[PATCH] Use EAGAIN for POSIX mq wait in ISR error
Martin Erik Werner
martinerikwerner at gmail.com
Sun Jan 19 15:11:38 UTC 2020
Modify the status code returned by _CORE_message_queue_Submit() when it
detects a wait bout to happen in an ISR (which would be deadly) to
return a status which translated to EAGAIN instead of ENOMEM.
(This is only relevant for POSIX message queues, since classic message
queues cannot block on send.)
The motivation is to match the "most related" errno value returned from
mq_send() and mq_timedsend() according to POSIX, via opengroup
[EAGAIN]
The O_NONBLOCK flag is set in the message queue description
associated with mqdes, and the specified message queue is full.
or via the RTEMS POSIX users documentation
EAGAIN
The message queue is non-blocking, and there is no room on the queue
for another message as specified by the mq_maxmsg.
Neither of these matches the case ofi avoided ISR wait perfectly, but
they seem to be the closest equivalent, unless it is desirable to keep a
new non-standard error for this case. It is presumed that this is not
desirable.
The previously returned ENOMEM error value is not documented in either
the opengroup or the RTEMS POSIX uses documentation.
Based on the discussion in:
https://lists.rtems.org/pipermail/devel/2020-January/056891.html
Message-Id: <CAF9ehCW5P12ZkZja4UPYTbdBFUyC1VKVL-tU7nyUtvK1Lz2Z3g at mail.gmail.com>
cpukit/include/rtems/score/status.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/score/status.h b/cpukit/include/rtems/score/status.h
index 34002559aa..fe1f0e87e6 100644
--- a/cpukit/include/rtems/score/status.h
+++ b/cpukit/include/rtems/score/status.h
@@ -90,7 +90,7 @@ typedef enum {
STATUS_MESSAGE_INVALID_SIZE =
STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, EMSGSIZE ),
STATUS_MESSAGE_QUEUE_WAIT_IN_ISR =
- STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, ENOMEM ),
+ STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, EAGAIN ),
STATUS_MESSAGE_QUEUE_WAS_DELETED =
STATUS_BUILD( STATUS_CLASSIC_OBJECT_WAS_DELETED, EBADF ),
STATUS_MINUS_ONE =
2.20.1
