Glossary of Terms
Wed Jan 8 18:36:30 UTC 2020
On Tue, Jan 7, 2020 at 11:34 PM Sebastian Huber
> On 07/01/2020 17:21, Gedare Bloom wrote:
> > On Tue, Jan 7, 2020 at 2:09 AM Sebastian Huber
> >> On 03/01/2020 18:16, Joel Sherrill wrote:
> >>> On Fri, Jan 3, 2020, 10:22 AM Gedare Bloom <gedare at rtems.org
> >>> <mailto:gedare at rtems.org>> wrote:
> >>>      I prefer we use a centralized glossary/document to generate individual
> >>>      glossaries (via scripting or improving Sphinx). This will be a lot
> >>>      easier to maintain.
> >>> The DoD Architecture Framework (DoDAF) calls this an AV-2 which is a
> >>> singular artifacr across the project for consistencyt
> >>> http://acqnotes.com/acqnote/tasks/av-2-integrated-dictionary
> >>> That said, you need glossaries in documents and automating pulling
> >>> definitions and acronyms out automatically producing a glossary and
> >>> acronym list from the master AV-2 is desirable. No one wants to
> >>> reference a standalone glossary.
> >>> There can be issues if definitions change over time because the single
> >>> AV-2 can't deal with old and new. It gets confusing. I have seen a
> >>> project where the AV-2 included history like the Oxford English
> >>> Dictionary. It was dreadful.
> >>> That's a lot of background to say this isn't a RTEMS unique problem. A
> >>> central database of acronyms and definitions would be a good thing. If
> >>> grep is sufficient to find word use to trigger inclusion in a document
> >>> specific glossary, great.
> >> Good, so my proposal is this:
> >> 1. I move c-user/glossary.rst to common/glossary.rst and include this
> >> file as is in c-user.
> >> 2. The glossary.rst for the other documents is generated from
> >> common/glossary.rst based on the :term: usage. This can start simple,
> >> e.g. only look at the *.rst files in the document directory (e.g. no
> >> recursive includes).
> > Later when a new term is added for something not in c-user, then the
> > c-user should be updated to also derive its glossary with :term:?
> > (Before that, we might need to double check if the current glossary
> > terms are all defined/used in c-user with :term:.)
> The :term: is sparely used in c-user currently. It would require a bit
> of manual work to pull in all terms via this text role.
Understood, although adding those :term: from the existing glossary
seems like a good job for grep and sed to me.
> After one night, I don't like my proposal any more. I think it would be
> better to move the glossary terms to the RTEMS specification (e.g. in
> the RTEMS sources "spec/glossary/*.yml") and generate the glossary.rst
> for the documents with a script.  This gives us more flexibility and
> removes the need for the special parser code, see:
> https://lists.rtems.org/pipermail/devel/2020-January/056811.html
> The AV-2 mentioned by Joel wants the glossary terms in categories. We
> could add categories to the glossary specification items. This would be
> difficult with a master glossary in reST.
Yes, putting the glossary terms in a parseable structure like YAML
sounds sensible.
