrypi/include/bsp.h
> >     b/bsps/arm/raspberrypi/include/bsp.h
> >     > index 1075cb1771..190dd16184 100644
> >     > --- a/bsps/arm/raspberrypi/include/bsp.h
> >     > +++ b/bsps/arm/raspberrypi/include/bsp.h
> >     > @@ -41,6 +41,10 @@ extern "C" {
> >     >  #define BSP_FEATURE_IRQ_EXTENSION
> >     > +#if BSP_START_COPY_FDT_FROM_U_BOOT
> >     > +#define BSP_FDT_IS_SUPPORTED
> >     > +#endif
> >     That's where I have caused a misunderstanding: I didn't want that you
> >     change the description of the commit. Please move enabling FDT to a
> >     separate patch that only enables FDT. You patch set will then have
> two
> >     patches. First one that has only this four lines and the ones further
> >     below that enable FDT (marked with FDT-PATCH).
> >     One patch should only do one thing. That makes it simpler to find and
> >     rework patches that introduce bugs. Your patch currently does two
> things
> >     at the same time:
> >     - Enable FDT for this BSP.
> >     - Rework console to work with the FDT.
> >     If unsure how to split an existing patch: A short guide is here:
> >         https://stackoverflow.com/a/6217314/2229658
> >     I already lost changes when rebasing. Therefore I suggest to create a
> >     branch first and only do a rebase on that. In the worst case you can
> go
> >     back to the original branch and throw away the rebase branch.
> >     >  #define RPI_L2_CACHE_ENABLE 1
> >     >  #define BSP_GPIO_PIN_COUNT 32
> >     > @@ -50,6 +54,8 @@ extern "C" {
> >     >  #define BSP_CONSOLE_UART0   0
> >     >  #define BSP_CONSOLE_FB      1
> >     > +void *raspberrypi_get_reg_of_node(const void *fdt, int node);
> >     >  void rpi_init_cmdline(void);
> >     >  const char *rpi_cmdline_get_cached(void);
> >     >  const char *rpi_cmdline_get_raw(void);
> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     > index d0e126699a..9de75ee5a4 100644
> >     > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     > @@ -33,12 +33,25 @@ extern "C" {
> >     >  #define FB_CONSOLE 0x50492835
> >     > -bool fbcons_probe( int minor );
> >     > +bool fbcons_probe(
> >     > +  char c
> >     > +void output_char_fb(char c);
> >     > +typedef struct {
> >     > +    rtems_termios_device_context base;
> >     > +} rpi_fb_context ;
> >     >   * Driver function table
> >     > -extern const console_fns fbcons_fns;
> >     > +extern const rtems_termios_device_handler fbcons_fns;
> >     >  #ifdef __cplusplus
> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     > index 40c80cf408..b7061a9ff4 100644
> >     > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     > @@ -24,6 +24,7 @@
> >     >  #include <stdint.h>
> >     >  #include <bsp/utility.h>
> >     >   * @defgroup raspberrypi_reg Register Definitions
> >     > @@ -53,13 +54,25 @@
> >     >  #if (BSP_IS_RPI2 == 1)
> >     > -   #define RPI_PERIPHERAL_BASE      0x3F000000
> >     > +  #define RPI_PERIPHERAL_BASE      0x3F000000
> >     > +  #define BASE_OFFSET              0X3F000000
> >     >  #else
> >     > -   #define RPI_PERIPHERAL_BASE      0x20000000
> >     > +  #define RPI_PERIPHERAL_BASE      0x20000000
> >     > +  #define BASE_OFFSET              0X5E000000
> >     >  #endif
> >     >  #define RPI_PERIPHERAL_SIZE         0x01000000
> >     > + * @name Bus to Physical address translation
> >     > + *       Macro.
