[PATCH] bsp/raspberrypi: Updated the console API.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jan 3 15:54:36 UTC 2020
On Fri, Jan 3, 2020, 8:53 PM Niteesh <gsnb.gn at gmail.com> wrote:
> On Fri, Jan 3, 2020 at 7:32 PM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hi Niteesh,
>> A few formatting suggestions:
>>> diff --git a/bsps/arm/raspberrypi/console/console-config.c
>>> b/bsps/arm/raspberrypi/console/console-config.c
>>> index d2186c918b..4000fd1c50 100644
>>> --- a/bsps/arm/raspberrypi/console/console-config.c
>>> +++ b/bsps/arm/raspberrypi/console/console-config.c
>>> @@ -19,50 +19,132 @@
>>> #include <rtems/bspIo.h>
>>> -#include <libchip/serial.h>
>> You removed it here and added it below
>>> +#include <rtems/console.h>
>>> +#include <rtems/sysinit.h>
>>> #include <bspopts.h>
>>> -#include <bsp/irq.h>
>>> -#include <bsp/usart.h>
>> same here
>>> +#include <bsp.h>
>>> #include <bsp/raspberrypi.h>
>>> +#include <bsp/usart.h>
>> added here ^
>>> +#include <bsp/arm-pl011.h>
>>> #include <bsp/fbcons.h>
>>> +#include <bsp/console-termios.h>
>>> +#include <bsp/fdt.h>
>>> +#include <bsp/fatal.h>
>>> +#include <libfdt.h>
>>> +#include <libchip/serial.h>
>> here
> Is there any particular reason for doing it, or is it just a preference?
For RTEMS, I don't see any preference mentioned in the docs for the order
or includes:
https://docs.rtems.org/branches/master/eng/coding-conventions.html
In libbsd, however, the FreeBSD style guide is followed which has a
preference for the order of header includes:
https://www.freebsd.org/cgi/man.cgi?query=style&apropos=0&sektion=9
Apart from that, this is a redundant change. Is there a reason to change
the order?
> This is just a small change and I would suggest you wait for at least a day
>> before sending a v2 of the patch so that you can add changes suggested
>> by other people (if any). Congrats on getting it working ;-)
> Thank you.
>> Best,
>> Vijay
>>> +#define UART0 "/dev/ttyS0"
>>> +#define FBCONS "/dev/fbcons"
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200103/3f5a103e/attachment-0001.html>
