[PATCH v2 1/2] libchip/ns16550: Allow user calculate baud divisor
G S Niteesh gsnb.gn at gmail.com
Wed Jan 22 03:45:23 UTC 2020
This patch will allow the user to pass a function to calculate
the baud divisor.
This will allow for more flexibility, since for some BSPs
like raspberrypi, the calculation of baud divisor is different
from what is in the current driver.
 bsps/include/libchip/ns16550.h           | 9 +++++++--
 bsps/shared/dev/serial/ns16550-context.c | 2 ++
 2 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/bsps/include/libchip/ns16550.h b/bsps/include/libchip/ns16550.h
index f053c8767f9..b45331a4039 100644
--- a/bsps/include/libchip/ns16550.h
+++ b/bsps/include/libchip/ns16550.h
@@ -60,7 +60,11 @@ typedef uint8_t (*ns16550_get_reg)(uintptr_t port, uint8_t reg);
 typedef void (*ns16550_set_reg)(uintptr_t port, uint8_t reg, uint8_t value);
-typedef struct {
+typedef struct ns16550_context ns16550_context;
+typedef uint32_t (*ns16550_calculate_baud_divisor)(ns16550_context *ctx, uint32_t baud);
+struct ns16550_context{
   rtems_termios_device_context base;
   ns16550_get_reg get_reg;
   ns16550_set_reg set_reg;
@@ -78,7 +82,8 @@ typedef struct {
   size_t out_current;
   const char *out_buf;
   rtems_termios_tty *tty;
-} ns16550_context;
+  ns16550_calculate_baud_divisor calculate_baud_divisor;
 extern const rtems_termios_device_handler ns16550_handler_interrupt;
 extern const rtems_termios_device_handler ns16550_handler_polled;
diff --git a/bsps/shared/dev/serial/ns16550-context.c b/bsps/shared/dev/serial/ns16550-context.c
index ce55b8309cc..dbf6c64af4a 100644
--- a/bsps/shared/dev/serial/ns16550-context.c
+++ b/bsps/shared/dev/serial/ns16550-context.c
@@ -112,6 +112,8 @@ static uint32_t NS16550_GetBaudDivisor(ns16550_context *ctx, uint32_t baud)
       NS16550_FRACTIONAL_DIVIDER,
       fractionalDivider
+  } else if (ctx->calculate_baud_divisor != NULL) {
+    baudDivisor = ctx->calculate_baud_divisor(ctx, baud);
   return baudDivisor;
2.17.1
