Raspberrypi3: AUX Uart driver
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Jan 15 07:55:15 UTC 2020
On 15/01/2020 06:27, Niteesh wrote:
> I commented out all FDT queries and everything works using ns16550 driver.
> How do I load FDT blob using uboot, I tried using the default
> bootloader, but
> it doesn't work. I tried the following command but they don't work
> fatload mmc 0 0x200000 kernel7.img
> fatload mmc 0 0x1000 bcm2710-rpi-3-b.dtb
> fdt addr 0x1000
> fdt boardsetup
> go 0x200080
Instead of "go 0x200080" try it with bootm with the syntax for linux:
https://www.denx.de/wiki/view/DULG/UBootCmdGroupExec#Section_5.9.4.2.
With the commands you used it should be a
   bootm 0x200000 - 0x1000
Best regards
Christian
> On Tue, Jan 14, 2020 at 9:40 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     I am finished with code, I tested it in QEMU emulator raspi2but it
>     doesn't work
>     when testing on real rpi3. I don't know if the problem is with
>     loading the FDT
>     or with my code?
>     How do I send the code, so that you can take a look at it?
>     On Tue, Jan 14, 2020 at 8:04 PM Niteesh <gsnb.gn at gmail.com
>         On Tue, Jan 14, 2020 at 1:57 PM Christian Mauderer
>         <christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>> wrote:
>             On 13/01/2020 19:04, Niteesh wrote:
>             > The ns16550_context already has a field named
>             baud_divisor, so if the
>             > user passes
>             > value for it, then we can skip the GetBaudDivisor function
>             and use that
>             > value instead.
>             > Is this approach okay?
>             Is the driver still able to handle different baud rates with
>             this? Does
>             the ioctl call for setting the baudrate work?
>         I didn't think about this, it won't work if we are using this
>         method. ns16550_set_attributes
>         calls ns16550_GetBaudDivisor, then I think we will have to stick
>         with the old method.
>             Best regards
>             Christian
>             > On Mon, Jan 13, 2020 at 3:46 PM Niteesh <gsnb.gn at gmail.com
>             > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>             >     On Mon, Jan 13, 2020 at 1:38 PM Christian Mauderer
>             <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>             >         On 12/01/2020 21:26, Niteesh wrote:
>             >         > On Sun, Jan 12, 2020 at 11:42 PM Christian Mauderer
>             >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>             <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>             >         > <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de>>>> wrote:
>             >         >     Hello Niteesh,
>             >         >     On 12/01/2020 16:06, Niteesh wrote:
>             >         >     > The only issue, I faced while using this
>             driver is the
>             >         baud divisor is
>             >         >     > calculated
>             >         >     > by CLOCK_FREQ/(BAUD_RATE * 16)
>             (*ns16550-context.c:68)*
>             >         >     > but it should BAUD_DIV = (CLOCK_FREQ/(8 *
>             BAUD_RATE)) -
>             >         1, for Rpi3.
>             >         >     > For testing, I assigned the baud divisor
>             to 270 (115200
>             >         bits/s) in
>             >         >     > ns16550-context.c,
>             >         >     > and everything works fine.
>             >         >     Sounds great. In NS16550_GetBaudDivisor
>             there is already a
>             >         case where
>             >         >     the baudDivisor is calculated differently
>             (depending on
>             >         >     ctx->has_precision_clock_synthesizer and
>             >         >     ctx->has_fractional_divider_register). If
>             none of the two
>             >         cases are ok
>             >         >     for the controller you could just add
>             another one.
>             >         > Can we pass in a function, which gets called,
>             won't this be more
>             >         > flexible? because
>             >         > in the future if we have some other board that
>             has a different
>             >         > calculation for the baud rate
>             >         > the function will take care of it.
>             >         It's possible. Please make sure to be compatible
>             with the
>             >         current API.
>             >         For example if the pointer is NULL you should call
>             the legacy
>             >         function
>             >         instead.
>             >     I will be adding an extra field, a function pointer to
>             ns16550_context,
>             >     the prototype of the function would be *uint32_t
>             >     calculate_baud_divisor( ns16550_context * )*
>             >     This is will calculate the baud divisor using its own
>             formula and
>             >     the initial baud.
