[PATCH] bsp/raspberrypi: Updated the console API.
Niteesh
gsnb.gn at gmail.com
Fri Jan 3 12:34:20 UTC 2020
qemu-system-aarch64 doesn't support elf formats too. I tried running them
but
the qemu is stuck at 0x200. Should I change the cpu type to armv7, but by
default
Rpi3 should run 32bit applications, but not sure about qemu.
On Fri, Jan 3, 2020 at 6:01 PM Niteesh <gsnb.gn at gmail.com> wrote:
> On Fri, Jan 3, 2020 at 3:48 PM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 03/01/2020 11:11, Niteesh wrote:
>> > Great, please do have a look at the FDT patch I sent today.
>> The FDT patch looks OK too. I thought it's clear when I said that I'll
>> push it together with this one in a few days.
> Sorry, I was reading that on mobile and somehow missed it.
> > I would like to work on something else now, do you have something
>> > interesting
>> > for me to do?
>> That depends on what you want to do. I think your original intention was
>> to get the serial console running on the RPi3? So maybe add that?
> I did try that, but qemu-system-aarch64 doesn't accept exe file formats, I
> tried
> converting it to .img file, but then it doesn't run. Is there some way to
> convert to
> get elf files as output instead of exe? Is it possible to convert exe to
> elf, maybe we have
> to do some symbol table and header manipulation?
> It would be also great if you could write down some lines on how to
>> start the BSP on qemu or on a real hardware for the manual. It doesn't
>> have to be an extensive chapter. Some hints like "use objcopy like
>> that..., start qemu like this, ..." can be already very helpful.
> I will send in a documentation patch on how to run executables in qemu in a
> couple of days.
> Joel suggested a tester integration for the raspberry BSP on qemu in
>> another mail thread.
> By tester integration, you mean writing a tester.cfg which will automate
> testing using
> rtems-test right?
> You might want to start to discuss your toppic for GSoC in some more
>> details. Gedare gave some hints in the other mail thread too.
> Won't there be any idea's list? because I am literally confused about what
> to choose.
> Everything seems interesting to me, I just fear if I would pick something
> big, that I am
> not capable of finishing.
> I have gone through previous GSOC projects and have selected a few which I
> found
> quite interesting to me. I listed them in the other thread* What do you
> want to study in GSOC 2020?*
> have a look at it.
> It is still not clear of what has been accomplished? Based on the feedback
> and suggestions from
> the community, I will choose, a particular project and start working on it.
> But don't hesitate to pick any other topic that picks your eye. I'm not
>> giving orders here. Take them just as some hints what could be possible
>> from my point of view.
>> > On Fri, Jan 3, 2020 at 3:39 PM Christian Mauderer <list at c-mauderer.de
>> > <mailto:list at c-mauderer.de>> wrote:
>> > Hello Niteesh,
>> > looks good to me. The UART works for a Pi1 and a Pi2. The
>> Framebuffer
>> > console doesn't but it doesn't work either before this patch and as
>> far
>> > as I can tell you took over the logic correctly. So I don't think
>> this
>> > patch will break anything that isn't already broken.
>> > I'll give the patch some more days for others to review and if no
>> one
>> > objects, I'll push it together with the "Enable FDT support" and my
>> two
>> > patches that fix the SDRAM stuff.
>> > Best regards
>> > Christian
>> > On 03/01/2020 09:26, G S Niteesh wrote:
>> > > Replaces the legacy termios API with new termios API (#3034)
>> > > Replaces the custom PL011 serial driver with RTEMS arm-pl011.
