Requirement Document generator tool
Wed Jan 8 16:47:06 UTC 2020
On Fri, Jan 3, 2020 at 7:26 AM Sebastian Huber <
> Hello Jose,
> On 03/01/2020 11:52, Jose Valdez wrote:
> >>>> Should be in rtems-tools? If so, in which place?
> >>> I think this is the best place given the information I have. I would
> >>> need to have more detail before I could provide any specific direction
> here.
> >> All host tools are in rtems-tools so at this point, there isn't another
> place.
> >> But I agree with Chris. We need more information.
> > We need to know:
> > * Language(s) used for the tool
> > * Host requirements to run the tool
> > * Licensing of the tool
> > Putting the pre-qual tools into rtems-tools seems reasonable, but a
> discussion should happen within the RTEMS Project community/maintainers to
> do that.
> > JV02012019, Joel and Gedare:
> > We need to know:
> > * Language(s) used for the tool - python (>= 3.7)
> > * Host requirements to run the tool - Debian 10
> > * Licensing of the tool - BSD-2-Clause
> > Please read the section 4 of the document SDD-301.pdf, I am sending in
> attach (removed to go to rtems devel mailing list!!). This provides an
> overview of the tool (I think we missed to give you this overview).
> > For more information you may also take a look in the SRS-300.pdf and
> TI-003 (just the conclusions on each section).
> > Note that the information presented in these documents is subjected to
> be changed, but as I said, the idea is for you to have a better
> understanding about the big picture of the project. The details will be
> discussed (and iterated) alongside the project execution.
> the aim is to write all tools in the ESA pre-qualification activity in
> Python. Derivatives of existing stuff will use the respective license.
> New stuff will use the BSD-2-Clause license for code and CC-BY-SA-4.0
> for documentation.
>  From an RTEMS Project point of view, project-specific documentation is
> irrelevant in general. It can be used as a complementary material to
> explain things intended for integration, however, all content relevant
> to things integrated in the RTEMS Project must move to the right places
> in the RTEMS Project.
> We have to settle on a specific Python version. Since Doorstop 2.0.post2
> is already selected as the tool for requirements management and it
> requires at least Python 3.6 I think it makes sense to use this version
> as well for new tools. In contrast to the build system I think a Python
> 2 compatibility is unnecessary.
> Tools which belong also to the work flow of an RTEMS user, e.g. the
> RTEMS Tester, should still work with Python 2.
> The decisions, justification, and requirements with respect to the tool
> language selection should be recorded in the RTEMS Software Engineering
> manual.
> Once a tool language is selected. We need a coding style and standard.
> We should choose an existing one, e.g.
> https://www.python.org/dev/peps/pep-0008/
> There should be tools to check the coding style automatically. I don't
> want the situation we have with the RTEMS sources. For Python there are
> plenty of tools, guides, and documentation available. We just have to
> pick some for the RTEMS Project and document this in the RTEMS Software
> Engineering manual.
> The compatible Python versions (e.g. 3.6+), coding style (e.g. black -l
> 80), documentation style (e.g. pydocstyle), test approach (standard
> Python unittest and unittest.mock), static analysis (e.g. mypy and
> pylint), code coverage, use of third-party packages, etc. need to be
> discussed with the RTEMS Project and the conclusions should be added to
> the RTEMS Software Engineering manual.
> Running the checkers, test suites, code coverage, etc. should be done
> though the build system (in rtems-tools this is waf). The Doorstop
> project is a good example how this can be set up.
> If you look at the current RTEMS Software Engineering manual you will
> find next to nothing with respect to Python code. You can set now the
> standards (after discussion on devel at rtems.org). You should do this
> before you send the first line of Python code for review.
I agree completely on the proposed approach with Python tools.
> Once the frame for Python development is settled. We need a high level
> description of the purpose of the tools, the inputs and the outputs.
> This high level description should be integrated in the RTEMS Project
> documentation. If you want to get things integrated in the RTEMS Project
> then you have make sure that it is good and general enough so that
> others can continue to work on it. In the worst case everything should
> be maintainable by the RTEMS Project without you in the future.
Describing the purpose, inputs and outputs, and high level description
should
go a long way to having a theory of operation for the tools. It is
important to
know what software engineering purpose the tool satisfies and its role in
the pre-qualification workflow.
Thanks for taking the time Sebastian for the nice write up.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200108/2b83bacd/attachment-0001.html>
