.rtemsstack location on ARM
Will
nyphbl8d at gmail.com
Thu Jan 9 15:07:54 UTC 2020
Hi Sebastian,
The relocated vector table is also present in REGION_VECTOR as long as
bsp_vector_table_in_start_section is not defined in the linker script. It
sounds like this is expected behavior, though, so I'll adjust accordingly.
Thanks,
William
On Wed, Jan 8, 2020 at 11:58 PM Sebastian Huber <
> Hello,
> the region name REGION_VECTOR is a bit misleading. For ARMv-7M the
> vector table is in the .bsp_start_text section, see
> "bsps/arm/shared/start/start.S". In the REGION_VECTOR there is only the
> interrupt stack.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200109/ae1da030/attachment.html>
