[PATCH v2] doc/raspberrypi: Added instructions for raspberrypi
Niteesh gsnb.gn at gmail.com
Sun Jan 12 18:57:40 UTC 2020
I haven't tested it, but it should be possible if using u-boot. I wanted to
try
this out but didn't have the time due to my university's tight academics. I
currently use a setup in which the kernel images are transferred through
serial,
but it is really slow.
I will try this out, once I am free.
On Mon, Jan 13, 2020 at 12:18 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> On Sun, Jan 12, 2020, 9:51 AM Jiri Gaisler <jiri at gaisler.se> wrote:
>> You should build devel/qemu4 with RSB, the older devel/qemu does not
>> build on newer systems ...
> +1
> Also is there anyway to boot RTEMS executables from the network? Manually
> replacing the kernel image in the SD is not conducive to automated testing.
> If you don't know how to do that, the doc looks ok without assuming the
> recommended changes happen. It would just be nice to know how to automate
> testing the Pi's.
>> Jiri.
>> On 1/12/20 4:48 PM, Niteesh wrote:
>> I can't build QEMU using RSB, there seems to be a problem with GLib(see
>> attachment)
>> but I had no problem building it from the source. Should I just mention
>> build qemu from
>> source?
>> On Tue, Jan 7, 2020 at 11:12 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>> I didn't use the QEMU build from RSB, I built it from the source
>>> directly for another project
>>> I'll try QEMU from RSB, and will also add instructions for it in a
>>> couple of days.
>>> On Tue, Jan 7, 2020 at 1:00 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Mon, Jan 6, 2020 at 11:25 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>> > Do you want to add a build section or just add in a statement that
>>>> states "it was built
>>>> > using xx version of RSB"?
>>>> Just a simple statement. Don't even  need to mention a specific
>>>> version, if they use RSB to build QEMU it should just work, right?
>>>> > On Mon, Jan 6, 2020 at 11:51 PM Gedare Bloom <gedare at rtems.org>
>>>> wrote:
>>>> >> On Mon, Jan 6, 2020 at 2:47 AM Christian Mauderer <
>>>> list at c-mauderer.de> wrote:
>>>> >> > Looks a lot better.
>>>> >> > On 05/01/2020 20:19, G S Niteesh wrote:
>>>> >> > > Added instructions to run examples on raspberrypi.
>>>> >> > >  user/bsps/arm/raspberrypi.rst | 74
>>>> >> > >  1 file changed, 73 insertions(+), 1 deletion(-)
>>>> >> > > diff --git a/user/bsps/arm/raspberrypi.rst
>>>> b/user/bsps/arm/raspberrypi.rst
>>>> >> > > index 4ef75bd..7eccca5 100644
>>>> >> > > --- a/user/bsps/arm/raspberrypi.rst
>>>> >> > > +++ b/user/bsps/arm/raspberrypi.rst
>>>> >> > > @@ -5,4 +5,76 @@
>>>> >> > >  raspberrypi
>>>> >> > > -TODO.
>>>> >> > > +This BSP supports `Raspberry Pi 1` and `Raspberry Pi 2`
>>>> currently.
>>>> >> > > +The support for `Raspberry Pi 3` is work under progress.
>>>> >> > > +The default bootloader on the raspberrypi which is used to boot
>>>> raspbian
>>>> >> > raspberrypi -> Raspberry Pi
>>>> >> > raspbian -> Raspbian
>>>> >> > > +or other OS can be also used to boot RTEMS. U-boot can also be
>>>> used.
>>>> >> > > +Setup SD card
>>>> >> > > +The Raspberry Pis have an unconventional booting mechanism. The
>>>> GPU
>>>> >> > > +boots first, initializes itself, runs the bootloader and starts
>>>> the CPU.
>>>> >> > > +The bootloader looks for a kernel image, by default the kernel
>>>> images must
>>>> >> > > +have a name of the form `kernel*.img` but this can be changed
>>>> by adding
>>>> >> > Please highlight all files in the same way. Other BSPs use the
>>>> following
>>>> >> > syntax:
>>>> >> >     The ``ticker.exe`` elf file must be translated ...
