[PATCH] cpukit/libfs: remove dead code from pipe/fifo.c
Fri Jan 3 18:50:51 UTC 2020
Dead code identified by Coverity (CID 1456678). The value of ret
at line 293 is always 0.
 cpukit/libfs/src/pipe/fifo.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/cpukit/libfs/src/pipe/fifo.c b/cpukit/libfs/src/pipe/fifo.c
index b64c0d95b6..579f118bfd 100644
--- a/cpukit/libfs/src/pipe/fifo.c
+++ b/cpukit/libfs/src/pipe/fifo.c
@@ -290,8 +290,6 @@ ssize_t pipe_read(
     pipe->waitingReaders ++;
     PIPE_READWAIT(pipe);
     pipe->waitingReaders --;
-    if (ret != 0)
-      goto out_locked;
   /* Read chunk bytes */
2.17.1