>             >     If this function is not NULL then it would be called
>             inside
>             >     *NS16550_GetBaudDivisor* function,
>             >         >     > For console selection, my plan is to
>             search for the aux
>             >         node using
>             >         >     > compatible
>             >         >     > property and if its status is enabled,
>             then initialize
>             >         the AUX
>             >         >     uart and
>             >         >     > set the BSP_output_char
>             >         >     > to aux_output_char, else
>             pl011_output_char. All this
>             >         will be done
>             >         >     inside
>             >         >     > the uart_probe function,
>             >         >     > except for the initialization of AUX which
>             will be done in
>             >         >     init_ctx_aux.
>             >         >     > And finally, call the output char
>             >         >     > function using *BSP_output_char. Do you
>             have any neat
>             >         way to do this?
>             >         >     I don't have an example for a similar case
>             at hand. So:
>             >         No, no neat way
>             >         >     that I can tell you.
>             >         >     Before you start to write code: Please take
>             a look at the
>             >         different
>             >         >     beagle variants what is possible. Is there a
>             variant where
>             >         AUX uart
>             >         >     would be there but shouldn't be used as a
>             console (one of
>             >         the Zeros
>             >         >     maybe or the compute module?). How does
>             Raspbian or
>             >         FreeBSD decide which
>             >         >     port should be used? Maybe they decide based
>             on the
>             >         commandline.txt? In
>             >         >     such a case it would be better to just
>             initialize all
>             >         active (in the
>             >         >     fdt) serial ports and decide based on the
>             commandline too.
>             >         > The Documentation says the following:
>             >         > *By default, on Raspberry Pis equipped with the
>             >         wireless/Bluetooth*
>             >         > *module (Raspberry Pi 3 and Raspberry Pi Zero
>             W), **the PL011
>             >         UART is*
>             >         > *connected to the Bluetooth module, while the
>             mini UART is
>             >         used as the
>             >         > primary UART and*
>             >         > *will have a Linux console on it. On all other
>             models, the
>             >         PL011 is used
>             >         > as the primary UART.
>             >         > *In Linux device terms, by default, /dev/ttyS0
>             refers to the
>             >         mini UART,
>             >         > and /dev/ttyAMA0 refers*
>             >         > *to the PL011. The primary UART is the one
>             assigned to the Linux
>             >         > console, which depends on*
>             >         > *the Raspberry Pi model as described above.
>             There are also
>             >         symlinks:
>             >         > /dev/serial0, which always*
>             >         > *refers to the primary UART (if enabled), and
>             /dev/serial1, which
>             >         > similarly always refers to the secondary UART
>             (if enabled).*
>             >         > I checked in all the DTB files, by decompiling
>             them (files are
>             from https://github.com/raspberrypi/firmware/tree/master/boot).
>             >         > In all board with support for wireless and
>             bluetooth, the AuX
>             >         is enabled
>             >         > and serial0 points to it. So we could use serial0
>             >         > to find the correct UART port. I think this is
>             solid enough.
>             >         So, should
>             >         > I use this approach?
>             >         Sounds OK. If possible please initialize the other
>             UART too if it is
>             >         enabled in the FDT. Although we don't support
>             bluetooth yet
>             >         maybe there
>             >         will be support in the future or someone wants to
>             do it in the
>             >         application.
>             >     I will go with this method then.
>             >         > Or if using the command line, then we need to
>             move the link to
>             >         > CONSOLE_DEVICE to console_initialize, and parse the
>             >         > command line twice. If this is no problem, then
>             we could use this
>             >         > approach also.
>             >         Would be possible too.
>             >         >     > And why don't we have a function similar
>             >         to *of_device_is_available*,
>             >         >     > since there will be more and more
>             >         >     > FDT based boards, this will be really helpful.
>             >         >     I agree that it would be helpful. Seems that
>             you just
>             >         found a function
>             >         >     that should be in a FDT framework.
>             >         >     RTEMS currently only has the basic libfdt
>             functions and
>             >         some RTEMS
>             >         >     specific ones. The of_... functions belong
>             to the FreeBSD
>             >         "Open Firmware
>             >         >     Bus" which is an abstraction layer on top of
>             FDT. It would
>             >         be great to
>             >         >     identify useful ones and port them or
>             provide an RTEMS
>             >         implementation.
