[PATCH v2 2/2] score: Simplify _Thread_Initialize()
Fri Jan 3 16:13:45 UTC 2020
Looks good.
On Thu, Jan 2, 2020 at 11:31 PM Sebastian Huber
> Allocate new thread queue heads during objects information extend.  This
> removes an error case and the last dependency on the workspace in
> _Thread_Initialize().
> Update #3835.
>  cpukit/Makefile.am                         |  1 +
>  cpukit/include/rtems/score/thread.h        | 10 ++++-
>  cpukit/score/src/threadallocateunlimited.c | 72 ++++++++++++++++++++++++++++++
>  cpukit/score/src/threadinitialize.c        | 11 +----
>  testsuites/samples/unlimited/test1.c       |  2 +
>  5 files changed, 86 insertions(+), 10 deletions(-)
>  create mode 100644 cpukit/score/src/threadallocateunlimited.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 52365cab8c..6e754bfe86 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -943,6 +943,7 @@ librtemscpu_a_SOURCES += score/src/rbtreeiterate.c
>  librtemscpu_a_SOURCES += score/src/rbtreenext.c
>  librtemscpu_a_SOURCES += score/src/rbtreepostorder.c
>  librtemscpu_a_SOURCES += score/src/rbtreereplace.c
> +librtemscpu_a_SOURCES += score/src/threadallocateunlimited.c
>  librtemscpu_a_SOURCES += score/src/thread.c
>  librtemscpu_a_SOURCES += score/src/threadchangepriority.c
>  librtemscpu_a_SOURCES += score/src/threadclearstate.c
> diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
> index ab640c3595..fbd5327b30 100644
> --- a/cpukit/include/rtems/score/thread.h
> +++ b/cpukit/include/rtems/score/thread.h
> @@ -1039,6 +1039,14 @@ Thread_Information name##_Information = { \
> + * @brief Return an inactive thread object or NULL.
> + * @retval NULL No inactive object is available.
> + * @retval object An inactive object.
> +Objects_Control *_Thread_Allocate_unlimited( Objects_Information *information );
>  #define THREAD_INFORMATION_DEFINE( name, api, cls, max ) \
>  static Objects_Control * \
>  name##_Local_table[ _Objects_Maximum_per_allocation( max ) ]; \
> @@ -1051,7 +1059,7 @@ Thread_Information name##_Information = { \
>      _Objects_Build_id( api, cls, 1, _Objects_Maximum_per_allocation( max ) ), \
>      name##_Local_table, \
>      _Objects_Is_unlimited( max ) ? \
> -      _Objects_Allocate_unlimited : _Objects_Allocate_static, \
> +      _Thread_Allocate_unlimited : _Objects_Allocate_static, \
>        _Objects_Free_unlimited : _Objects_Free_static, \
>      0, \
> diff --git a/cpukit/score/src/threadallocateunlimited.c b/cpukit/score/src/threadallocateunlimited.c
> new file mode 100644
> index 0000000000..c4b176f887
> --- /dev/null
> +++ b/cpukit/score/src/threadallocateunlimited.c
> @@ -0,0 +1,72 @@
> + * @file
> + * @ingroup RTEMSScoreThread
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019, 2020 embedded brains GmbH
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#if HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/thread.h>
> +#include <rtems/score/objectimpl.h>
> +#include <rtems/score/wkspace.h>
> +static void _Thread_Extend_information( Objects_Information *base )
> +  Thread_Information *information;
> +  Objects_Maximum     block;
> +  information = (Thread_Information *) base;
> +  block = _Objects_Extend_information( &information->Objects );
> +  if ( block > 0 ) {
> +    void *new_heads;
> +    new_heads = _Freechain_Extend(
> +      &information->Thread_queue_heads.Free,
> +      _Workspace_Allocate,
> +      _Objects_Extend_size( &information->Objects ),
> +      _Thread_queue_Heads_size
> +    if ( new_heads == NULL ) {
> +      _Objects_Free_objects_block( &information->Objects, block );
> +  return _Objects_Allocate_with_extend(
> +    information,
> +    _Thread_Extend_information
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index 6b9b6bef21..4dc6d51d72 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -24,7 +24,6 @@
>  #include <rtems/score/tls.h>
>  #include <rtems/score/userextimpl.h>
>  #include <rtems/score/watchdogimpl.h>
> -#include <rtems/score/wkspace.h>
>  #include <rtems/config.h>
>  bool _Thread_Initialize(
> @@ -115,15 +114,9 @@ bool _Thread_Initialize(
>     *  Get thread queue heads
> -  the_thread->Wait.spare_heads = _Freechain_Get(
> -    &information->Thread_queue_heads.Free,
> -    _Workspace_Allocate,
> -    _Objects_Extend_size( &information->Objects ),
> -    _Thread_queue_Heads_size
> +  the_thread->Wait.spare_heads = _Freechain_Pop(
> -  if ( the_thread->Wait.spare_heads == NULL ) {
> -    goto failed;
>    _Thread_queue_Heads_initialize( the_thread->Wait.spare_heads );
> diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
> index a529c71be3..3fe2688681 100644
> --- a/testsuites/samples/unlimited/test1.c
> +++ b/testsuites/samples/unlimited/test1.c
> @@ -51,6 +51,7 @@ void test1()
>      _Objects_Information_table[OBJECTS_CLASSIC_API][OBJECTS_RTEMS_TASKS];
>    objects_per_block = the_information->objects_per_block;
>    the_information->objects_per_block = 0;
> +  the_information->allocate = _Objects_Allocate_static;
>    while (task_count < MAX_TASKS)
> @@ -102,6 +103,7 @@ void test1()
>    destroy_all_tasks("TEST1");
>    the_information->objects_per_block = objects_per_block;
> +  the_information->allocate = _Thread_Allocate_unlimited;
>    printf( " TEST1 : completed\n" );
> 2.16.4
> devel mailing list
> devel at rtems.org
