[PATCH] libchip/ns16550: Allow user calculate baud divisor
Christian Mauderer list at c-mauderer.de
Thu Jan 16 19:48:00 UTC 2020
On 15/01/2020 12:50, G S Niteesh wrote:
> This patch will allow the user to pass a function to calculate
> the baud divisor.
> This is will allow for more flexibility, since for some BSP's
> like raspberrypi, the calculate of baud divisor is different
> from what is in the current driver.
>  bsps/include/libchip/ns16550.h           | 11 ++++++++---
>  bsps/shared/dev/serial/ns16550-context.c |  6 ++++--
>  2 files changed, 12 insertions(+), 5 deletions(-)
> diff --git a/bsps/include/libchip/ns16550.h b/bsps/include/libchip/ns16550.h
> index f053c8767f9..ab7992fd30b 100644
> --- a/bsps/include/libchip/ns16550.h
> +++ b/bsps/include/libchip/ns16550.h
> @@ -1,6 +1,6 @@
>   *  @file
Please don't change lines that don't concern the target of your patch.
If you want to fix the white space please do so in an extra patch.
By the way: You can also send patch sets. Just pass all patches to "git
send-email". Then git will number patches that belong together (like
this and the AUX uart driver). That makes it easier to apply all in the
right order.
> @@ -60,7 +60,11 @@ typedef uint8_t (*ns16550_get_reg)(uintptr_t port, uint8_t reg);
>  typedef void (*ns16550_set_reg)(uintptr_t port, uint8_t reg, uint8_t value);
> -typedef struct {
> +typedef struct ns16550_context ns16550_context;
> +typedef uint32_t (*ns16550_calculate_baud_divisor)(ns16550_context *ctx, uint32_t baud);
> +struct ns16550_context{
>    rtems_termios_device_context base;
>    ns16550_get_reg get_reg;
>    ns16550_set_reg set_reg;
> @@ -70,6 +74,7 @@ typedef struct {
>    uint32_t initial_baud;
>    bool has_fractional_divider_register;
>    bool has_precision_clock_synthesizer;
> +  ns16550_calculate_baud_divisor calculate_baud_divisor;
>    uint8_t modem_control;
>    uint8_t line_control;
>    uint32_t baud_divisor;
> @@ -78,7 +83,7 @@ typedef struct {
>    size_t out_current;
>    const char *out_buf;
>    rtems_termios_tty *tty;
> -} ns16550_context;
>  extern const rtems_termios_device_handler ns16550_handler_interrupt;
>  extern const rtems_termios_device_handler ns16550_handler_polled;
> diff --git a/bsps/shared/dev/serial/ns16550-context.c b/bsps/shared/dev/serial/ns16550-context.c
> index ce55b8309cc..70e73fc8c93 100644
> --- a/bsps/shared/dev/serial/ns16550-context.c
> +++ b/bsps/shared/dev/serial/ns16550-context.c
> @@ -1,6 +1,6 @@
>   *  @file
Again: Please only change if it is necessary for your patch.
>   *  This file contains the TTY driver for the National Semiconductor NS16550.
>   *  This part is widely cloned and second sourced.  It is found in a number
> @@ -112,6 +112,8 @@ static uint32_t NS16550_GetBaudDivisor(ns16550_context *ctx, uint32_t baud)
>        NS16550_FRACTIONAL_DIVIDER,
>        fractionalDivider
> +  } else if (ctx->calculate_baud_divisor != NULL) {
> +    baudDivisor = ctx->calculate_baud_divisor(ctx, baud);
>    return baudDivisor;
> @@ -165,7 +167,7 @@ bool ns16550_probe(rtems_termios_device_context *base)
>    ctx->modem_control = SP_MODEM_IRQ;
> -  pNS16550 = ctx->port;
> +  pNS16550 = ctx->port;
>    setReg   = ctx->set_reg;
>    getReg   = ctx->get_reg;