>             >         >     Like already discussed this could be part of
>             a GSoC project.
>             >         >     Best regards
>             >         >     Christian
>             >         >     > On Sun, Jan 5, 2020 at 12:57 AM Christian
>             Mauderer
>             >         >     <list at c-mauderer.de
>             >         >     > <mailto:list at c-mauderer.de
>             <mailto:list at c-mauderer.de>>>>> wrote:
>             >         >     >     On 04/01/2020 09:32, Niteesh wrote:
>             >         >     >     > We could now run RTEMS on Rpi3. I
>             tried examples
>             >         from the
>             >         >     samples
>             >         >     >     > section and they run
>             >         >     >     > fine. But still, a lot of
>             functionality has to
>             >         tested since it
>             >         >     >     uses the
>             >         >     >     > RPI2 BSP. To test these examples
>             >         >     >     > I used a simple driver for the AUX.
>             >         >     >     > The documentation from BCM link
>                <https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf> (pg
>             >         >     >     > no 10) states that
>             >         >     >     >     *The implemented UART is not a 16650
>             >         compatible UART However
>             >         >     >     as far
>             >         >     >     >     as possible the first 8 control
>             and status
>             >         registers are
>             >         >     laid out
>             >         >     >     >     like a 16550 UART.*
>             >         >     >     It also tells
>             >         >     >         "Al 16550 register bits which are
>             not supported
>             >         can be
>             >         >     written but
>             >         >     >     will be ignored and read back as 0.
>             All control bits for
>             >         >     simple UART
>             >         >     >     receive/transmit operations are
>             available."
>             >         >     >     So I would expect that not everything
>             works like
>             >         expected (for
>             >         >     example
>             >         >     >     setting DCD, DSR, DTR, RI - they are
>             not there for
>             >         the mini
>             >         >     UART) but
>             >         >     >     the basic stuff should work.
>             >         >     >     > My question is can we use the
>             existing ns16550
>             >         driver or
>             >         >     should I
>             >         >     >     create
>             >         >     >     > a new one? I also checked the
>             address of the
>             >         registers the
>             >         >     offsets
>             >         >     >     don't
>             >         >     >     > seem right to me, but someone should
>             check and
>             >         correct me if
>             >         >     I am
>             >         >     >     wrong.
>             >         >     >     If you compare the registers in the
>             existing driver
>             >         >     >     (NS16550_RECEIVE_BUFFER, ... in
>             ns16550_p.h) and the
>             >         one in
>             >         >     the BCM
>             >         >     >     datasheet the registers look very
>             similar (at least
>             >         from the
>             >         >     position /
>             >         >     >     function). I haven't done a bit by bit
>             comparison
>             >         yet. Please
>             >         >     note that
>             >         >     >     you have to do a conversion between
>             the defines and
>             >         register
>             >         >     addresses.
>             >         >     >     The define gives you a register index
>             for a 32bit
>             >         register. So
>             >         >     you have
>             >         >     >     to multiply by 4 to get an address.
>             The driver is
>             >         designed
>             >         >     that you
>             >         >     >     provide a setRegister and getRegister
>             function that
>             >         can do this
>             >         >     >     conversion.
>             >         >     >     Where did you find differences?
>             >         >     >     I would suggest to just try the driver.
>             >         > _______________________________________________
>             >         > devel mailing list
>             >         > devel at rtems.org <mailto:devel at rtems.org>
>             <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>             >         > http://lists.rtems.org/mailman/listinfo/devel
>             >         embedded brains GmbH
>             >         Herr Christian Mauderer
>             >         Dornierstr. 4
>             >         D-82178 Puchheim
>             >         Germany
>             >         email: christian.mauderer at embedded-brains.de
>             >         Phone: +49-89-18 94 741 - 18
>             >         Fax:   +49-89-18 94 741 - 08
>             >         PGP: Public key available on request.
>             >         Diese Nachricht ist keine geschäftliche Mitteilung
>             im Sinne des
>             >         EHUG.
>             Dornierstr. 4
>             D-82178 Puchheim
>             Germany
>             Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>             des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