>>>> >> > So here it is:
>>>> >> > `kernel*.img` -> ``kernel*.img``
>>>> >> > > +`kernel=<img_name>` to config.txt.
>>>> >> > config.txt -> ``config.txt``
>>>> >> > > +You must provide the required files for the GPU to proceed.
>>>> These files
>>>> >> > > +can be downloaded from this
>>>> >> > > +`link <https://github.com/raspberrypi/firmware/tree/master/boot
>>>> >`_.
>>>> >> > I would suggest:
>>>> >> > ... can be downloaded from
>>>> >> > `the Raspberry Pi Firmware Repository
>>>> >> > <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
>>>> >> > I think you shouldn't break links so if this is too long you can
>>>> >> > exceptionally break the 80 character rule. It's done for other
>>>> links too.
>>>> >> > > +You can remove the kernel*.img if you want, but don't touch the
>>>> other files.
>>>> >> > kernel*.img -> ``kernel*.img``
>>>> >> > > +Copy these files in to a SD card with FAT filesystem.
>>>> >> > > +Kernel image
>>>> >> > > +The following steps show how to run hello.exe on a Raspberry Pi
>>>> 2.
>>>> >> > hello.exe -> ``hello.exe``
>>>> >> > > +The same instructions can be applied to Raspberry Pi 1 also.
>>>> >> > > +Other executables can be processed in a similar way.
>>>> >> > > +To create the kernel image:
>>>> >> > > +.. code-block:: none
>>>> >> > > +     arm-rtems5-objcopy -Obinary hello.exe kernel.img
>>>> >> > > +Copy the kernel image to the SD card.
>>>> >> > > +Make sure you have these lines below in your config.txt.
>>>> >> > > +     enable-uart=1
>>>> >> > > +     kernel_address=0x200000
>>>> >> > > +     kernel=kernel.img
>>>> >> > > +Testing
>>>> >> > Maybe change that chapter to "Emulation" or "Testing using QEMU".
>>>> When
>>>> >> > reading I had expected a hardware setup in this chapter after the
>>>> >> > SD-card has been prepared in the previous one.
>>>> >> > > +Qemu along with GDB can be used for debugging, but it only
>>>> supports
>>>> >> > Please always use the capitalization that the project uses. In
>>>> this case:
>>>> >> > Qemu -> QEMU
>>>> >> > > +``Raspberry Pi 2`` and the emulation is also incomplete. So
>>>> some of the
>>>> >> > Again: One formatting for one phrase. So that would be:
>>>> >> > ``Raspberry Pi 2`` -> Raspberry Pi 2
>>>> >> > > +features might not work as expected.
>>>> >> > > +Make sure you have latest version of qemu, because older ones
>>>> don't support
>>>> >> > qemu -> QEMU
>>>> >> My only other comment is if this version is built by RSB already it
>>>> is
>>>> >> worth mentioning here.
>>>> >> > > +Raspberry Pi.
>>>> >> > > +     qemu-system-arm -M raspi2 -m 1G -kernel hello.exe -serial
>>>> mon:stdio -nographic -S -s
>>>> >> > > +This starts qemu and creates a socket at port
>>>> ``localhost:1234`` for GDB to
>>>> >> > qemu -> QEMU
>>>> >> > > +connect.
>>>> >> > > +In a new terminal, run GDB using
>>>> >> > > +     arm-rtems5-gdb hello.exe
>>>> >> > > +     tar remote:1234
>>>> >> > > +     load
>>>> >> > > +This will connect GDB to qemu and load the application.
>>>> >> > qemu -> QEMU
>>>> >> > > +**Note**: Add ``set scheduler-locking on`` in GDB if you have
>>>> any issues
>>>> >> > > +running the examples.
>>>> >> > > \ No newline at end of file
>> devel mailing listdevel at rtems.orghttp://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200113/b75d9071/attachment-0001.html>
