Use specification items to generate documentation
Gedare Bloom
gedare at rtems.org
Wed Jan 8 18:49:50 UTC 2020
On Wed, Jan 8, 2020 at 7:55 AM Sebastian Huber
> Hello,
> for the RTEMS pre-qualification activity we need a specification of
> RTEMS. I would like to use this opportunity to move structured
> information which is present in hand written and hand formatted content
> in the RTEMS documentation into a structured data format (YAML).
> Documentation source files can be generated from the YAML files. Having
> information available in an easily machine readable format with
> meta-information gives us a lot of flexibility. For example to adjust
> the presentation we just have to change the generator program and not
> the hand written content. The presentation of things may depend on the
> standard of interest, e.g. ECSS, IEC 61508, ISO 26262, DO-178C, etc.
The proposal makes sense to me.
> To get started, I would like to use the glossary of terms and the
> application configuration as a use case. The conversion from hand
> written and hand formatted content to generated content needs three things:
> 1. A definition of the data format (YAML with Doorstop attributes)
> 2. The specification items in the defined data format.
> 3. A generator program which uses the specification items as input and
> outputs the documentation source files.
> The new build system introduced build specification items in the RTEMS
> sources under "spec/build". I would like to place all of the RTEMS
> specification under the "spec" directory. For the glossary I propose to
> use "spec/glossary". For the application configuration categories I
> propose "spec/cfg" and for the application configuration options
> "spec/cfg/opt". The layout of the application configuration items
> enables an easy reassignment of options to categories.
Will there also be specifications for RTEMS configuration? (I.e.,
options specified during RTEMS build such as --enable-networking.) If
so, maybe spec/cfg needs to be separated or subdirectoried for 'app'
vs 'rtems'?
> The definition of the data format should be added to the RTEMS Software
> Engineering manual to the Software Requirements Engineering chapter.
> The generator program should be written in Python and placed into the
> rtems-tools repository. The generator program needs paths to the RTEMS
> sources and the RTEMS documentation sources. The paths should be
> specified via the command line.
Similar paths are specified as options for other tools (e.g.,
rtems-test). Aim for consistency (and code reuse) in these interfaces.
> For a proof-of-concept please have a look at the attached two patches.
The .doorstop.yml are "hidden" files in typical *nix filesystems. Are
these automatically generated files and not to be modified or
necessarily read by humans? If so, fine, but otherwise they should not
be "hidden"
> What do you think of it?
Cursory glance of the patches makes sense. Is there a good way to
validate the format or error-check the configuration yml files, or it
is a manual job to create the file and check correctness?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
