Generated by "./waf regenerate".
Update #3715.
eng/glossary.rst | 39 +++++++++++++++++++++++++++++++++++++++
eng/index.rst | 1 +
eng/wscript | 2 +-
3 files changed, 41 insertions(+), 1 deletion(-)
create mode 100644 eng/glossary.rst
diff --git a/eng/glossary.rst b/eng/glossary.rst
new file mode 100644
index 0000000..5f3b759
--- /dev/null
+++ b/eng/glossary.rst
@@ -0,0 +1,39 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Automatically generated by "./waf regenerate"
+Glossary
+.. glossary::
+ :sorted:
+ ABI
+ An accronym for Application Binary Interface.
+ API
+ An acronym for Application Programming Interface.
+ CCB
+ An acronym for Change Control Board.
+ Doorstop
+ `Doorstop <https://github.com/doorstop-dev/doorstop>`_ is a
+ requirements management tool.
+ EARS
+ An acronym for Easy Approach to Requirements Syntax.
+ GNAT
+ *GNAT* is the :term:`GNU` compiler for Ada, integrated into the
+ :term:`GCC`.
+ ISVV
+ An acronym for Independent Software Verification and Validation.
+ ReqIF
+ An abbreviation for
+ `Requirements Interchange Format <https://www.omg.org/spec/ReqIF/About-ReqIF/>`_.
+ software item
+ See :term:`software product`.
+ source code
+ This project uses the *source code* definition of the
+ `Linux Information Project <http://www.linfo.org/source_code.html>`_:
+ "Source code (also referred to as source or code) is the version of
+ software as it is originally written (i.e., typed into a computer) by a
+ human in plain text (i.e., human readable alphanumeric characters)."
+ YAML
+ An acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
diff --git a/eng/index.rst b/eng/index.rst
index ed314a9..a317727 100644
--- a/eng/index.rst
+++ b/eng/index.rst
@@ -37,4 +37,5 @@ RTEMS Software Engineering (|version|)
appendix-a
function_and_variable
concept
+ glossary
zreferences
diff --git a/eng/wscript b/eng/wscript
index 6bbe351..7ef6896 100644
--- a/eng/wscript
+++ b/eng/wscript
@@ -5,4 +5,4 @@ from common.waf import spell
from common.waf import cmd_spell
from common.waf import linkcheck
from common.waf import cmd_linkcheck
-from common.waf import cmd_regenerate
+from common.glossary import cmd_regenerate
2.16.4
