[PATCH 1/3] common: Add URLs to manuals
Gedare Bloom
gedare at rtems.org
Mon Jan 20 17:16:34 UTC 2020
On Sun, Jan 19, 2020 at 10:35 PM Chris Johns <chrisj at rtems.org> wrote:
> On 20/1/20 4:38 pm, Chris Johns wrote:
> > On 3/1/20 11:31 pm, Sebastian Huber wrote:
> >> common/rtemsdomain.py | 14 +++++++++++++-
> >> 1 file changed, 13 insertions(+), 1 deletion(-)
> >> diff --git a/common/rtemsdomain.py b/common/rtemsdomain.py
> >> index 49d0728..018e7ed 100644
> >> --- a/common/rtemsdomain.py
> >> +++ b/common/rtemsdomain.py
> >> @@ -43,7 +43,19 @@ role_url = {
> >> "review": ("Gerrit Code Review", "https://review.rtems.org/"),
> >> "bugs": ("Bugs Database", "https://devel.rtems.org/wiki/Bugs/"),
> >> "gsoc": ("Google Summer of Code", "https://devel.rtems.org/wiki/GSoC/"),
> >> - "socis": ("ESA SOCIS", "https://devel.rtems.org/wiki/SOCIS/")
> >> + "socis": ("ESA SOCIS", "https://devel.rtems.org/wiki/SOCIS/"),
> >> + "bsp-howto": ("RTEMS BSP and Driver Guide", "https://docs.rtems.org/branches/master/bsp-howto/index.html"),
> >> + "cpu-supplement": ("RTEMS CPU Architecture Supplement", "https://docs.rtems.org/branches/master/cpu-supplement/index.html"),
> >> + "c-user": ("RTEMS Classic API Guide", "https://docs.rtems.org/branches/master/c-user/index.html"),
> >> + "develenv": ("RTEMS Development Environment Guide", "https://docs.rtems.org/branches/master/develenv/index.html"),
> >> + "eclipse": ("RTEMS Eclipse Manual", "https://docs.rtems.org/branches/master/eclipse/index.html"),
> >> + "eng": ("RTEMS Software Engineering", "https://docs.rtems.org/branches/master/eng/index.html"),
> >> + "filesystem": ("RTEMS Filesystem Design Guide", "https://docs.rtems.org/branches/master/filesystem/index.html"),
> >> + "networking": ("RTEMS Networking User Manual", "https://docs.rtems.org/branches/master/networking/index.html"),
> >> + "posix-compliance": ("RTEMS POSIX 1003.1 Compliance Guide", "https://docs.rtems.org/branches/master/posix-compliance/index.html"),
> >> + "posix-users": ("RTEMS POSIX API Guide", "https://docs.rtems.org/branches/master/posix-users/index.html"),
> >> + "shell": ("RTEMS Shell Guide", "https://docs.rtems.org/branches/master/shell/index.html"),
> >> + "user": ("RTEMS User Manual", "https://docs.rtems.org/branches/master/user/index.html"),
> > Oh, please do not add references to the online docs. This is rather fragile, ie
> > branches are broken.
> > I hope it has not been pushed.
> It has been. This need to be reverted.
I don't quite understand the complaint. The links are "working" for now?
> Chris
> devel mailing list
> devel at rtems.org