>> > > Update #3034
>> > > bsps/arm/raspberrypi/console/console-config.c | 148
>> > > bsps/arm/raspberrypi/console/console_select.c | 114 ------------
>> > > bsps/arm/raspberrypi/console/fbcons.c | 78 ++++----
>> > > bsps/arm/raspberrypi/console/usart.c | 167
>> > > bsps/arm/raspberrypi/include/bsp.h | 2 +
>> > > bsps/arm/raspberrypi/include/bsp/fbcons.h | 17 +-
>> > > .../arm/raspberrypi/include/bsp/raspberrypi.h | 54 ++----
>> > > bsps/arm/raspberrypi/include/bsp/usart.h | 5 +-
>> > > bsps/arm/raspberrypi/start/bspstart.c | 15 ++
>> > > c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 6 +-
>> > > 10 files changed, 199 insertions(+), 407 deletions(-)
>> > > delete mode 100644 bsps/arm/raspberrypi/console/console_select.c
>> > > delete mode 100644 bsps/arm/raspberrypi/console/usart.c
>> > > diff --git a/bsps/arm/raspberrypi/console/console-config.c
>> > b/bsps/arm/raspberrypi/console/console-config.c
>> > > index d2186c918b..4000fd1c50 100644
>> > > --- a/bsps/arm/raspberrypi/console/console-config.c
>> > > +++ b/bsps/arm/raspberrypi/console/console-config.c
>> > > @@ -19,50 +19,132 @@
>> > > #include <rtems/bspIo.h>
>> > > -#include <libchip/serial.h>
>> > > +#include <rtems/console.h>
>> > > +#include <rtems/sysinit.h>
>> > > #include <bspopts.h>
>> > > -#include <bsp/irq.h>
>> > > -#include <bsp/usart.h>
>> > > +#include <bsp.h>
>> > > #include <bsp/raspberrypi.h>
>> > > +#include <bsp/usart.h>
>> > > +#include <bsp/arm-pl011.h>
>> > > #include <bsp/fbcons.h>
>> > > +#include <bsp/console-termios.h>
>> > > +#include <bsp/fdt.h>
>> > > +#include <bsp/fatal.h>
>> > > +#include <libfdt.h>
>> > > +#include <libchip/serial.h>
>> > > +#define UART0 "/dev/ttyS0"
>> > > +#define FBCONS "/dev/fbcons"
>> > > +arm_pl011_context pl011_context;
>> > > +rpi_fb_context fb_context;
>> > > +static void output_char_serial(char c)
>> > > + arm_pl011_write_polled(&pl011_context.base, c);
>> > > +void output_char_fb(char c)
>> > > + fbcons_write_polled(&fb_context.base, c);
>> > > -console_tbl Console_Configuration_Ports [] = {
>> > > - .sDeviceName = "/dev/ttyS0",
>> > > - .deviceType = SERIAL_CUSTOM,
>> > > - .pDeviceFns = &bcm2835_usart_fns,
>> > > - .deviceProbe = NULL,
>> > > - .pDeviceFlow = NULL,
>> > > - .ulCtrlPort1 = BCM2835_UART0_BASE,
>> > > - .ulCtrlPort2 = 0,
>> > > - .ulClock = USART0_DEFAULT_BAUD,
>> > > - .ulIntVector = BCM2835_IRQ_ID_UART
>> > > - .sDeviceName ="/dev/fbcons",
>> > > - .pDeviceFns = &fbcons_fns,
>> > > - .deviceProbe = fbcons_probe,
>> > > -#define PORT_COUNT \
>> > > - (sizeof(Console_Configuration_Ports) \
>> > > - / sizeof(Console_Configuration_Ports [0]))
>> > > -unsigned long Console_Configuration_Count = PORT_COUNT;
>> > > +static void init_ctx_arm_pl011(
>> > > + const void *fdt,
>> > > + int node
>> > > + arm_pl011_context *ctx = &pl011_context;
>> > > + rtems_termios_device_context_initialize(&ctx->base, "UART");
>> > > + ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
>> > > +static void register_fb( void )
>> > > + if (fbcons_probe(&fb_context.base) == true) {
>> > > + rtems_termios_device_install(
>> > > + FBCONS,
>> > > + &fbcons_fns,
>> > > + NULL,
>> > > + &fb_context.base);
>> > > +static void console_select( void )
>> > > + const char *opt;
>> > > + opt = rpi_cmdline_get_arg("--console=");
>> > > + if ( opt ) {
>> > > + if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 )
>> > > + if ( rpi_video_is_initialized() > 0 ) {
>> > > + BSP_output_char = output_char_fb;
>> > > + link(FBCONS, CONSOLE_DEVICE_NAME);
>> > > + return ;
>> > > + BSP_output_char = output_char_serial;
>> > > + link(UART0, CONSOLE_DEVICE_NAME);
>> > > +static void uart_probe(void)
>> > > + static bool initialized = false;
>> > > + const void *fdt;
>> > > + int node;
>> > > + if ( initialized ) {
>> > > + return ;
