Raspberry Pi test report
Alan Cudmore
alan.cudmore at gmail.com
Tue Jan 21 20:31:08 UTC 2020
I can try QEMU. Is there a quick pointer to the QEMU parameters needed
to run a Pi2 image?
Alan
On Tue, Jan 21, 2020 at 3:22 PM Christian Mauderer <list at c-mauderer.de> wrote:
> Does the same error occur on the Pi2 Qemu? In that case you could use it
> for proper debugging.
> On 21/01/2020 03:35, Alan Cudmore wrote:
> > I don't really have a debug setup.. I'm just using printk for now. But
> > I have a pretty efficient setup where I can add a few printk
> > statements, rebuild and copy the smp01.exe sample over to the SD card.
> > I use this board:
> > https://www.adafruit.com/product/3589
> > It lets me connect the serial port using a USB cable, and it also
> > supplies power and provides a switch. I can pop the SD card in, flip
> > the switch and watch the UART output.
> > (Edit, make, objcopy, move card to pi, and flip the power switch).
> > The board provides plenty of power for the single core models through
> > the host USB port. I should double check that it's providing enough
> > power for the Pi2 before I spend too much time!
> > Here is an example of my latest output where the SMP initialization is
> > not completing:
> > RTEMS RPi 2B 1.1 (1GB) [00a21041]
> > in _SMP_Handler_initialize
> > in _SMP_Handler_initialize, max processors = 4
> > in _SMP_Handler_initialize - calling _CPU_SMP_Initialize
> > in _CPU_SMP_Initialize
> > in _SMP_Handler_initialize - _SMP_Processor_maximum = 4
> > in _SMP_Handler_initialize - calling _SMP_Start_processors
> > In _SMP_Start_processors
> > In _SMP_Start_processors - index = 0
> > In _SMP_Start_processors - index = 1
> > In _SMP_Start_processors - calling _CPU_SMP_Start_processor
> > in _CPU_SMP_Start_processor
> > in _CPU_SMP_Start_processor - wait for secondary processor to complete
> > in Per_CPU_State_wait_for_non_initial_state
> > CPU state = 0
> > in Per_CPU_State_wait_for_non_initial_state - about to call
> > _CPU_SMP_Processor_event_receive in while loop
> > in Per_CPU_State_wait_for_non_initial_state - after
> > CPU state after = 0
> > Alan
> > On Mon, Jan 20, 2020 at 9:03 PM Niteesh <gsnb.gn at gmail.com> wrote:
> >> What is your debugging setup? It would be really helpful for my future works on Rpi3.
> >> Thanks,
> >> Niteesh
> >> On Tue, 21 Jan, 2020, 7:23 AM Alan Cudmore, <alan.cudmore at gmail.com> wrote:
> >>> A little more information on my Raspberry Pi 2 SMP tests:
> >>> The BSP startup is getting to this loop:
> >>> https://git.rtems.org/rtems/tree/cpukit/score/src/percpustatewait.c#n49
> >>> (In the function _Per_CPU_State_wait_for_non_initial_state)
> >>> In the while loop on line 49, the CPU state is PER_CPU_STATE_INITIAL (0).
> >>> The while loop calls _CPU_SMP_Processor_event_receive() and returns,
> >>> but the state is still 0
> >>> It calls _CPU_SMP_Processor_event_receive() again and does not return.
> >>> I'm reading up on the defines in percpu.h (comments for the defines
> >>> are very helpful by the way)
> >>> Based on what I can tell in the comments, the boot CPU will wait in
> >>> until the secondary processors complete their primary initialization
> >>> and transition to
> >>> PER_CPU_STATE_READY_TO_START_MULTITASKING.
> >>> Next is to figure out why the secondary processors are not
> >>> transitioning or possibly why events are not occurring?
> >>> Alan
> >>> On Mon, Jan 20, 2020 at 6:25 PM Chris Johns <chrisj at rtems.org> wrote:
> >>>> On 21/1/20 10:20 am, Alan Cudmore wrote:
> >>>>> As it turns out the latest RTEMS master may need some of the dtb
> >>>>> and/or overlay files in the raspberry pi SD card. But the updated
> >>>>> instructions that Niteesh submitted for the raspberrypi BSP should
> >>>>> still be valid.
> >>>> Great.
> >>>>> Either way, we should be able to automate it. A firmware release on
> >>>>> Github is ~180 megabytes. If you clone the whole repository, it's 10+
> >>>>> Gigabytes, probably because you get every binary release.
> >>>> Ouch. If we list the needed files, even if there is a few, I can fetch them from
> >>>> github and avoid a full clone. We would need to settle on a specific hash or
> >>>> version but that is not a bad thing.
> >>>>> I'm trying to troubleshoot the RPi 2 SMP a little bit now. Non SMP
> >>>>> code seems to work on the Pi 2, but when you have an example with
> >>>>> #define CONFIGURE_MAXIMUM_PROCESSORS 4
> >>>>> it crashes during initialization.
> >>>> Awesome and all the best. I am sure you will figure it out.
> >>>> Chris
