[PATCH] bsp/raspberrypi: AUX uart driver
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jan 17 14:34:20 UTC 2020
On 17/01/2020 14:57, Niteesh wrote:
> On Fri, Jan 17, 2020 at 1:40 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 15/01/2020 13:05, G S Niteesh wrote:
>     > This patch adds the driver for aux driver present in Raspberry
>     > Pi 3 and above, this uart is currently used as the primary uart.
>     Most of the time UART is written all upper case.
>     > The AUX uart is similar to ns16550, it uses the libchip/ns16550
>     > driver.
>     >  bsps/arm/raspberrypi/console/console-config.c | 113
>     >  bsps/arm/raspberrypi/include/bsp/usart.h      |   1 +
>     >  2 files changed, 107 insertions(+), 7 deletions(-)
>     > diff --git a/bsps/arm/raspberrypi/console/console-config.c
>     b/bsps/arm/raspberrypi/console/console-config.c
>     > index 48c4c6a3ec7..6ff018fb8ef 100644
>     > --- a/bsps/arm/raspberrypi/console/console-config.c
>     > +++ b/bsps/arm/raspberrypi/console/console-config.c
>     > @@ -24,6 +24,7 @@
>     >  #include <libchip/serial.h>
>     >  #include <libfdt.h>
>     > +#include <libchip/ns16550.h>
>     >  #include <bspopts.h>
>     >  #include <bsp/usart.h>
>     > @@ -34,35 +35,103 @@
>     >  #include <bsp/console-termios.h>
>     >  #include <bsp/fdt.h>
>     >  #include <bsp/fatal.h>
>     > +#include <bsp/gpio.h>
>     > +#include <bsp/rpi-gpio.h>
>     > + * UART0 - PL011
>     > + * UART1 - AUX UART
>     Isn't it called "Mini UART" in the peripheral manual? That would affect
>     all following "aux" too.
>     >  #define UART0     "/dev/ttyS0"
>     > +#define UART1     "/dev/ttyS1"
> Should I leave them as UART0 and UART1 or change them
> to their respective peripheral names?
I would rename them. Random numbers are allways a bit confusing.
>     >  #define FBCONS    "/dev/fbcons"
>     >  arm_pl011_context pl011_context;
>     > +ns16550_context aux_context;
>     >  rpi_fb_context fb_context;
>     > -static void output_char_serial(char c)
>     > +static void output_char_pl011(char c)
>     >    arm_pl011_write_polled(&pl011_context.base, c);
>     > +static void output_char_aux(char c)
>     > +  ns16550_polled_putchar(&aux_context.base, c);
>     >  void output_char_fb(char c)
>     >    fbcons_write_polled(&fb_context.base, c);
>     > +static uint8_t raspberrypi_get_reg(uintptr_t port, uint8_t index)
>     Is it a "raspberrypi_get_reg" or a "mini_uart_get_reg"?
>     > +  volatile uint32_t *val = (volatile uint32_t *)port + index;
>     > +  return (uint8_t) *val;
>     > +static void raspberrypi_set_reg(uintptr_t port, uint8_t index,
>     uint8_t val)
>     > +  volatile uint32_t *reg = (volatile uint32_t *)port + index;
>     > +  *reg = val;
>     >  static void init_ctx_arm_pl011(
>     >    const void *fdt,
>     >    int node
>     >    arm_pl011_context *ctx = &pl011_context;
>     > -  rtems_termios_device_context_initialize(&ctx->base, "UART");
>     > +  rtems_termios_device_context_initialize(&ctx->base, "UART 0");
>     Maybe "PL011UART" would be a better name?
>     >    ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
>     > +static uint32_t calculate_baud_divisor(
>     > +  ns16550_context *ctx,
>     > +  uint32_t baud
>     > +  uint32_t baudDivisor = (ctx->clock / (8 * baud)) - 1;
>     > +  return baudDivisor;
>     > +static void init_ctx_aux(
>     > +  const void *fdt,
>     > +  int node
>     > +  const char *status;
>     > +  int len;
>     > +  ns16550_context *ctx = &aux_context;
>     Although your ctx is a global variable and therefore (most likely) zero
>     already: If you don't write all fields of a context (you missed for
>     example has_fractional_divider_register) please set it to zero
>     explicitly (with memset). It would be possible that someone allocates
>     that context for example for rpi4 and forgets it. That leads to odd
>     effects that only happen sometimes.
>     > +  rtems_termios_device_context_initialize(&ctx->base, "UART 1");
>     I would suggest "MiniUART" for the name. It's just easier if you debug
>     something and you get told "it's this or that hardware module" without
>     having to look at some mapping.