>> > > + fdt = bsp_fdt_get();
>> > > + node = fdt_node_offset_by_compatible(fdt, -1,
>> > "brcm,bcm2835-pl011");
>> > > + init_ctx_arm_pl011(fdt, node);
>> > > + initialized = true;
>> > > static void output_char(char c)
>> > > - const console_fns *con =
>> > > - Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>> > > + uart_probe();
>> > > + output_char_serial(c);
>> > > +rtems_status_code console_initialize(
>> > > + rtems_device_major_number major,
>> > > + rtems_device_minor_number minor,
>> > > + void *arg
>> > > + rtems_termios_initialize();
>> > > - con->deviceWritePolled((int) Console_Port_Minor, c);
>> > > + uart_probe();
>> > > + UART0,
>> > > + &arm_pl011_fns,
>> > > + NULL,
>> > > + &pl011_context.base
>> > > + register_fb();
>> > > + console_select();
>> > > + return RTEMS_SUCCESSFUL;
>> > > BSP_output_char_function_type BSP_output_char = output_char;
>> > > BSP_polling_getchar_function_type BSP_poll_char = NULL;
>> > > +RTEMS_SYSINIT_ITEM(
>> > > + uart_probe,
>> > > + RTEMS_SYSINIT_BSP_START,
>> > > + RTEMS_SYSINIT_ORDER_LAST
>> > > \ No newline at end of file
>> > > diff --git a/bsps/arm/raspberrypi/console/console_select.c
>> > b/bsps/arm/raspberrypi/console/console_select.c
>> > > deleted file mode 100644
>> > > index bd246ca868..0000000000
>> > > --- a/bsps/arm/raspberrypi/console/console_select.c
>> > > +++ /dev/null
>> > > @@ -1,114 +0,0 @@
>> > > - * @file
>> > > - * @ingroup raspberrypi_console
>> > > - * @brief console select
>> > > - * Copyright (c) 2015 Yang Qiao
>> > > - * The license and distribution terms for this file may be
>> > > - * found in the file LICENSE in this distribution or at
>> > > - * http://www.rtems.org/license/LICENSE
>> > > -#include <bsp.h>
>> > > -#include <bsp/fatal.h>
>> > > -#include <rtems/libio.h>
>> > > -#include <stdlib.h>
>> > > -#include <string.h>
>> > > -#include <assert.h>
>> > > -#include <termios.h>
>> > > -#include <rtems/termiostypes.h>
>> > > -#include "../../shared/dev/serial/legacy-console.h"
>> > > -#include <bsp/rpi-fb.h>
>> > > -rtems_device_minor_number BSPPrintkPort = 0;
>> > > - * Method to return true if the device associated with the
>> > > - * minor number probs available.
>> > > -static bool bsp_Is_Available( rtems_device_minor_number minor )
>> > > - console_tbl *cptr = Console_Port_Tbl[ minor ];
>> > > - * First perform the configuration dependent probe, then the
>> > > - * device dependent probe
>> > > - if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>> > > - cptr->pDeviceFns->deviceProbe( minor ) ) {
>> > > - return true;
>> > > - return false;
>> > > - * Method to return the first available device.
>> > > -static rtems_device_minor_number bsp_First_Available_Device(
>> void )
>> > > - rtems_device_minor_number minor;
>> > > - for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>> > > - return minor;
>> > > - * Error No devices were found. We will want to bail here.
>> > > - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>> > > -void bsp_console_select( void )
>> > > - * Reset Console_Port_Minor and
>> > > - * BSPPrintkPort here if desired.
>> > > - * This default version allows the bsp to set these
>> > > - * values at creation and will not touch them again
>> > > - * unless the selected port number is not available.
>> > > - const char *opt;
>> > > - Console_Port_Minor = BSP_CONSOLE_UART0;
>> > > - BSPPrintkPort = BSP_CONSOLE_UART0;
>> > > - opt = rpi_cmdline_get_arg( "--console=" );
>> > > - if ( opt ) {
>> > > - if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 )
>> > > - if ( rpi_video_is_initialized() > 0 ) {
>> > > - Console_Port_Minor = BSP_CONSOLE_FB;
>> > > - BSPPrintkPort = BSP_CONSOLE_FB;
>> > > - * If the device that was selected isn't available then
>> > > - * let the user know and select the first available device.
