[PATCH] cpukit/score: avoid NULL and races in priority mutex
Fri Jan 3 17:18:55 UTC 2020
On Fri, Jan 3, 2020, 12:08 AM Sebastian Huber <
> On 03/01/2020 00:24, Gedare Bloom wrote:
> >     while ( !_Chain_Is_empty(
> &the_thread->Priority_node.Inherited_priorities ) ) {
> > +    _ISR_Disable( level );
> >       _Thread_Dequeue_priority_node(
> >         ((Thread_Priority_node*)_Chain_First(
> > +    _ISR_Enable( level );
> I don't know how the stuff works in detail, but this looks like a TOCTOU
> problem. Should this be changed into:
>      (Thread_Priority_node *) _Chain_First(
>    _ISR_Flash( level );
I think Sebastian is right. There is a small window.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200103/4b802768/attachment.html>
