Error while building the rtems-libbsd
Utkarsh Rai
utkarsh.rai60 at gmail.com
Wed Jan 8 17:52:06 UTC 2020
So, finally after resetting almost every configuration on my system , and
rebasing the changes on the latest libsd commit I was able to build the
libbsd successfully on my host for beagle BSP.
I have been trying to get a test app to work for PRU drivers , as of now
the app cannot read the IRQs triggered as described here
<https://reviews.freebsd.org/D11959> (The issue seems to be with mmaps) .
Should I write the app from scratch or continue upon the current work?(And
in that case it would be helpful if I could get some pointers to solve the
mmap issue).
On Sun, Jan 5, 2020 at 2:27 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 05/01/2020 03:17, Utkarsh Rai wrote:
> > 1. For the libbbsd I have been
> > using https://github.com/nilhoel1/rtems-libbsd/tree/ti_pruss, this was
> > used by @Nils Hölscher <mailto:nilhoel1 at gmail.com> for his GSoc project(
> > I have talked to him about my errors, and this libbsd builds fine on his
> > host system).
> That version of libbsd is based on commit bc2ba9a9c of libbsd which has
> been added on 2019-07-09.
> > 2. The rtems and RSB versions are https://github.com/RTEMS/rtems.git
> > and https://github.com/RTEMS/rtems-source-builder.git
> Which commit did you check out? I would suggest to either check out one
> with about the same date as the libbsd commit. Or you should rebase the
> changes onto the latest libbsd commit. That depends on whether you want
> to just use the work or continue it.
> > 3. I have been using the beaglebone black BSP.
> > On Fri, Jan 3, 2020 at 2:12 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 01/01/2020 16:14, Utkarsh Rai wrote:
> > > I have been successful in building the rtems-libbsd using 'python3
> > > ./waf'. Although, I had to do some weird changes to some of the
> > files in
> > > the libbsd package. (These changes were done as there were several
> > build
> > > errors even after the 'python ./waf' command )
> > > 1. In the ../freebsd/sys/netinet/in_mcast.c
> > > and ../../freebsd/sys/netpfil/pf/if_pfsync.c files I had to change
> > > the IP_MIN_MEMBERSHIPS with IP_MAX_MEMBERSHIPS .
> > > 2. In the ../../freebsd/sys/netinet6/in6_mcast.c and
> > > .../freebsd/sys/netinet/ip_carp.c files I had to
> > > change IPV6_MIN_MEMBERSHIPS, to IPV6_MAX_MEMBERSHIPS,
> > > 3. In the ../testsuite/syscalls01/test_main.c I changed
> > the IPPROTO_SEP
> > > to IPPROTO_EGP .
> > > Now, I suspect that these changes will come back to bite me as I
> > proceed
> > > further as I have simply overwritten them based on build error
> > > messages. It would be helpful if the community can provide its
> > views on
> > > my changes and whether this is a bug or something that I am doing
> > wrong.
> > I would too expect that these changes are not a good idea. In normal
> > case libbsd builds without any trouble.
> > Can you give some more information about the exact versions you use:
> > - Which commit of libbsd are you trying to build?
> > - Which rtems commit do you use?
> > - Which tool version do you use? If RSB: Which commit?
> > - What BSP do you use?
> > Best regards
> > Christian
> > > On Tue, Dec 31, 2019 at 6:28 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > On 31/12/2019 12:41, Utkarsh Rai wrote:
> > > > My host system has an x-86_64 architecture with ubuntu-18.04
> > > running on
> > > > top of it, I have a python2 installed.
> > > > Interestingly enough, when I clean up the libbsd directory
> > and try to
> > > > build as a super-user, I have two observations:-
> > > Please note that building as super user is generally not a
> > good idea for
> > > any sane build environment. Although I have to say that in
> > this case it
> > > provided an interesting error output ...
> > > > 1. The build fails with the following error message:-
> > > > [1/4] Creating
> ///h/o/m/e///u/r/1/0///s/a/n/d/b/o/x///r/t/e/m/s/-/l/i/b/b/s/d///b/u/i/l/d///a/r/m/-/r/t/e/m/s/5/-/b/e/a/g/l/e/b/o/n/e/b/l/a/c/k/-/d/e/f/a/u/l/t/build-include/rtems/bsd/modules.h
> > > ... here. That looks like some join went horrible wrong. I
> > assume that
> > > there is some location in the build system where an array of
> paths
> > > should be joined but only one is given. Looks like a bug.