>> > > - if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>> > > - Console_Port_Minor = bsp_First_Available_Device();
>> > > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>> > b/bsps/arm/raspberrypi/console/fbcons.c
>> > > index 3669ba458d..0c0a5087ce 100644
>> > > --- a/bsps/arm/raspberrypi/console/fbcons.c
>> > > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>> > > @@ -18,6 +18,7 @@
>> > > #include <rtems.h>
>> > > +#include <rtems/termiostypes.h>
>> > > #include <stdlib.h>
>> > > @@ -29,15 +30,6 @@
>> > > #include <bsp/vc.h>
>> > > - * fbcons_init
>> > > - * This function initializes the fb console to a quiecsent
>> state.
>> > > -static void fbcons_init( int minor )
>> > > * fbcons_open
>> > > @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
>> > > * Default state is 9600 baud, 8 bits, No parity, and 1 stop
>> bit.
>> > > -static int fbcons_open(
>> > > - int major,
>> > > - int minor,
>> > > - void *arg
>> > > +static bool fbcons_open(
>> > > + struct rtems_termios_tty *tty,
>> > > + rtems_termios_device_context *base,
>> > > + struct termios *term,
>> > > + rtems_libio_open_close_args_t *args
>> > > - return RTEMS_SUCCESSFUL;
>> > > + return true;
>> > > @@ -59,13 +52,12 @@ static int fbcons_open(
>> > > * This function shuts down the requested port.
>> > > -static int fbcons_close(
>> > > - int major,
>> > > - int minor,
>> > > - void *arg
>> > > +static void fbcons_close(
>> > > - return ( RTEMS_SUCCESSFUL );
>> > > @@ -73,8 +65,8 @@ static int fbcons_close(
>> > > * This routine polls out the requested character.
>> > > -static void fbcons_write_polled(
>> > > - int minor,
>> > > +void fbcons_write_polled(
>> > > char c
>> > > @@ -90,8 +82,8 @@ static void fbcons_write_polled(
>> > > * Console Termios output entry point when using polled output.
>> > > -static ssize_t fbcons_write_support_polled(
>> > > - int minor,
>> > > +static void fbcons_write_support_polled(
>> > > const char *buf,
>> > > size_t len
>> > > @@ -102,14 +94,9 @@ static ssize_t fbcons_write_support_polled(
>> > > * poll each byte in the string out of the port.
>> > > while ( nwrite < len ) {
>> > > - fbcons_write_polled( minor, *buf++ );
>> > > + fbcons_write_polled( base, *buf++ );
>> > > nwrite++;
>> > > - * return the number of bytes written.
>> > > - return nwrite;
>> > > @@ -117,7 +104,9 @@ static ssize_t fbcons_write_support_polled(
>> > > * Console Termios polling input entry point.
>> > > -static int fbcons_inbyte_nonblocking_polled( int minor )
>> > > +static int fbcons_inbyte_nonblocking_polled(
>> > > // if( rtems_kbpoll() ) {
>> > > // int c = getch();
>> > > @@ -133,15 +122,17 @@ static int fbcons_inbyte_nonblocking_polled(
>> > int minor )
>> > > * This function sets the UART channel to reflect the requested
>> > termios
>> > > * port settings.
