Raspberrypi3: AUX Uart driver
Niteesh gsnb.gn at gmail.com
Mon Jan 13 10:16:41 UTC 2020
On Mon, Jan 13, 2020 at 1:38 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 12/01/2020 21:26, Niteesh wrote:
> > On Sun, Jan 12, 2020 at 11:42 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     Hello Niteesh,
> >     On 12/01/2020 16:06, Niteesh wrote:
> >     > The only issue, I faced while using this driver is the baud
> divisor is
> >     > calculated
> >     > by CLOCK_FREQ/(BAUD_RATE * 16) (*ns16550-context.c:68)*
> >     > but it should BAUD_DIV = (CLOCK_FREQ/(8 * BAUD_RATE)) - 1, for
> Rpi3.
> >     > For testing, I assigned the baud divisor to 270 (115200 bits/s) in
> >     > ns16550-context.c,
> >     > and everything works fine.
> >     Sounds great. In NS16550_GetBaudDivisor there is already a case where
> >     the baudDivisor is calculated differently (depending on
> >     ctx->has_precision_clock_synthesizer and
> >     ctx->has_fractional_divider_register). If none of the two cases are
> ok
> >     for the controller you could just add another one.
> > Can we pass in a function, which gets called, won't this be more
> > flexible? because
> > in the future if we have some other board that has a different
> > calculation for the baud rate
> > the function will take care of it.
> It's possible. Please make sure to be compatible with the current API.
> For example if the pointer is NULL you should call the legacy function
> instead.
I will be adding an extra field, a function pointer to ns16550_context,
the prototype of the function would be *uint32_t calculate_baud_divisor(
ns16550_context * )*
This is will calculate the baud divisor using its own formula and the
initial baud.
If this function is not NULL then it would be called inside
*NS16550_GetBaudDivisor* function,
> >     > For console selection, my plan is to search for the aux node using
> >     > compatible
> >     > property and if its status is enabled, then initialize the AUX
> >     uart and
> >     > set the BSP_output_char
> >     > to aux_output_char, else pl011_output_char. All this will be done
> >     inside
> >     > the uart_probe function,
> >     > except for the initialization of AUX which will be done in
> >     init_ctx_aux.
> >     > And finally, call the output char
> >     > function using *BSP_output_char. Do you have any neat way to do
> this?
> >     I don't have an example for a similar case at hand. So: No, no neat
> way
> >     that I can tell you.
> >     Before you start to write code: Please take a look at the different
> >     beagle variants what is possible. Is there a variant where AUX uart
> >     would be there but shouldn't be used as a console (one of the Zeros
> >     maybe or the compute module?). How does Raspbian or FreeBSD decide
> which
> >     port should be used? Maybe they decide based on the commandline.txt?
> In
> >     such a case it would be better to just initialize all active (in the
> >     fdt) serial ports and decide based on the commandline too.
> > The Documentation says the following:
> > *By default, on Raspberry Pis equipped with the wireless/Bluetooth*
> > *module (Raspberry Pi 3 and Raspberry Pi Zero W), **the PL011 UART is*
> > *connected to the Bluetooth module, while the mini UART is used as the
> > primary UART and*
> > *will have a Linux console on it. On all other models, the PL011 is used
> > as the primary UART.
> > *In Linux device terms, by default, /dev/ttyS0 refers to the mini UART,
> > and /dev/ttyAMA0 refers*
> > *to the PL011. The primary UART is the one assigned to the Linux
> > console, which depends on*
> > *the Raspberry Pi model as described above. There are also symlinks:
> > /dev/serial0, which always*
> > *refers to the primary UART (if enabled), and /dev/serial1, which
> > similarly always refers to the secondary UART (if enabled).*
> > I checked in all the DTB files, by decompiling them (files are
> > from https://github.com/raspberrypi/firmware/tree/master/boot).
> > In all board with support for wireless and bluetooth, the AuX is enabled
> > and serial0 points to it. So we could use serial0
> > to find the correct UART port. I think this is solid enough. So, should
> > I use this approach?
> Sounds OK. If possible please initialize the other UART too if it is
> enabled in the FDT. Although we don't support bluetooth yet maybe there
> will be support in the future or someone wants to do it in the application.
I will go with this method then.
> > Or if using the command line, then we need to move the link to
> > CONSOLE_DEVICE to console_initialize, and parse the
> > command line twice. If this is no problem, then we could use this
> > approach also.
> Would be possible too.
> >     > And why don't we have a function similar
> to *of_device_is_available*,
> >     > since there will be more and more
> >     > FDT based boards, this will be really helpful.
> >     I agree that it would be helpful. Seems that you just found a
> function
> >     that should be in a FDT framework.
> >     RTEMS currently only has the basic libfdt functions and some RTEMS
> >     specific ones. The of_... functions belong to the FreeBSD "Open
> Firmware
> >     Bus" which is an abstraction layer on top of FDT. It would be great
> to
> >     identify useful ones and port them or provide an RTEMS
> implementation.
> >     Like already discussed this could be part of a GSoC project.
> >     Best regards
> >     Christian
> >     > On Sun, Jan 5, 2020 at 12:57 AM Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     On 04/01/2020 09:32, Niteesh wrote:
> >     >     > We could now run RTEMS on Rpi3. I tried examples from the
> >     samples
> >     >     > section and they run
> >     >     > fine. But still, a lot of functionality has to tested since
> it
> >     >     uses the
> >     >     > RPI2 BSP. To test these examples
> >     >     > I used a simple driver for the AUX.
> >     >     > The documentation from BCM link
> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
> > (pg
> >     >     > no 10) states that
> >     >     >     *The implemented UART is not a 16650 compatible UART
> However
> >     >     as far
> >     >     >     as possible the first 8 control and status registers are
> >     laid out
> >     >     >     like a 16550 UART.*
> >     >     It also tells
> >     >         "Al 16550 register bits which are not supported can be
> >     written but
> >     >     will be ignored and read back as 0. All control bits for
> >     simple UART
> >     >     receive/transmit operations are available."
> >     >     So I would expect that not everything works like expected (for
> >     example
> >     >     setting DCD, DSR, DTR, RI - they are not there for the mini
> >     UART) but
> >     >     the basic stuff should work.
> >     >     > My question is can we use the existing ns16550 driver or
> >     should I
> >     >     create
> >     >     > a new one? I also checked the address of the registers the
> >     offsets
> >     >     don't
> >     >     > seem right to me, but someone should check and correct me if
> >     I am
> >     >     wrong.
> >     >     If you compare the registers in the existing driver
> >     >     (NS16550_RECEIVE_BUFFER, ... in ns16550_p.h) and the one in
> >     the BCM
> >     >     datasheet the registers look very similar (at least from the
> >     position /
> >     >     function). I haven't done a bit by bit comparison yet. Please
> >     note that
> >     >     you have to do a conversion between the defines and register
> >     addresses.
> >     >     The define gives you a register index for a 32bit register. So
> >     you have
> >     >     to multiply by 4 to get an address. The driver is designed
> >     that you
> >     >     provide a setRegister and getRegister function that can do this
> >     >     conversion.
> >     >     Where did you find differences?
> >     >     I would suggest to just try the driver.
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200113/5dc7feba/attachment.html>