>     > +  status = fdt_getprop(fdt, node, "status", &len);
>     > +  if (status == NULL){
>     > +    return ;
>     > +  if ( strcmp(status, "disabled") == 0 ) {
>     > +    return ;
>     You could put that into one if. Would be a bit shorter to read:
>     if (status == NULL || strcmp(status, "disabled") == 0) {
>             return;
>     > +  ctx->port = (uintptr_t) raspberrypi_get_reg_of_node(fdt, node);
>     > +  ctx->initial_baud = AUX_DEFAULT_BAUD;
>     > +  ctx->clock = BCM2835_CLOCK_FREQ;
>     > +  ctx->calculate_baud_divisor = calculate_baud_divisor;
>     > +  ctx->get_reg = raspberrypi_get_reg;
>     > +  ctx->set_reg = raspberrypi_set_reg;
>     > +  rtems_gpio_bsp_select_specific_io(0, 14, RPI_ALT_FUNC_5, NULL);
>     > +  rtems_gpio_bsp_select_specific_io(0, 15, RPI_ALT_FUNC_5, NULL);
>     > +  rtems_gpio_bsp_set_resistor_mode(0, 14, NO_PULL_RESISTOR);
>     > +  rtems_gpio_bsp_set_resistor_mode(0, 15, NO_PULL_RESISTOR);
>     > +  BCM2835_REG(AUX_ENABLES) |= 0x1;
>     > +  ns16550_probe(&ctx->base);
>     >  static void register_fb( void )
>     >    if (fbcons_probe(&fb_context.base) == true) {
>     > @@ -87,16 +156,27 @@ static void console_select( void )
>     >          link(FBCONS, CONSOLE_DEVICE_NAME);
>     >          return ;
>     > +    } else if ( strncmp( opt, UART1, sizeof(UART1) - 1 ) == 0) {
>     Hm. UART1 is "/dev/ttyS1". Linux calls the miniUART "/dev/ttyS0" and the
>     PL011 "/dev/ttyAMA0", right? So the command line will be different for
>     Linux and RTEMS?
>     I think I would preferre to use the Linux names.
>     > +      BSP_output_char = output_char_aux;
>     > +      link(UART1, CONSOLE_DEVICE_NAME);
>     > +    } else if ( strncmp( opt, UART0, sizeof(UART0) - 1 ) == 0) {
>     > +      BSP_output_char = output_char_pl011;
>     > +      link(UART0, CONSOLE_DEVICE_NAME);
>     > -  BSP_output_char = output_char_serial;
>     > -  link(UART0, CONSOLE_DEVICE_NAME);
>     > +   * If no command line option was given, default to AUX uart.
>     Is it really a good idea to default to the AUX uart? The BSP is still
>     named raspberrypi2. So I think the default should match the RPi2.
>     >  static void uart_probe(void)
>     >    static bool initialized = false;
>     >    const void *fdt;
>     > +  const char *console;
>     > +  int len;
>     >    int node;
>     >    if ( initialized ) {
>     > @@ -104,17 +184,29 @@ static void uart_probe(void)
>     >    fdt = bsp_fdt_get();
>     > -  node = fdt_node_offset_by_compatible(fdt, -1,
>     "brcm,bcm2835-pl011");
>     > +  node = fdt_node_offset_by_compatible(fdt, -1,
>     >    init_ctx_arm_pl011(fdt, node);
>     "brcm,bcm2835-aux-uart");
>     > +  init_ctx_aux(fdt, node);
>     > +  node = fdt_path_offset(fdt, "/aliases");
>     > +  console = fdt_getprop(fdt, node, "serial0", &len);
>     > +  if (strcmp(console, "/soc/serial at 7e215040") == 0) {
>     > +  }else {
>     >    initialized = true;
>     >  static void output_char(char c)
>     >    uart_probe();
>     > -  output_char_serial(c);
>     > +  (*BSP_output_char)(c);
>     >  rtems_status_code console_initialize(
>     > @@ -133,6 +225,13 @@ rtems_status_code console_initialize(
>     >      &pl011_context.base
>     > +  rtems_termios_device_install(
>     > +    UART1,
>     > +    &ns16550_handler_polled,
>     > +    NULL,
>     > +    &aux_context.base
>     >    register_fb();
>     >    console_select();
>     > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>     b/bsps/arm/raspberrypi/include/bsp/usart.h
>     > index abbf53626c9..c73cebc86bd 100644
>     > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>     > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>     > @@ -33,6 +33,7 @@ extern "C" {
>     >  #endif /* __cplusplus */
>     >  #define PL011_DEFAULT_BAUD 115000
>     > +#define AUX_DEFAULT_BAUD   115200
> I have also changed AUX_DEFAULT_BAUD to MINI_UART_DEFAULT_BAUD
> is that okay?
Yes.
>     >  #define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>     >  #ifdef __cplusplus
> I fixed everthing else, that you mentioned.
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