>> > > -static int fbcons_set_attributes(
>> > > - int minor,
>> > > +static bool fbcons_set_attributes(
>> > > const struct termios *t
>> > > - return 0;
>> > > + return true;
>> > > -bool fbcons_probe( int minor )
>> > > +bool fbcons_probe(
>> > > + rtems_termios_device_context *context
>> > > // rtems_status_code status;
>> > > static bool firstTime = true;
>> > > @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
>> > > return ret;
>> > > -const console_fns fbcons_fns =
>> > > +const rtems_termios_device_handler fbcons_fns =
>> > > - .deviceProbe = libchip_serial_default_probe, /*
>> deviceProbe */
>> > > - .deviceFirstOpen = fbcons_open, /*
>> > deviceFirstOpen */
>> > > - .deviceLastClose = fbcons_close, /*
>> > deviceLastClose */
>> > > - .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead
>> > > - .deviceWrite = fbcons_write_support_polled, /* deviceWrite
>> > > - .deviceInitialize = fbcons_init, /*
>> > deviceInitialize */
>> > > - .deviceWritePolled = fbcons_write_polled, /*
>> > deviceWritePolled */
>> > > - .deviceSetAttributes = fbcons_set_attributes, /*
>> > deviceSetAttributes */
>> > > - .deviceOutputUsesInterrupts = FALSE, /*
>> > deviceOutputUsesInterrupts*/
>> > > + .first_open = fbcons_open,
>> > > + .last_close = fbcons_close,
>> > > + .poll_read = fbcons_inbyte_nonblocking_polled,
>> > > + .write = fbcons_write_support_polled,
>> > > + .set_attributes = fbcons_set_attributes,
>> > > + .mode = TERMIOS_POLLED
>> > > diff --git a/bsps/arm/raspberrypi/console/usart.c
>> > b/bsps/arm/raspberrypi/console/usart.c
>> > > index 25fb523621..0000000000
>> > > --- a/bsps/arm/raspberrypi/console/usart.c
>> > > +++ /dev/null
>> > > @@ -1,167 +0,0 @@
>> > > - * @file
>> > > - * @ingroup raspberrypi_usart
>> > > - * @brief USART support.
>> > > - * Copyright (c) 2013 Alan Cudmore
>> > > -#include <libchip/sersupp.h>
>> > > -#include <bsp.h>
>> > > -#include <bsp/raspberrypi.h>
>> > > -#include <rtems/bspIo.h>
>> > > -static void usart_delay(uint32_t n)
>> > > - volatile uint32_t i = 0;
>> > > - for(i = 0; i < n; i++)
>> > > -#if 0
>> > > - * These will be useful when the driver supports interrupt
>> > driven IO.
>> > > -static rtems_vector_number usart_get_irq_number(const console_tbl
>> > *ct)
>> > > - return ct->ulIntVector;
>> > > -static uint32_t usart_get_baud(const console_tbl *ct)
>> > > - return ct->ulClock;
>> > > -#endif
>> > > -static void usart_set_baud(int minor, int baud)
>> > > - * Nothing for now
>> > > - return;
>> > > -static void usart_initialize(int minor)
>> > > - unsigned int gpio_reg;
>> > > - ** Program GPIO pins for UART 0
>> > > - gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>> > > - gpio_reg &= ~(7<<12); /* gpio14 */
>> > > - gpio_reg |= (4<<12); /* alt0 */
>> > > - gpio_reg &= ~(7<<15); /* gpio15 */
>> > > - gpio_reg |= (4<<15); /* alt0 */
>> > > - BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>> > > - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>> > > - usart_delay(150);
>> > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>> > > - usart_delay(150);
>> > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>> > > - ** Init the PL011 UART
>> > > - BCM2835_REG(BCM2835_UART0_CR) = 0;
>> > > - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
>> > > - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>> > > - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>> > > - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>> > > - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>> > > - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
>> > > - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
>> > > - BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>> > > - usart_set_baud(minor, 115000);
>> > > -static int usart_first_open(int major, int minor, void *arg)
>> > > - rtems_libio_open_close_args_t *oc =
