[PATCH rtems-littelvgl] lv_conf.h: Enable user data.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Jan 10 06:16:28 UTC 2020
Just a reminder. If no one objects in the next few days, I'll push that
patch.
On 04/12/2019 12:47, Christian Mauderer wrote:
> This is usefull for passing driver objects arround and it doesn't add
> too much overhad for drivers that don't need it. Therefore enabling it
> by default seems like the better choice.
> lv_conf.h | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/lv_conf.h b/lv_conf.h
> index 5a0ea26..7453905 100644
> --- a/lv_conf.h
> +++ b/lv_conf.h
> @@ -152,7 +152,7 @@ typedef void * lv_fs_drv_user_data_t;
> #endif
> /*1: Add a `user_data` to drivers and objects*/
> -#define LV_USE_USER_DATA 0
> +#define LV_USE_USER_DATA 1
> * Image decoder and cache
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
