Glossary of Terms
Sebastian Huber
Tue Jan 7 09:08:55 UTC 2020
On 03/01/2020 18:16, Joel Sherrill wrote:
> On Fri, Jan 3, 2020, 10:22 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> I prefer we use a centralized glossary/document to generate individual
> glossaries (via scripting or improving Sphinx). This will be a lot
> easier to maintain.
> The DoD Architecture Framework (DoDAF) calls this an AV-2 which is a
> singular artifacr across the project for consistencyt
> http://acqnotes.com/acqnote/tasks/av-2-integrated-dictionary
> That said, you need glossaries in documents and automating pulling
> definitions and acronyms out automatically producing a glossary and
> acronym list from the master AV-2 is desirable. No one wants to
> reference a standalone glossary.
> There can be issues if definitions change over time because the single
> AV-2 can't deal with old and new. It gets confusing. I have seen a
> project where the AV-2 included history like the Oxford English
> Dictionary. It was dreadful.
> That's a lot of background to say this isn't a RTEMS unique problem. A
> central database of acronyms and definitions would be a good thing. If
> grep is sufficient to find word use to trigger inclusion in a document
> specific glossary, great.
Good, so my proposal is this:
1. I move c-user/glossary.rst to common/glossary.rst and include this
file as is in c-user.
2. The glossary.rst for the other documents is generated from
common/glossary.rst based on the :term: usage. This can start simple,
e.g. only look at the *.rst files in the document directory (e.g. no
recursive includes).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