>> > (rtems_libio_open_close_args_t *) arg;
>> > > - struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>> > oc->iop->data1;
>> > > - const console_tbl *ct = Console_Port_Tbl [minor];
>> > > - console_data *cd = &Console_Port_Data [minor];
>> > > - cd->termios_data = tty;
>> > > - rtems_termios_set_initial_baud(tty, ct->ulClock);
>> > > - return 0;
>> > > -static int usart_last_close(int major, int minor, void *arg)
>> > > - return 0;
>> > > -static int usart_read_polled(int minor)
>> > > - if (minor == 0) {
>> > > - if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>> > == 0) {
>> > > - return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>> > > - } else {
>> > > - return -1;
>> > > - } else {
>> > > - printk("Unknown console minor number: %d\n", minor);
>> > > - return -1;
>> > > -static void usart_write_polled(int minor, char c)
>> > > - while (1) {
>> > > - if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
>> > == 0)
>> > > - break;
>> > > - BCM2835_REG(BCM2835_UART0_DR) = c;
>> > > -static ssize_t usart_write_support_polled(
>> > > - int minor,
>> > > - const char *s,
>> > > - size_t n
>> > > - ssize_t i = 0;
>> > > - for (i = 0; i < n; ++i) {
>> > > - usart_write_polled(minor, s [i]);
>> > > - return n;
>> > > -static int usart_set_attributes(int minor, const struct termios
>> > *term)
>> > > - return -1;
>> > > -const console_fns bcm2835_usart_fns = {
>> > > - .deviceFirstOpen = usart_first_open,
>> > > - .deviceLastClose = usart_last_close,
>> > > - .deviceRead = usart_read_polled,
>> > > - .deviceWrite = usart_write_support_polled,
>> > > - .deviceInitialize = usart_initialize,
>> > > - .deviceWritePolled = usart_write_polled,
>> > > - .deviceSetAttributes = usart_set_attributes,
>> > > - .deviceOutputUsesInterrupts = false
>> > > diff --git a/bsps/arm/raspberrypi/include/bsp.h
>> > b/bsps/arm/raspberrypi/include/bsp.h
>> > > index b81d19cd76..190dd16184 100644
>> > > --- a/bsps/arm/raspberrypi/include/bsp.h
>> > > +++ b/bsps/arm/raspberrypi/include/bsp.h
>> > > @@ -54,6 +54,8 @@ extern "C" {
>> > > #define BSP_CONSOLE_UART0 0
>> > > #define BSP_CONSOLE_FB 1
>> > > +void *raspberrypi_get_reg_of_node(const void *fdt, int node);
>> > > void rpi_init_cmdline(void);
>> > > const char *rpi_cmdline_get_cached(void);
>> > > const char *rpi_cmdline_get_raw(void);
>> > > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> > b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> > > index d0e126699a..9de75ee5a4 100644
>> > > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> > > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> > > @@ -33,12 +33,25 @@ extern "C" {
>> > > #define FB_CONSOLE 0x50492835
>> > > -bool fbcons_probe( int minor );
>> > > +bool fbcons_probe(
>> > > + char c
>> > > +void output_char_fb(char c);
>> > > +typedef struct {
>> > > + rtems_termios_device_context base;
>> > > +} rpi_fb_context ;
>> > > * Driver function table
>> > > -extern const console_fns fbcons_fns;
>> > > +extern const rtems_termios_device_handler fbcons_fns;
>> > > #ifdef __cplusplus
>> > > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> > b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> > > index 40c80cf408..eeb48c42f1 100644
>> > > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> > > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> > > @@ -53,12 +53,24 @@
>> > > #if (BSP_IS_RPI2 == 1)
>> > > - #define RPI_PERIPHERAL_BASE 0x3F000000
>> > > + #define RPI_PERIPHERAL_BASE 0x3F000000
>> > > + #define BASE_OFFSET 0X3F000000
>> > > #else
>> > > - #define RPI_PERIPHERAL_BASE 0x20000000
>> > > + #define RPI_PERIPHERAL_BASE 0x20000000
>> > > + #define BASE_OFFSET 0X5E000000
>> > > #endif
>> > > -#define RPI_PERIPHERAL_SIZE 0x01000000
>> > > +#define RPI_PERIPHERAL_SIZE 0x01000000
>> > > + * @name Bus to Physical address translation
>> > > + * Macro.
