[PATCH] Updated docs to use the standalone SIS simulator, instead of GDB inbuilt SIS for the erc32 BSP.
Christian Mauderer
list at c-mauderer.de
Tue Jan 7 18:40:38 UTC 2020
Pushed. Thanks.
On 27/12/2019 13:01, G S Niteesh wrote:
> user/start/bsp-test.rst | 4 +-
> user/tools/tester.rst | 144 ++++++++++++++++++++++++++++++++++++----
> 2 files changed, 132 insertions(+), 16 deletions(-)
> diff --git a/user/start/bsp-test.rst b/user/start/bsp-test.rst
> index 5278375..aefeeb9 100644
> --- a/user/start/bsp-test.rst
> +++ b/user/start/bsp-test.rst
> @@ -21,7 +21,7 @@ Just run this command:
> .. code-block:: none
> cd $HOME/quick-start/build/b-erc32
> - rtems-test --rtems-bsp=erc32 --rtems-tools=$HOME/quick-start/rtems/5 .
> + rtems-test --rtems-bsp=erc32-sis --rtems-tools=$HOME/quick-start/rtems/5 .
> This command should output something like this (omitted lines are denoted by
> ...). In this output the base directory :file:`$HOME/quick-start` was replaced
> @@ -30,7 +30,7 @@ by ``$BASE``.
> RTEMS Testing - Tester, 5.0.not_released
> - Command Line: $BASE/rtems/5/bin/rtems-test --rtems-bsp=erc32 --rtems-tools=$BASE/rtems/5 .
> + Command Line: $BASE/rtems/5/bin/rtems-test --rtems-bsp=erc32-sis --rtems-tools=$BASE/rtems/5 .
> Python: 2.7.15 (default, Jan 10 2019, 01:14:47) [GCC 4.2.1 Compatible FreeBSD Clang 6.0.1 (tags/RELEASE_601/final 335540)]
> Host: FreeBSD-12.0-RELEASE-p2-amd64-64bit-ELF (FreeBSD Build_FreeBSD12 12.0-RELEASE-p2 FreeBSD 12.0-RELEASE-p2 GENERIC amd64 amd64)
> [ 1/589] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | sparc/erc32: dhrystone.exe
> diff --git a/user/tools/tester.rst b/user/tools/tester.rst
> index 609384b..c3c3fe2 100644
> --- a/user/tools/tester.rst
> +++ b/user/tools/tester.rst
> @@ -109,39 +109,155 @@ the tests. Using the run with the ERC32 BSP the command is:
> The run command is the GDB simulator without the GDB part.
> -Running the example using GDB:
> +Running the example using SIS:
> +.. code-block:: none
> + $ sparc-rtems5-sis sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
> + SIS - SPARC/RISCV instruction simulator 2.20, copyright Jiri Gaisler 2019
> + Bug-reports to jiri at gaisler.se
> + ERC32 emulation enabled
> + Loaded sparc-rtems5/c/erc32/testsuites/samples/hello.exe, entry 0x02000000
> + sis> run
> + *** BEGIN OF TEST HELLO WORLD ***
> + *** TEST VERSION: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
> + *** TEST STATE: EXPECTED-PASS
> + *** TEST BUILD: RTEMS_POSIX_API
> + *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 83fa79314dd87c0a8c78fd642b2cea3138be8dd6, Newlib 3e24fbf6f)
> + Hello World
> + *** END OF TEST HELLO WORLD ***
> + *** FATAL ***
> + fatal source: 0 (INTERNAL_ERROR_CORE)
> + fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)
> + RTEMS version: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
> + RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 83fa79314dd87c0a8c78fd642b2cea3138be8dd6, Newlib 3e24fbf6f)
> + executing thread ID: 0x08a010001
> + executing thread name: UI1
> + cpu 0 in error mode (tt = 0x101)
> + 116401 02009ae0: 91d02000 ta 0x0
> + sis> q
> +The examples can also be run using GDB with SIS as the backend. SIS can be connected to
> +gdb through a network socket using the gdb remote interface.
> +Either start SIS with ``-gdb``, or issue the ``gdb`` command inside SIS, and connect
> +gdb with ``target remote:1234``. The default port is ``1234``, the port can be changed
> +using the ``-port`` option.
> +Open a terminal and issue the command:
> + $ sparc-rtems5-sis -gdb
> + gdb: listening on port 1234
> +Now open another terminal and issue the command:
> $ sparc-rtems5-gdb sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
> - GNU gdb (GDB) 7.12
> - Copyright (C) 2016 Free Software Foundation, Inc.
> + GNU gdb (GDB) 8.3
> + Copyright (C) 2019 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> - There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> - and "show warranty" for details.
> + There is NO WARRANTY, to the extent permitted by law.
> + Type "show copying" and "show warranty" for details.
> This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems5".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> - <http://www.gnu.org/software/gdb/documentation/>.
> + <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> - Reading symbols from
> - sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe...done.
> - (gdb) target sim
> - Connected to the simulator.
> + Reading symbols from sparc-rtems5/c/erc32/testsuites/samples/hello.exe...
> + (gdb) target remote:1234
> +The ``target remote:1234`` will tell gdb to connect to the sis simulator. After this
> +command the output of the first terminal will change to
> + gdb: listening on port 1234 connected
> +Before running the executable, it must be loaded, this is done using the
> +``load`` command in gdb, and to run, issue ``continue`` command.
> + $ sparc-rtems5-gdb sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
> + GNU gdb (GDB) 8.3
> + License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> + This is free software: you are free to change and redistribute it.
> + This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems5".
> + Type "show configuration" for configuration details.
> + For bug reporting instructions, please see:
> + <http://www.gnu.org/software/gdb/bugs/>.
> + Find the GDB manual and other documentation resources online at:
> + For help, type "help".
> + Type "apropos word" to search for commands related to "word"...
> + Remote debugging using :1234
> + 0x00000000 in ?? ()
> (gdb) load
> - (gdb) r
> - Starting program: sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
> + Loading section .text, size 0x17170 lma 0x2000000
> + Loading section .rtemsroset, size 0x40 lma 0x2017170
> + Loading section .data, size 0x600 lma 0x20181c0
> + Start address 0x2000000, load size 96176
> + Transfer rate: 4696 KB/sec, 270 bytes/write.
> + (gdb) continue
> + Continuing.
> +You can see your executable running in the first terminal.
> + gdb: listening on port 1235 connected
> + X2000000,0:#40
> Hello World
> - [Inferior 1 (process 42000) exited normally]
> - (gdb) q
> + ^Csis> q
> +For more information on the sis simulator refer to this doc: https://gaisler.se/sis/sis.pdf
> The command ``r`` is used to debug set break points before issuing the GDB
> ``run`` command.