> >     > +#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
> >     >   * @name Internal ARM Timer Registers
> >     > @@ -184,42 +197,6 @@
> >     > - * @name UART 0 (PL011) Registers
> >     > -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
> >     > -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
> >     > -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
> >     > -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
> >     > -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
> >     > -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
> >     > -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
> >     > -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
> >     > -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
> >     > -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
> >     > -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
> >     > -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
> >     > -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
> >     > -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
> >     > -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
> >     > -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
> >     > -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
> >     > -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
> >     > -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
> >     > -#define BCM2835_UART0_MIS_RX    0x10
> >     > -#define BCM2835_UART0_MIS_TX    0x20
> >     > -#define BCM2835_UART0_IMSC_RX   0x10
> >     > -#define BCM2835_UART0_IMSC_TX   0x20
> >     > -#define BCM2835_UART0_FR_RXFE   0x10
> >     > -#define BCM2835_UART0_FR_TXFF   0x20
> >     > -#define BCM2835_UART0_ICR_RX    0x10
> >     > -#define BCM2835_UART0_ICR_TX    0x20
> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> >     b/bsps/arm/raspberrypi/include/bsp/usart.h
> >     > index d3e710c5e9..abbf53626c 100644
> >     > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> >     > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> >     > @@ -32,9 +32,8 @@
> >     >  extern "C" {
> >     >  #endif /* __cplusplus */
> >     > -#define USART0_DEFAULT_BAUD 115000
> >     > -extern const console_fns bcm2835_usart_fns;
> >     > +#define PL011_DEFAULT_BAUD 115000
> >     > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
> >     >  #ifdef __cplusplus
> >     > diff --git a/bsps/arm/raspberrypi/start/bspstart.c
> >     b/bsps/arm/raspberrypi/start/bspstart.c
> >     > index 6ff286f840..49896e4d47 100644
> >     > --- a/bsps/arm/raspberrypi/start/bspstart.c
> >     > +++ b/bsps/arm/raspberrypi/start/bspstart.c
> >     > @@ -24,6 +24,8 @@
> >     >  #include <bsp/vc.h>
> >     >  static const struct {
> >     >      uint32_t code;
> >     >      const char* label;
> >     > @@ -86,6 +88,19 @@ static const char* rpi_mem[] =
> >     >  #define NUMOF(_s) (sizeof(_s) / sizeof(_s[0]))
> >     > +  int len;
> >     > +  const uint32_t *val;
> >     > +  val = fdt_getprop(fdt, node, "reg", &len);
> >     > +  if (val == NULL || len < 4) {
> >     > +    return NULL;
> >     > +  return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
> >     >  void bsp_start(void)
> >     >      bcm2835_get_board_spec_entries spec = { 0 };
> >     > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     > index 11a22f89e3..70b19178b4 100644
> >     > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     > @@ -42,6 +42,7 @@ librtemsbsp_a_SOURCES +=
> >     ../../../../../../bsps/shared/start/bspfatal-default.c
> >     ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
> >     ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
> ../../../../../../bsps/shared/start/sbrk.c
> >     > +librtemsbsp_a_SOURCES +=
> >     ../../../../../../bsps/shared/start/bsp-fdt.c
> >     ../../../../../../bsps/shared/start/stackalloc.c
> >     ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
> >     ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> >     > @@ -63,14 +64,12 @@ librtemsbsp_a_SOURCES +=
> >     ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> >     ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> >     >  # Console
> >     > -librtemsbsp_a_SOURCES +=
> >     ../../../../../../bsps/shared/dev/serial/legacy-console.c
> >     ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
> >     ../../../../../../bsps/arm/raspberrypi/console/console-config.c
> >     ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> >     ../../../../../../bsps/arm/raspberrypi/console/usart.c
> >     ../../../../../../bsps/arm/raspberrypi/console/fb.c
> >     ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> >     ../../../../../../bsps/arm/raspberrypi/console/outch.c
> >     ../../../../../../bsps/shared/dev/serial/console-termios.c
> >     ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> >     >  # Mailbox
> >     ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
> >     > diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> >     b/c/src/lib/libbsp/arm/raspberrypi/configure.ac <http://configure.ac
> >     > index 452aa4d029..b1aa0bf417 100644
> >     > --- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> >     > +++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> >     > @@ -15,6 +15,19 @@ RTEMS_CANONICAL_TARGET_CPU
> >     >  AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> >     >  RTEMS_BSP_CONFIGURE
> >     These lines should go to FDT-PATCH too.
> >     vvvvvvv
> >     > +RTEMS_BSPOPTS_SET([BSP_START_COPY_FDT_FROM_U_BOOT],[*],[1])
> >     > +RTEMS_BSPOPTS_HELP([BSP_START_COPY_FDT_FROM_U_BOOT],[copy the
> >     U-Boot provided FDT to an internal storage])
> >     > +RTEMS_BSPOPTS_SET([BSP_FDT_BLOB_SIZE_MAX],[*],[262144])
> >     > +RTEMS_BSPOPTS_HELP([BSP_FDT_BLOB_SIZE_MAX],[maximum size of the
> >     FDT blob in bytes])
> >     > +RTEMS_BSPOPTS_SET([BSP_FDT_BLOB_READ_ONLY],[*],[1])
> >     > +RTEMS_BSPOPTS_HELP([BSP_FDT_BLOB_READ_ONLY],[place the FDT blob
> >     into the read-only data area])
> +RTEMS_BSPOPTS_SET([BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA],[*],[1])
> >     +RTEMS_BSPOPTS_HELP([BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA],[copy
> >     the FDT blob into the read-only load area via bsp_fdt_copy()])
> >     >  RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
> >     >  RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address
> >     for BSP start])
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200103/4f17a442/attachment-0001.html>