>> > > +#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
>> > > * @name Internal ARM Timer Registers
>> > > @@ -184,42 +196,6 @@
>> > > - * @name UART 0 (PL011) Registers
>> > > -#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>> > > -#define BCM2835_UART0_DR (BCM2835_UART0_BASE + 0x00)
>> > > -#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE + 0x04)
>> > > -#define BCM2835_UART0_FR (BCM2835_UART0_BASE + 0x18)
>> > > -#define BCM2835_UART0_ILPR (BCM2835_UART0_BASE + 0x20)
>> > > -#define BCM2835_UART0_IBRD (BCM2835_UART0_BASE + 0x24)
>> > > -#define BCM2835_UART0_FBRD (BCM2835_UART0_BASE + 0x28)
>> > > -#define BCM2835_UART0_LCRH (BCM2835_UART0_BASE + 0x2C)
>> > > -#define BCM2835_UART0_CR (BCM2835_UART0_BASE + 0x30)
>> > > -#define BCM2835_UART0_IFLS (BCM2835_UART0_BASE + 0x34)
>> > > -#define BCM2835_UART0_IMSC (BCM2835_UART0_BASE + 0x38)
>> > > -#define BCM2835_UART0_RIS (BCM2835_UART0_BASE + 0x3C)
>> > > -#define BCM2835_UART0_MIS (BCM2835_UART0_BASE + 0x40)
>> > > -#define BCM2835_UART0_ICR (BCM2835_UART0_BASE + 0x44)
>> > > -#define BCM2835_UART0_DMACR (BCM2835_UART0_BASE + 0x48)
>> > > -#define BCM2835_UART0_ITCR (BCM2835_UART0_BASE + 0x80)
>> > > -#define BCM2835_UART0_ITIP (BCM2835_UART0_BASE + 0x84)
>> > > -#define BCM2835_UART0_ITOP (BCM2835_UART0_BASE + 0x88)
>> > > -#define BCM2835_UART0_TDR (BCM2835_UART0_BASE + 0x8C)
>> > > -#define BCM2835_UART0_MIS_RX 0x10
>> > > -#define BCM2835_UART0_MIS_TX 0x20
>> > > -#define BCM2835_UART0_IMSC_RX 0x10
>> > > -#define BCM2835_UART0_IMSC_TX 0x20
>> > > -#define BCM2835_UART0_FR_RXFE 0x10
>> > > -#define BCM2835_UART0_FR_TXFF 0x20
>> > > -#define BCM2835_UART0_ICR_RX 0x10
>> > > -#define BCM2835_UART0_ICR_TX 0x20
>> > > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>> > b/bsps/arm/raspberrypi/include/bsp/usart.h
>> > > index d3e710c5e9..abbf53626c 100644
>> > > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>> > > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>> > > @@ -32,9 +32,8 @@
>> > > extern "C" {
>> > > #endif /* __cplusplus */
>> > > -#define USART0_DEFAULT_BAUD 115000
>> > > -extern const console_fns bcm2835_usart_fns;
>> > > +#define PL011_DEFAULT_BAUD 115000
>> > > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>> > > #ifdef __cplusplus
>> > > diff --git a/bsps/arm/raspberrypi/start/bspstart.c
>> > b/bsps/arm/raspberrypi/start/bspstart.c
>> > > index 6ff286f840..49896e4d47 100644
>> > > --- a/bsps/arm/raspberrypi/start/bspstart.c
>> > > +++ b/bsps/arm/raspberrypi/start/bspstart.c
>> > > @@ -24,6 +24,8 @@
>> > > #include <bsp/vc.h>
>> > > static const struct {
>> > > uint32_t code;
>> > > const char* label;
>> > > @@ -86,6 +88,19 @@ static const char* rpi_mem[] =
>> > > #define NUMOF(_s) (sizeof(_s) / sizeof(_s[0]))
>> > > + int len;
>> > > + const uint32_t *val;
>> > > + val = fdt_getprop(fdt, node, "reg", &len);
>> > > + if (val == NULL || len < 4) {
>> > > + return NULL;
>> > > + return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
>> > > void bsp_start(void)
>> > > bcm2835_get_board_spec_entries spec = { 0 };
>> > > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> > b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> > > index 77aa360977..57562c10c7 100644
>> > > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> > > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> > > @@ -64,11 +64,9 @@ librtemsbsp_a_SOURCES +=
>> > ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>> > ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>> > > # Console
>> > > -librtemsbsp_a_SOURCES +=
>> > ../../../../../../bsps/shared/dev/serial/legacy-console.c
>> > ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>> > > +librtemsbsp_a_SOURCES +=
>> > ../../../../../../bsps/shared/dev/serial/console-termios.c
>> > ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>> > ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>> > ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>> > ../../../../../../bsps/arm/raspberrypi/console/usart.c
>> > ../../../../../../bsps/arm/raspberrypi/console/fb.c
>> > ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>> > ../../../../../../bsps/arm/raspberrypi/console/outch.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200103/4d5dade6/attachment-0001.html>