> > > > [2/4] Compiling rtemsbsd/rtems/generate_kvm_symbols
> > > > [3/4] Compiling
> > > testsuite/include/rtems/bsd/test/network-config.h.in
> > <http://network-config.h.in>
> > > > /bin/sh: 1:
> .//home/ur10/sandbox/rtems-libbsd/rtemsbsd/rtems/generate_kvm_symbols:
> > > The ./ in front is a bit odd here. Looks like an absolute path
> > which
> > > (for some reason) has been forced to be local...
> > > > not found
> > > > Now I have checked, and the file in question is present at
> its
> > > location.
> > > > 2. The traceback of the last calls is something like this:-
> > > > File
> "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Build.py",
> > > > line 100, in execute_build
> > > > self.compile()
> > > > File
> > > > line 174, in compile
> > > > self.store()
> > > > File
> > > > line 153, in store
> > > > Utils.writef(db+'.tmp',x,m='wb')
> > > > File
> "/home/ur10/sandbox/rtems-libbsd/.waf-2.0.13-4c5a17779813574907c253ab5418388d/waflib/Utils.py",
> > > > line 155, in writef
> > > > with open(fname,m)as f:
> > > > IOError: [Errno 2] No such file or directory:
> u'/home/ur10/sandbox/rtems-libbsd/build/arm-rtems5-beagleboneblack-default/.wafpickle-linux2-34017264-20.tmp'
> > > > If I am correct, this is a python exception for invalid file
> > > handling.
> > > > Since I have already removed the 'build' directory, I
> suppose
> > > the call
> > > > should be 'w+' or 'wb+' but this does not seem to be the
> > case. (I am
> > > > going out on a limb with this assumption, I may be wrong !)
> > > You are right that it's a python exception. Most likely it's a
> > follow up
> > > bug due to the wrong paths further up.
> > > > It would be very helpful if you could provide your views on
> the
> > > problem
> > > > and as to how I should proceed to resolve this.
> > > The solution is to find the bug in the path handling from
> > further above.
> > > As a workaround could you try to use python3? Some string
> > handling is
> > > different there so it might work or give a better error
> message.
> > > Just use
> > > python3 ./waf ...
> > > instead of only "waf" in every waf command line.
> > > > On Mon, Dec 30, 2019 at 7:19 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > > On 28/12/2019 18:43, Utkarsh Rai wrote:
> > > > > Hi,
> > > > > While building the rtems-libbsd as described here
> https://devel.rtems.org/browser/rtems-libbsd/README.waf?rev=b83012a9f9f1551d9d223c3126d0f43aba79db62
> > I
> > > > > was able to successfully configure the waf file as:-
> > > > > waf configure
> > > > > --prefix="/home/ur10/sandbox/rtems/5"
> > > > > --rtems-bsps=arm/beagleboneblack
> > > > > --buildset=buildset/default.ini
> > > > > But the build fails on the "waf" instruction with the
> > error
> > > - "Could
> > > > > not create the directory ///h".
> > > > > My path for the build is
> > PATH="~/sandbox/rtems/bin:$PATH",
> > > with the
> > > > > tools and the rtems-libbsd in the sandbox directory.
> > > > > It would be very kind of you if someone could point
> out as
> > > to what
> > > > is it
> > > > > that I am doing wrong.
> > > > > Thank You, Regards.
> > > > Hello Utkarsh Rai,
> > > > I now have seen that bug about two or three times on the
> > list.
> > > But I've
> > > > never been able to reproduce it. What host system are you
> > > using? Do you
> > > > have a python2 or a python3 as default python?
> > > > Sometimes it works to clean up the libbsd directory.
> Remove
> > > the "build"
> > > > directory and the ".waf2..." or ".waf3..." directory.
> Also
> > > remove any
> > > > "__pycache__" directories.
> > > > >From your call it seems that you use waf from your host
> > > system. Can you
> > > > try to use the waf version delivered with libbsd instead
> > > (using "./waf
> > > > configure ...")?
> > > > Best regards
> > > > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200108/cab7d4ae/attachment-0001.html>
