Cheap Small PC for RTEMS testing
Alan Cudmore
alan.cudmore at gmail.com
Tue Jan 14 02:39:56 UTC 2020
I wonder if any of these boards would be compatible:
https://up-board.org/
The Up Board that has the same form factor as a raspberry Pi looks like it
is $100 US:
https://up-shop.org/up-boards/272-up-board.html
A google shows this x86 32 bit processor, which is interesting:
http://www.86duino.com/?page_id=11
The 86duino "zero" is $39 US and has a 32 bit 300mhz x86 compatible CPU.
Says:
The 86Duino is a high performance and fully static 32-bit x86 processor
board compatible with Windows OS, Linux and most popular 32-bit RTOS
http://shop.dmp.com.tw/INT/products/23
Is RTEMS popular ? :)
On Mon, Jan 13, 2020 at 5:41 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I was looking for a recommendation as a cheap test PC option.
> I was considering the Minnowboard but it looks like minnowboard.org is
> dead which makes me a bit vervois. It has 64-bit BIOS. Did we ever get far
> enough where this might work?
> https://store.netgate.com/Turbot4.aspx
> Does anyone have any recommendation? Doesn't have to be fancy. Just a UART
> for console and no development required to make the PC work with RTEMS. :)
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200113/e73fcc1e/attachment.html>
